Software Archive
Read-only legacy content
17060 Discussions
Using iOS HealthKit in Intel XDK
Narayan_P_
I am using HealthKit in an Intel XDK app. For HeathKit I am using ngCordova HealthKit Plugin(http://ngcordova.com/docs/plugins/healthkit/)
But the problem is how do I add "HealthKit" entitlement to the entitlements file.
Please see the attached image for the list of things required for HealthKit to work
Everything else such as linking the framework, app ID etc is done. Please help
Brandon_K_Intel
From the documentation, it looks like the plugin adds this for you. Have you tried building your application?
Narayan_P_
No it doesn't. I have tried it multiple times.
I used Cordova CLI to generate XCode project. Then made this change in the XCode it worded. Therefore plugin doesn't do that.
Any solution?
PaulF_IntelCorp
Since you were able to do it locally, with an XCode project, you could deduce what the change in XCode meant for the plugin code. One way to do that would be to:
  • take a snapshot of the XCode project before you make the "entitlements file" change
  • make the XCode project change that fixes the "entitlements file" issue
  • compare the snapshot project to the fixed project
  • report the changes you found
Based on the changes you found we might be able to provide instructions on how to make this change manually in the plugin. If not, it may be that this can only be done on a local CLI build, in which case our cloud-based build system will not work for this plugin.
Narayan_P_
It creates an .entitlements file after enabling the options. I have attached a image. The first file in the directory.
How can I do that using the plugin?
PaulF_IntelCorp
That location of that entitlements file is not going to translate well into the XDK cloud build system. If it was located inside the www directory our build system could deal with it, but that location is not going to work with our current system. I'm assuming that you do not move the file from that location, and the build works properly when the file is located there?
