Software Archive
Read-only legacy content
17061 Discussions
R200 Enhanced Module and IR images
Tiago_F_
Hi! I have been working with the F200 model of RealSense, but yesterday i received the R200 model and tried to adapt my code samples to the new model.
When I try to add the enhanced mode of the R200 model as
PXCCapture::DeviceInfo dinfo={};
dinfo.model=PXCCapture::DEVICE_MODEL_R200_ENHANCED;
sm->QueryCaptureManager()->FilterByDeviceInfo(&dinfo);
It gives me an error message, only working with
Does anyone knows why this happens?
Additionally when can anyone elucidate me about how can i use the left and right images to obtain an IR image as the one obtained in the F200 model?
Thank you for your time!
Eli_E_
Do you use any of the modules in the RealSense SDK? If not, the library called librealsense provides an incredibly simple interface for the IR data. Check out the cpp-capture example -- it will automatically pull the color, depth, and dual IR sensor streams:
https://github.com/IntelRealSense/librealsense
Eli_E_
Tiago_F_
Thank you for your response. I will take a look into it ! But about my second question, it is possible to obtain a IR image like the F200 model in the R200 one? Because the stereoscopic images LEFT and RIGHT are very different from IR images...
Thank you again for your time Eli!
Tiago_F_
I guess i can, but i wasn't able to get them in my older programs. I already tested the library and it works perfectly. Thank You!
I will now try to integrate them in openCV.
