Software Archive
Read-only legacy content
17060 Discussions
Problem with _Cilk_shared and big sized data
Jesmin_Jahan_T_
Dear All,
I am facing problem in using _Cilk_shared key word. It does not work for bigger arrays. The same program works well when you have small array size/data.
I am getting either the following error or an error suggesting to increase memory map area.
CARD--ERROR:1 myoiPageFaultHandler: 0x7fffff22a788 Out of Range!
CARD--ERROR:1 _myoiPageFaultHandler: 0x7fffff22a788 switch to default signal handle
CARD--ERROR:1 Segment Fault!
What can we do so that we can use _Cilk_shared with big data (larger arrays).
Jesmin
Sumedh_N_Intel
Could you please post a reproducer for this issue? Also, which version of the compiler are you using?
