Software Archive
Read-only legacy content
17061 Обсуждение
SenseManager Init Failed
Ben_S_1
Начинающий
1 499Просмотр.
Hi, I have a new R200, everything installed correctly, and some of the samples (that do not require Scenemanager) run fine. librealsense runs fine.
But, when I try the augmented reality SDK sample, or the Sceneperception(which is what I actually need) I get:
RF_ScenePerception: Starts.
RF_ScenePerception: being configured...
Press any key to continue . . .
I have rebooted, tried a different usb port, and reinstalled the DCM(latest version intel_rs_dcm_r200_2.1.27.2853)
I am on Windows 10, 64, and have a gtx970 gpu. Please see the SDK info text file attached. Thank you.
0 баллов
6 Ответы
dugua_y_
Начинающий
1 499Просмотр.
Did you try to run the x64 samples ?
In my case I am not able to init 32 bits scene perception on windows 10 x64. Only the 64 bits version works.
I already post about this issue but I did not get any reply.
Yohann
Ben_S_1
Начинающий
1 499Просмотр.
Aha, i found out what was wrong. the DCM service was never starting. uninstalling it, and re-installing as admin has fixed this for me.
dugua_y_
Начинающий
1 499Просмотр.
lucky you.
On my Surface Pro 4 I have unstalled and reinstalled many times but it still not working.
Ben_S_1
Начинающий
1 499Просмотр.
Have you checked in task manager that the DCM service is running? TaskManagr>Services>RealsenseDcmR200
Have you seen this:
https://software.intel.com/en-us/forums/realsense/topic/560608
There is a bat script that will start it. Worth a shot if you have not tried already. Good luck!
...not much support for this hardware it seems!
Johannes_V_
Новый участник I
1 499Просмотр.
have you tried emailing the support team?
Ben_S_1
Начинающий
1 499Просмотр.
I did, and got this back : 'Thank you for contacting Click Support. Click does not provide technical support for the Intel RealSense Developer Kit. Please contact the Intel RealSense SDK forum for technical assistance at https://software.intel.com/en-us/forums/realsense. If you do not see an answer posted on the forum, please submit your question.' Is there a specific support email address I should be using? Thanks!
Ответить
