Software Archive
Read-only legacy content
17060 Discussions
SDK Sample Browser - Hands Viewer Javascript
germ13
I was testing  the "Hands Viewer (Javascript)"  code from  the SDK Sample Browser and the example would not work, until I went into the code and changed the file:
hands_viewer.html (line 104)
from
if (data.hands == 'undefined') return;
to
if (data.hands === 'undefined') return;
Just thought I'd share, might help someone.
And if any Intel personnel is reading this, is there a code repository where we can maybe share code bugs/suggestions?  If no, why not? :) Thanks :)
Xusheng_L_Intel
It works under Chrome. Are you using IE?
germ13
Yes, I am using the most recent chrome as my dev browser.
I stepped through the code, and thats where the issue was at.
I am going to set up a clean user environment for chrome, without any of my extensions.
Martin_W__K_
the problem still exists in the latest versions of the SDK.
This doesn't work in Chrome nor Firefox.
Reason: your need to check the type via 'typeof'.
See also: https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Operators/typeof
Correct code:
if (typeof data.hands === 'undefined') return;
@IntelDevelopers: please update the SDK :-)
Thanks in advance
Martin
Martin_W__K_
There is a second issue in this example file.
From time to time, this error occurs:  Uncaught TypeError: Cannot read property 'positionImage' of undefined
I've found the root cause and fixed it.
Please, see this github ghist revisions for the two fixes:
https://gist.github.com/nitram509/7d8869f30d76db97c683/revisions
