Software Archive
Read-only legacy content
17060 Discussions
XDK Crashing in macOS Sierra
Mike_C_2
XDK crashes after a few minutes of normal use on macOS Sierra.
Anyone else having this problem?
I searched the forum and it doesn't look like anyone has mentioned Sierra, either having problems or warning against install.
PaulF_IntelCorp
That version of Mac OSX came out after the current release of the XDK. We have not tested against the XDK against it, yet. It is likely due to some compatibilities with node-webkit used by the XDK, which is not due to be updated until later this year. Also, none of us are using that latest version of OSX on our regular machines due to an embargo on updating to that version by our IT department for some (unrelated to the XDK) compatibility issues.
I'll file a bug reporting the issue. If you are seeing a request to send in crash reports, please do send them in, engineering does review them.
Mike_C_2
Thanks for the reply.
That's too bad. I guess I'll have to downgrade to El Capitain to continue my development.
gameglaux
Im running XDK on Sierra and havent experienced any problems. Is there any specific area within XDK that causes the crash?
Diego_Calp
Valued Contributor I
Sam as gameglaux, not problem with latest XDK version and macOS Sierra 10.12.
