Software Archive
Read-only legacy content
17060 Discussions
SSH to Intel Xeon Phi card sometimes is kicked out and require password to access again
MChun4
Dear all,
Please help me with the problem: sometimes, I access the Xeon Phi cards by ssh, however, it takes a short time and kicks me out, the user for access is just a normal user. It has not occurred with root user. After that, I restart the service MPSS and it is ok.
Actually, I don't know the reason why, please help me with this problem. Below is the information of our Xeon Phi cards:
MicInfo Utility Log
Created Wed Aug 23 11:43:00 2017
System Info
HOST OS : Linux
OS Version : 3.10.0-514.21.1.el7.x86_64
Driver Version : 3.8-1
MPSS Version : 3.8
Host Physical Memory : 257518 MB
Device No: 0, Device Name: mic0
Version
Flash Version : 2.1.02.0391
SMC Firmware Version : 1.17.6900
SMC Boot Loader Version : 1.8.4326
Coprocessor OS Version : 2.6.38.8+mpss3.8
Device Serial Number : ADKC44700369
Board
Vendor ID : 0x8086
Device ID : 0x225c
Subsystem ID : 0x7d95
Coprocessor Stepping ID : 2
PCIe Width : Insufficient Privileges
PCIe Speed : Insufficient Privileges
PCIe Max payload size : Insufficient Privileges
PCIe Max read req size : Insufficient Privileges
Coprocessor Model : 0x01
Coprocessor Model Ext : 0x00
Coprocessor Type : 0x00
Coprocessor Family : 0x0b
Coprocessor Family Ext : 0x00
Coprocessor Stepping : C0
Board SKU : C0PRQ-7120 P/A/X/D
ECC Mode : Enabled
SMC HW Revision : Product 300W Passive CS
Cores
Total No of Active Cores : 61
Voltage : 1029000 uV
Frequency : 1238095 kHz
Thermal
Fan Speed Control : N/A
Fan RPM : N/A
Fan PWM : N/A
Die Temp : 58 C
GDDR
GDDR Vendor : Samsung
GDDR Version : 0x6
GDDR Density : 4096 Mb
GDDR Size : 15872 MB
GDDR Technology : GDDR5
GDDR Speed : 5.500000 GT/s
GDDR Frequency : 2750000 kHz
GDDR Voltage : 1501000 uV
Device No: 1, Device Name: mic1
Version
Device Serial Number : ADKC50600135
Board
Vendor ID : 0x8086
Device ID : 0x225c
ECC Mode : Enabled
Cores
Voltage : 1003000 uV
Thermal
Fan RPM : N/A
Fan PWM : N/A
Die Temp : 53 C
GDDR
GDDR Version : 0x6
