Software Archive
Read-only legacy content
17060 Discussions
Published App not compatible to my device
xkevin
I am having problem downloading my published app on google playstore.
Before publishing the app, I have tried to build the app install on my device (Andriod Version 5.1) and test it several times. It works so well. But when I published it on google play the app is not compatible with my device. Why is that? Tried to clear data and clear cache my play store app and services but no luck.
These are the details in my build setting.
Cordova CLI Version 6.2.0
Minimum Andriod API: 14
Target Andriod API: 21
 This is my first published app, Any help is much appreciated.
Hamilton_Tenório_da_
Valued Contributor I
xKevin> Did you publish 2 files to Google Play (ARM and x86)?
PaulF_IntelCorp
xkevin -- you may be including a plugin that requires specific features which your device does not have. The Google Play Store attempts to filter which devices an app can be installed onto based on "device capabilities" that must match what the software requires. See > https://developer.android.com/guide/practices/compatibility.html#how < for more details.
xkevin
Sir Hamilton, The Intel xdk publish tool automatically uploaded the file on the Play store. I just added the whole zip file in packages under publish tab of the intel xdk.
Some other device like Asus Zenfone 6 able to download it, but mine (Alcatel Flash 2) does not. I also find out (on google play store developer console) that the supported device was only 402. Is there a way to add more device on this list?
I am just wondering why the I am able to install the app when I am testing it (directly download the generated apk after build).
P.S. Whats the differences of ARM and x86 apk? What fits on my device was the arm apk file. Maybe this was the problem..
xkevin
Sir Paul, Thank for the link you've shared. I only added some of the cordova plugins which are:
Notification
InAppBrowser
Device
StatusBar
Camera
Compat
File
File Transfer
And these plugins are supported by my device. I tried and tested it. There was no error or bugs.
xkevin
Ok.. So this is the issue. The uploaded or published apk was only ARM file. I tried to close/refresh the google play store dev console then Go to APK tab -> it is automatically prompt you to upload another file. Then I uploaded x86 file.
So.. new lesson learned! Now I know that there should be two uploaded file (ARM and x86 apk) on the play store. Now I have 12064 Supported devices. :) Thank you for help!
Great! It was my suspiciuos.
xkevin
Thank you Sir Hamilton!
