Software Archive
Read-only legacy content
17060 Discussions
Realsense ImageData to OpenCV Mat
Marios_B_
Hi there!
Can someone tell me how I can get the realsense imagedata into a cv::Mat?
I found some stuff in the forum,but I was confused with the planes/pitches.Any links/sample code for conversion from realsense to mat formats?
samontab
Valued Contributor II
It depends on what type of data you want to get, and in what format.
For example, to get a color image, you could do something like this: (it can be done more efficiently, and you should error check on each step, but this should be easy to understand)
Let's say you have a color image:
PXCImage *color
You can create a cv::Mat color image based on it:
//First, create an ImageData object:
PXCImage::ImageData * data = new PXCImage::ImageData;
//Set the format that you want to use:
data->format = PXCImage::PIXEL_FORMAT_RGB32; // For example 4 bytes in this case (8 * 4 = 32)
//Create a cv::Mat black canvas based on the size of the color image
int width = color->QueryInfo().width;
int height = color->QueryInfo().height;
cv::Mat frameColor = cv::Mat::zeros(height, width, CV_8UC3);
//Now get access to the memory of the image:
color->AcquireAccess(PXCImage::ACCESS_READ, data->format, data);
//Now we just need to paint the canvas with each pixel from the image data
 pxcBYTE *cpixels=data->planes[0];
int x = 0, y = 0;
        for(int i=0; i < width * height; i++)
            //BGRA
            //Read the first 3 bytes of each 4 bytes, and ignore the last one
            pxcBYTE bvalue = cpixels[i * 4 + 0];
            pxcBYTE gvalue = cpixels[i * 4 + 1];
            pxcBYTE rvalue = cpixels[i * 4 + 2];
            unsigned int bvalueUchar = static_cast<unsigned int>(bvalue);
            unsigned int gvalueUchar = static_cast<unsigned int>(gvalue);
            unsigned int rvalueUchar = static_cast<unsigned int>(rvalue);
            frameColor.at<cv::Vec3b>(y, x)[0] = (bvalueUchar);
            frameColor.at<cv::Vec3b>(y, x)[1] = (gvalueUchar);
            frameColor.at<cv::Vec3b>(y, x)[2] = (rvalueUchar);
            //Advance, one pixel at a time (can be done better of course!)
            x += 1;
            if(x >= width)
                x = 0;
                y += 1;
        //At the end, release all the used memory
        color->ReleaseAccess(data);
        delete data;
samontab
PXCImage *color
int x = 0, y = 0;
            //BGRA
            x += 1;
            if(x >= width)
                x = 0;
                y += 1;
        delete data;
Marios_B_
Thank you for your reply.
I now understood the planes thing.However what exactly is the pitch?
Also,what happens if I also want the depth pixels?
Same thing exactly but with only 1 value per pixel?
samontab
Hi Marios,
I recently made a video tutorial explaining how to get the depth, IR, and colour streams into OpenCV using a single and a multi threaded approach. You might find this useful:
https://software.intel.com/en-us/forums/realsense/topic/595033
