Software Archive
Read-only legacy content
17061 Discussions
Twitter and Instagram Web services working within the Intel XDK emulator but not responding on my android and windows phone
wilmot_B_
I have an Intel XDK App, with a bootStrap UI Framework.
I called some web services within the app (Twitter and IG) using the "Explore Services" tab within the Intel XDK and I enabled the Cordova Plugins within the XDK.
I then called the web services and entered the necessary Tokens for authentication to get feeds from Twitter and Instagram.
The App works works properly with the Intel XDK Emulator and gets all the feeds but when I built it for My Android and Windows Phone, the page is blank and empty. It shows only my header, and not the feeds from twitter and Instagram.
Does anyone have any idea what's wrong?
Swati_S_Intel1
Does your app work in test tab using App Preview? What android device are you using?
wilmot_B_
@SWATI S. Thank you for the reply. The app doesn't work correctly in the test tab using App Preview either. I tested it on HTC One X(Android) and also on BlackBerry Z10(Which also run android apps), I also tested the app on a Windows phone, but I still encountered the same problem.
Thank you.
Swati_S_Intel1
Can you please send your project, I'll have a look at and see what's wrong.
Swait
wilmot_B_
@Swati S Thank you very much, please find attached document.
