Software Archive
Read-only legacy content
17060 Discussions
XDK - Project not found!
Flemming_P_
Hi
This is very annoying ..
Every new exported Cordova project from Construct 2 is showing this
Project not found! on start of XDK 3400, then I have to start over
remove project from within XDK and create a new and then
do al the basic stuff again, like adding all icons. info......
Why ?
PaulF_IntelCorp
Not sure why that is happening. Can you provide a sequence of steps to reproduce the issue, and include an exported Construct2 sample that you are using to reproduce those steps? Please attach the exported Construct2 sample to your post with the set of steps required to reproduce the problem. You can use the "Attach Files to Post" button below the forum post edit window.
