Software Archive
Read-only legacy content
17060 Discussions
Some trouble in Intel RealSense SDK programming
yinhu_z_
Why the Initialization statement "psm->Init() < PXC_STATUS_NO_ERROR" always gets the true result?
jb455
Valued Contributor II
If it's working fine, that should evaluate to false, not true. Only if there is some error will it evaluate to true.
Why: PXC_STATUS_NO_ERROR will be given an internal numeric value, say 0. All the other error codes will then have the value of -1,-2,-3 etc, so if the status is something other than NO_ERROR (ie, less than 0) it will evaluate as true then you can handle the error inside the if block. You can find a list of the possible statuses here: https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?pxcstatus.html
Hopefully that makes sense!
