Software Archive
Read-only legacy content
17060 Discussions
XDK, NFC plugin, functions are not defined
Lukas_B_
Hello all,
I have a problem with my first simple application in Intel XDK. It is very simple test program for NFC.
For this I have installed the phonegap-nfc plugin.
In index.html file I have only one button which call the javascript function:
<html>
<head>
<meta http-equiv="Content-type" content="text/html; charset=utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1, user-scalable=no">
<style>
  @-ms-viewport { width: 100vw ; zoom: 100% ; }  @viewport { width: 100vw ; zoom: 100% ; }
  @-ms-viewport { user-zoom: fixed ; }           @viewport { user-zoom: fixed ; }
</style>
<script src="cordova.js"></script>
<script src="js/app.js"></script>
<script src="xdk/init-dev.js"></script>
</head>
<body>
<form>
<p>Unicate App</p>
<input type="submit" value="Write" onClick="writeNDEF">
</form>
</body>
</html>
In the app.js file is also very simply functions which prepare the message "unicate test" and the write it:
function onAppReady()
    if( navigator.splashscreen && navigator.splashscreen.hide ) {   // Cordova API detected
       navigator.splashscreen.hide() ;
document.addEventListener("app.Ready", onAppReady, false) ;
function onSuccess() {
    window.alert("Send success"); }
function onFailure() {
    window.alert("Send errors");  }
function writeNDEF() {
var message = [
    ndef.textRecord("Unicate test")
nfc.write(message, [onSuccess], [onFailure]);
The problem is that there is a error message "ndef is not defined (w117)" and "nfc is not defined".
Can you tell me why it not connected to the plugin phonegap-nfc?
Do you have any idea what I am doing wrong?
Thank you very much for your help.
BR Lukas
PaulF_IntelCorp
Those are JS Hint problems you are seeing. See the "Blank Cordova Starter App" and the "Hello Cordova App" in the "samples and demos" section of "start a new project" for an example of how to deal with JS Hint errors and how to build a simple Cordova app. Also, see the JS Hint documentation > http://jshint.com/docs/ <
