I'm confused about the internal meaning of the product of HostTSC and the TSC multiplier being shifted right 48 bits before being added to the TSC offset. I am also confused about the binary layout of the field.
If for example host frequency was 2.5 ghz, and I wanted a guest reflection of 2.6, my ratio would be 1.04. According to the very short documentation on this field:
Specifically, an affected read from the timestamp co
unter first computes the product of the value of the
IA32_TIME_STAMP_COUNTER MSR and the value of the TS
C multiplier. It then shifts the value of the
product right by 48 bits and loads EAX:EDX with the
sum of that shifted value and the value of the TSC
offset.
Assuming that the final value must be a whole number, what is the meaning of this?
- Tags:
- Virtualization
Hello John,
This document online may provide some hint for your case: https://www.ccsl.carleton.ca/~jamuir/rdtscpm1.pdf.
-Thai
