Software Archive
Read-only legacy content
17060 Обсуждение
Registration Center error - Account does not exist
HAL_UK
Начинающий
2 188Просмотр.
I'm not able to access My Profile at the registration center (https://registrationcenter.intel.com/regcenter/register.aspx) since changing the account login.
Each time I try to login I get an error stating "Error. This account does not exist."
Facts:
  • Using "Forgot Login ID" at the registration center page works and I'm getting the login ID art of my credentials by mail.
  • Using "Forgot Password" at the registration center page works and I'm getting the pw change link by mail and I'm able to change the password.
  • The very same credentials work when login in here at "https://software.intel.com"
0 баллов
10 Ответы
Hubert_H_Intel
Сотрудник
2 188Просмотр.
Should be solved now. Were you able to login now?
Regards, Hubert.
HAL_UK
Начинающий
2 188Просмотр.
Hi Hubert, yes thanks.  We were able to login in successfully and finally download the licence file,
Thanks for your help getting this sorted for me,
regards, Yvonne
Gopi_s_
Начинающий
2 188Просмотр.
I am also facing the same problem(Registration Center error - Account does not exist)...could you please check and do the needful?
Gopi
Hubert_H_Intel
Сотрудник
2 188Просмотр.
Hi Gopi,
Can you tell me your email or login you used for software license registration in the Intel® Registration Center? PLEASE answer via 'Send Author A Message' link to protect confidential data.
Regards, Hubert.
MORRIS_L_
Начинающий
2 188Просмотр.
I am also facing the same problem recently (Registration Center error - Account does not exist)
Please could you do me favour and check mind also?
Morris Law
Hubert_H_Intel
Сотрудник
2 188Просмотр.
Hi Morris,
Could you please tell me your login id and email you used for login? Please answer via "Send Author A Message" to protect confidential data.
Regards, Hubert.
Young-Moo
Начинающий
2 188Просмотр.
I have the same problem: This account does not exist. Can you solve this problem?
Young-Moo Byun
Kai-Chun_H_
Начинающий
2 188Просмотр.
I have the same problem, too.This account does not exist. Can you help me solve this problem?
My login ID: hitoshihsu
Email: loanve222@gmail.com
Hubert_H_Intel
Сотрудник
2 188Просмотр.
Hi Kai-Chun,
I don't see a problem with your account. Where did you try to login? https://registrationcenter.intel.com ?
But I guess you need the license file to overcome the known issue with "trusted storage". I've sent it to your email. Once you have your license file (*.lic), copy it to the following folder:  C:\Program Files(x86)\Common Files\Intel\Licenses\
But please check again the login. Let me know if it still doesn't work.
Regards, Hubert.
Hubert_H_Intel
Сотрудник
2 188Просмотр.
Hi Giorgio,
I see expired evaluation and non-commercial license registrations only under your account with the referenced email. Thus access to the Intel(R) Registration Center has expired too. Or do you have registrations under a different email too?
What exactly did you want to obtain from the Intel(R) Registration Center?
Regards, Hubert.
Ответить
