Software Archive
Read-only legacy content
Windows - Parallel Studio C++/Fortran 2017 Update 4 installation crash
damienhocking
I just tried to install update 4, and it crashes the installation right at the end after updating all the packages, trying to update the tools in VS2015.  I have VS2017 installed as well, but it never gets to there.  It's done this three times now.
Which logs do you need?
Damien
Devorah_H_Intel
    It can happen when some products of the same family have been previously installed. Usually it happens at the end of installation, when all components are already installed.
This issue was resolved by the following steps:
1. Remove all current and older versions of Intel products
2. Repair VS 2015
3. Reinstall PSXE 2017 update 4
Devorah_H_Intel
Thank you for the report. Install logs would be helpful
They are located in Temp, i.e.
C:\Users\username\AppData\Local\Temp\pset_tmp_PSXE2017_username\2017.04.xx_xxxxxxxxxxx\log
 Please open VS, go to Help>About> click Copy Info and send us the text file with pasted information. Then click System Info and send us the copy of System Summary.
damienhocking
Here you go.
damienhocking
VS2015 info
Devorah_H_Intel
Thank you for the information and logs. I have escalated this to our Install team for further investigation.
Devorah_H_Intel
2. Repair VS 2015
damienhocking
OK, I'll try that.  Thanks.
damienhocking
Yes, that fixed it.  Took a while to do.
Devorah_H_Intel
Thank you for the update. Glad to hear that this was resolved.
