Software Archive
Read-only legacy content
公告
17060 討論
XDK Directory Structure
Bob_Seabrook
初學者
1,119 檢視
 I'm just starting to port apps to this framework.
My question is: Is the directory structure I see  cast in stone for XDK?  "vendors" rather than scripts. etc.
0 積分
4 回應
Elroy_A_Intel
員工
1,119 檢視
The Intel® XDK file structure doesn't required you to use any specific naming convention for your directories.
Note: New projects are created with www/ as the root directory. All files relevant to your project should be located within this file directory. www/ directory is commonly used to hold HTML applications within native apps.
Bob_Seabrook
初學者
1,119 檢視
 Question:
Regarding the latest versions of Jquery and JQM  , is it fine to use latest release with INTEL XDK?
PaulF_IntelCorp
1,119 檢視
Yes, you can use any JavaScript framework that will work in a Cordova/PhoneGap environment. The XDK package provides a similar environment. If you choose to use App Designer to create an app, one of the options is to use jQuery Mobile.
We recommend that you use App Framework, it has been specifically optimized for use with embedded webviews and deals with some problems that are unique to these hybrid mobile apps.
Bob_Seabrook
初學者
1,119 檢視
    You're going to make me work for it right?  LOL...will have to build a couple of macros to strip out the JQM txt
回覆
