Software Archive
Read-only legacy content
17061 Discussions
When building app XDK crashes
Mike_C_4
Hi All,
When attempting to build a android app the XDK app crashes. This started with version 3088 and is also doing it in 3240. However 3240 is doing much more frequently
is anyone experiencing the same issue?
Thanks Mike
Swati_S_Intel1
Are you seeing this issue every time you build? Please send xdk.log file after the crash.
Mike_C_4
no it don't, just more with build 3240, where are logs located at? The next time it happens i will upload the logs
Mike_C_4
okay just happen here is the log
Swati_S_Intel1
Hi Mike, the log shows the activities after the XDK restarted. It doesn't give much information. If next time it happens, copy the log file before you restart the XDK. Also, we've found some crashlogs that are showing similar behavior. We are looking into it.
Swati_S_Intel1
@Mike, Can you PM your project zip, so we can try to reproduce this? Thanks.
Mike_C_4
okay it crash on me today I attached the log
PaulF_IntelCorp
Mike -- my guess is the Emulate tab is causing your app to crash. There are references in the log to API calls for AdMob, which could only be from your code running in the Emulate tab. The Emulate tab doesn't have any actual code to support those calls, and is probably crashing as a result.
I suggest you "stop" the Emulate tab before you do your build, using the "stop" icon in the Emulate tab's toolbar. See this post for more workarounds > https://software.intel.com/en-us/forums/intel-xdk/topic/624417
Mike_C_4
Okay  Paul,
I keep that in mine when I build thanks.
