Software Archive
Read-only legacy content
17060 Discussions
Programmatically detecting CPU affinity of PCI card for sandybridge
stardust496
Folks,
With Sandybrdige, a PCI card has a natural affinity to one CPU. How can I programmatically determine which CPU it is, so that I can affinitize my program to the right CPU?
Many thanks!
Roman_D_Intel
Hi, in Linux you can identify which processor your PCIe device is connected to by reading the "/sys/devices/[PCI root]/[PCIe function]/numa_node" or "/sys/class/[device class]/[interface]/device/numa_node" virtual files. However BIOS should support the proper ACPI feature for such detection, otherwise numa_node will report -1. Best regards, Roman
Roman_D_Intel
in Linux you can look it up in the /sys/devices/[PCI root]/[PCIe function]/numa_node virtual file. However BIOS should support the proper ACPI feature, otherwise you will read -1.
Roman_D_Intel
for network card devices it is also available through "/sys/class/net/[interface]/device/numa_node" file.
