Software Archive
Read-only legacy content
17060 Discussions
Procblems using gcc with cilkplus binary
Robert_M_
Hallo,
I tried the binary from August 2013 from https://www.cilkplus.org/download-0#gcc-development-branch on my Ubuntu 13.4 x86 VM.
I extracted files to ~/cilkplus-4_8-install and gave execution permission to all files in /bin subfolder and executed
export LD_LIBRARY_PATH=~/cilkplus-4_8-install/lib:~/cilkplus-4_8-install/lib64:$LD_LIBRARY_PATH
export LIBRARY_PATH=~/cilkplus-4_8-install/lib:~/cilkplus-4_8-install/lib64:$LIBRARY_PATH
but not even
~/cilkplus-4_8-install/bin/gcc --version
or
~/cilkplus-4_8-install/bin/g++ --version
works.
g++ simply does nothing, for gcc I get the error message "cannot execute binary file". whats wrong here?
thank you
Jim_S_Intel
x64 or x86_64 VM?  By any chance, are you using the 64-bit version on a 32-bit OS?
It states on the download page, "These compilers are provided as a convenience. They are not guaranteed to be up-to-date or error-free."    If they do not work, you might also try building from source... :)
Cheers,
Jim
Robert_M_
Its x86 only, so 32bit. There is only one \bin directory, even though this build is supposed to be for x86 and x86_64. (no \bin64 folder or gcc64 file)
I'm actually already trying to compile from source.
Some packets cannot be found, which complicates the process:  isl, autoconf (version 2.64, hopefully 2.69 works), gmp, mpfr.
I keep working on that, but I was hoping for a solutions which shortens the process....
Robert_M_
using file command I found out, that it actually IS a x64 binary. So the describtion is probably missleading, saying "These compilers are for the x86-32 and x86-64 architectures.  They were built and tested on SUSE Linux Enterprise Server 11 SP1." - meaning the target platform for compiled code, not the environment the compiler runs in?!
Barry_T_Intel
Thank you for pointing this out.  I've updated the entry on the website to specify that the compilers were built for the x86-64 architecture.
I apologize for the confusion.
    - Barry
Robert_M_
Now using a x64 Ubuntu 13.10.
g++ is an empty file! (0Bit) - so its obvious that it cannot work.
gcc may work, only got c++ code to test here right now. using it with a cpp file results in error:
"libcilkrts.so:file format not recognized, treating as a linker script"
This error is now produced by the gcc delivered with ubuntu as well...
EDIT: After fixing some broken symlinks in directory of cilkplus, I now get
ld: /tmp/RANDOM_NAME.o: undefined reference to symbol '_ZSt17__throw_bad_allocv@@GLIBCXX_3.4'
/usr/lib/x86_64-linux-gnu/libstdc++.so.6: error adding symbols: DSO missing from command line
where RANDOM_NAME changes with every compilation
compilation with build-in g++ is now working again, build-in gcc throw a lot of error. I assume in the build-in gcc is for C and g++ for c++, whereas the cilk-gcc can handle both, c and c++?!
