Software Archive
Read-only legacy content
17060 Discussions
Setup Problem in application created using Intel RealSense SDK
Linda_M_
As I developed an application using the Emotion Viewer sample application,I need to setup this application and run in any systems which has the corresponding requirements provided by the RSSDK. Here I used C# .Net  as the development platform. So I added "libpxcclr.cs.dll" and "libpxccpp2c" as the references to my application. But it is working fine with the systems where the RSSDK is installed. And not working on the other systems where the RSSDK is not installed. Do I need to add any additional references or files to run this application on systems without the RSSDK?
Please help!!!
Colleen_C_Intel
Please see the PDF in the Docs directory titled SDKDevGuide
Linda_M_
Thanks Collen..Will see..
Jonathan_M_Intel
Linda - you just need to send the "runtime" installer along with your application's installer.  If you're just using core camera & depth functions, but not the more advanced hand/face/etc tracking modules, then you can get away with the smaller "core" installer, otherwise you can ship the larger full installer (or if you'd like to save bandwidth, the PDF Colleen pointed you to will show you how to create the specific installer script you'll need).
The installers are in the RSSDK/runtime folder.
Sankalp_S_
Jonathan - I am working in unity game engine. Can you guide me how to include runtime installer in my unity project ? It gives me one .exe file and data folder, no application installer.
Please help.
MartyG
Hi Sankalp,
Unity usually exports the files necessary to run a RealSense project when you create the exe.  I imagine they would be in the data folder.  So with Unity, you should not need to use the runtime installers in the RSSDK folder, which are likely meant for installing non-Unity RealSense applications.
Sankalp_S_
Thanks for reply Marty, as i understand from documents, runtime installers design to install sdk with application or update sdk to latest version.
If i run my project in a non sdk system it does not installed sdk and no RealSense controls working, but if i run my project in a system which have RealSense sdk installed everything works fine.
Please update me where am i wrong.
MartyG
Hi Sankalp,
I made my app for the RealSense App Challenge contest, where the judges will have the SDK installed on their judging computers.  I therefore haven't tried running my app without the SDK being on my machine (because there was no reason to), so I haven't experienced your problem with running when the SDK is uninstalled.  So I have no further advice I can give on the subject.  My apologies, and I hope you find a solution soon.
