Software Archive
Read-only legacy content
17060 Discussions
Scigraph demo options
pecan204
I am working with the scigraph sample and would like to setup project again like sample but cannot figure out how to set same compiler options as in the scigraph sample fortran tab. The AlphaRel option seems to be the issue.
Do I need this setting and if so how do I set it?
The sample contains:
/compile_only /debug:full /include:"AlphaRel/" /nologo /threads /warn:nofileopt /module:"AlphaRel/" /object:"AlphaRel/" /pdbfile:"AlphaRel/DF60.PDB"
The "AlphaRel" means that the configuration you're looking at is for Alpha processor systems. It is just a subfolder name.
For the SCIGRAPH library project, it's just a "Fortran Static Library" with one change - under Libraries, check the "Use Multithreaded Library" box.
For your application which uses SCIGRAPH, it must be a QuickWin or Standard Graphics application.
Steve
pecan204
I do not see where the selection of Use Multithreaded Library Box is?
In Project setting/libraries there is only
output filename
suppress startup banner
and project options.
Thanks for info.
Project..Settings..Fortran..Libraries. You're looking at the Link settings, I think.
Steve
