Software Archive
Read-only legacy content
17060 Discussions
V3522 Build System failing to insert Install Link
Nick_F_2
New Contributor III
The Build system is failing to insert the link into emails to install directly, the only options are to download the IPA file or the application log file, followed by the instructions on how to install via iTunes.
Can yo fix this missing link please.
PaulF_IntelCorp
EDIT -- Appears that a change in the backend has broken the OTA link. We're working on rolling back that change, should be fixed by the end of the day.
---- original post ----
Nick -- that OTA link in the email works ONLY with the standard iOS email app. If you are using the gmail or outlook or some other email app it will not work. Sorry, that's a limitation of the iOS system.
