Software Archive
Read-only legacy content
17060 Discussions
System interfaces and integer(8)
james1
Are there any plans to take advantage of integer(8) in the interface definitions? This would lead to a more normal interaction with a number of services, rather than using types based on the assumption that integer(4) is the largest integer data type.
James
Which services did you have in mind?
Steve
james1
Basically any structure or call interface in DFWINTY and KERNEL32 that reference type (T_LARGE_INTEGER) and (T_LARGE_INTEGERX). A typical example is GetDiskFreeSpaceEx which requires 8 byte integers. Of course one can always re-define the interface or equivalence one type to another, however it would certainly be cleaner and more "natural" to simply deal with the integers now that we have eight byte integers implemented.
James
james1
Wondered if there was an answer to this one yet? Thanks.
James
james1
Here is another example. I have some code that does some time arithmetic with the integer(8) time representation. Routines such as GetSystemTimeAsFileTime and SetWaitableTimer are used. In each case a different "type" is needed, so I end up have equivalence statements such as:
integer(DWORDLONG) binary_time
type (T_FILETIME) binary_time_filetime
type (T_LARGE_INTEGER) binary_time_large
equivalence (binary_time, binary_time_filetime, binary_time_large)
And using the appropriate variable name for each case, which make the code harder to follow for the next guy. I'd rather have the ability to cast in this case, it would actually be more readable, IMHO.
James
