Software Archive
Read-only legacy content
17061 讨论
Problems with F200 3DCamera
bernd_k_
初学者
595 次查看
during my tests with RSSDK and F200 camera I often get no connection to the device. For example when I started the softwaretool Camera Explorer 18 times I got 8 times ERROR and 10 times SUCCESS.
ERROR means: "Device failed due to malfunctioning"
SUCCESS means: There is a correct live stream in the output panel.
I use a test computer with Windows 8.1, USB 3.0. For further details please look at attached file My_SDKInfo_Output.TXT
Thanks for your answer...
0 项奖励
2 回复数
Xusheng_L_Intel
595 次查看
Please attach the sdk_info, it will help us to figure out if it is HW issue. Thanks!
0 项奖励
bernd_k_
初学者
595 次查看
Hi David, thank you for answering. Here is the sdk_info (see attach My_SDKInfo_Output.TXT, second try).
0 项奖励
回复
