Software Archive
Read-only legacy content
17061 Discussions
VTune 2015 Trial Version License Error
S_D_
I downloaded and installed a 30-day trial version of Intel VTune Amplifier XE 2015 today on my windows 64-bit machine. However, after running some profiling, as part of opening the results, VTune is throwing a license check error, similar to below.
License Check Failed
Intel VTune Amplifier XE 2015 cannot find a license file. Data cannot be displayed.
Error 0x4000001f (No valid license) -- License file is not found. Make sure that your license file is in the correct location and readable.
In the About VTune dialog > Details tab, the "License Type" and "Expiration Date" fields are empty.
What do I need to do fix this issue so that I can view the profiled results?
thanks!
Light_Intel
We now have a workaround for this issue. Please see the following article:
https://software.intel.com/en-us/articles/Intel-VTune-Amplifier-Evaluation-Version-License-Error
Also bear in mind. An evaluation license is only good for 30 days. Once it had expired it will no longer be usable.
Hubert_H_Intel
I've sent the license fie.
Hubert.
Cedric_R_
Hello Hubert,
I got the same error with VTune Amplifier 2015 [update 2].
I sent you my email address by PM.
Can you please send me the eval license file?
Naif_J_
Hello Hubert,
Ankit_R_
I have the exact same issue. There is no license file under CommonFiles\Intel\Licenses.
Hubert_H_Intel
Ankit,
Which is your email address you used for eval license registration (please answer via "Send Author A Message").
Hubert.
Anusha_D_
I also am in the same boat. Analysis results cannot be seen because the license file is missing in Evaluation mode.
Hubert, I sent you a message. Hope you'll get back to me soon.
Hubert_H_Intel
Hi Thomas,
I've sent the eval license to your email.
Regards, Hubert.
Christophe_K_
 I'm having the same issue trying VTune Amplifier 2015:
I have the License tab of "Intel software manager" with a 31 days evaluation license, but impossible to make an analysis because I get :
"Intel VTune Amplifier XE 2015 cannot find a valid license."
And this close the analysis without getting any result.
Regards, Christophe.
Hubert_H_Intel
Christophe,
I do not see any eval license registrations under your name. Please let me know the serial number or the email address uncer which you registered your eval license. PLEASE answer via "Send Author A Message".
Thanks! Regards, Hubert.
Surabhi_J_
Hi Hubert,
I am also getting licence error and cant find the licence files in the desired location. Trying to use 30 days evaluation product.
Please help me with this.
Hubert_H_Intel
Hi Surabhi,
I've sent you your eval license files (for Linux and Windows).
Regards, Hubert.
Hubert_H_Intel
Under which email did you register your eval license? Please answer via "Send Author A Message"
Regards, Hubert.
Warikoo__Ashutosh
I guess I require the same help as well.
Hubert_H_Intel
Ashutosh,
License file sent to your email.
Regards, Hubert.
Amanda_M_
Hello Hubert,
I'm getting this same error as well.
Thanks, Amanda
Hubert_H_Intel
Hi Amanda,
Have sent you the license file.
Hubert.
Anton_M_
Hello Hubert,
Getting the same error.
Thanks, Anton
Madan_M_
Hello Hubert,
Getting same problem.
Thank you in advance, Madan
Hubert_H_Intel
Madan, I've sent you the license file.
Regards, Hubert.
Trishla_S_
Hello Sir,
I too am having the same problem license while working with Intel Vtune Amplifier XE 2015.
I have installed in eval mode only.
Can I please get a solution??
Trishla
David_A_Intel1
Hi Trishla:
I've sent the license file to your registered email address.
Note: anyone can follow the instructions on this page to send the license file to themselves.  Save the email attachment to your system and reference it during installation via the "alternative method" option.
Also, please be aware that our email with the license may be blocked, either as spam or because it has an attachment. You may want to add 'intel.registration.center@intel.com' to your contacts list.
