Every time I try to build up my app it crash. I am trying to build a rpg maker mv project.
What can I do to solve this?
I will put the log :
xdk:client:[2016-04-14T00:48:25.504Z]: (1460594905505): memlim: 767557632
xdk:client:[2016-04-14T00:48:25.508Z]: (1460594905508): Setting NW crash dump to: C:\Users\Usuario\AppData\Local\XDK
xdk:client:[2016-04-14T00:48:25.717Z]: (1460594905717): Intel XDK: 3088
xdk:client:[2016-04-14T00:48:25.717Z]: (1460594905717): Platform: win32-ia32 (6.3.9600)
xdk:client:[2016-04-14T00:48:25.717Z]: (1460594905717): System Info: CPU: 4 X Intel(R) Core(TM) i5-3330 CPU @ 3.00GHz Physical Memory: 8527228928
xdk:client:[2016-04-14T00:48:25.717Z]: (1460594905717): NW: 0.11.7-rc10-dev
xdk:client:[2016-04-14T00:48:25.777Z]: (1460594905777): Created new theme: base
xdk:client:[2016-04-14T00:48:25.777Z]: (1460594905777): Registered new theme: base
xdk:client:[2016-04-14T00:48:25.783Z]: (1460594905783): Current theme is now: base
xdk:client:[2016-04-14T00:48:25.784Z]: (1460594905784): Loading theme from: ../../public/themes/xdk.json
xdk:client:[2016-04-14T00:48:25.785Z]: (1460594905785): Failed to load theme: xdk { [Error: Cannot find module '../../public/themes/xdk.json'] code: 'MODULE_NOT_FOUND' }
xdk:client:[2016-04-14T00:48:26.093Z]: (1460594906093): Starting client process initialization
xdk:client:[2016-04-14T00:48:26.122Z]: (1460594906122): NW Cache is up-to-date.
xdk:server:[2016-04-14T00:48:26.685Z]: (1460594906686): memlim: 767557632
xdk:server:[2016-04-14T00:48:26.691Z]: (1460594906691): Setting NW crash dump to: C:\Users\Usuario\AppData\Local\XDK
xdk:server:[2016-04-14T00:48:26.942Z]: (1460594906942): Starting server process initialization
xdk:server:[2016-04-14T00:48:27.087Z]: (1460594907088): Http server started on the standard port 58889
xdk:server:[2016-04-14T00:48:27.111Z]: (1460594907111): NW Cache is up-to-date.
xdk:server:[2016-04-14T00:48:27.625Z]: (1460594907625): Component "core:assert" starting import
xdk:server:[2016-04-14T00:48:27.626Z]: (1460594907626): Component "core:assert" finished initialization
xdk:server:[2016-04-14T00:48:27.626Z]: (1460594907626): Component "core:component-error" starting import
xdk:server:[2016-04-14T00:48:27.626Z]: (1460594907626): Component "core:component-error" finished initialization
xdk:server:[2016-04-14T00:48:27.626Z]: (1460594907626): Component "core:command-line-options" starting import
xdk:server:[2016-04-14T00:48:27.626Z]: (1460594907626): Component "core:command-line-options" finished initialization
xdk:server:[2016-04-14T00:48:27.626Z]: (1460594907626): Component "core:service-error" starting import
xdk:server:[2016-04-14T00:48:27.627Z]: (1460594907627): Component "core:service-error" finished initialization
xdk:server:[2016-04-14T00:48:27.627Z]: (1460594907627): Component "core:buffer" starting import
xdk:server:[2016-04-14T00:48:27.627Z]: (1460594907627): Component "core:buffer" finished initialization
xdk:server:[2016-04-14T00:48:27.627Z]: (1460594907627): Component "core:signaler" starting import
xdk:server:[2016-04-14T00:48:27.629Z]: (1460594907629): Component "core:signaler" finished initialization
xdk:server:[2016-04-14T00:48:27.629Z]: (1460594907629): Component "core:signaler-group" starting import
xdk:server:[2016-04-14T00:48:27.631Z]: (1460594907631): Component "core:signaler-group" finished initialization
xdk:server:[2016-04-14T00:48:27.631Z]: (1460594907631): Component "core:logger" starting import
xdk:server:[2016-04-14T00:48:27.632Z]: (1460594907632): Component "core:logger" finished initialization
xdk:server:[2016-04-14T00:48:27.632Z]: (1460594907632): Component "core:http-request" starting import
xdk:server:[2016-04-14T00:48:27.633Z]: (1460594907633): Component "core:http-request" finished initialization
xdk:server:[2016-04-14T00:48:27.633Z]: (1460594907633): Component "core:database" starting import
xdk:server:[2016-04-14T00:48:27.634Z]: (1460594907634): Component "core:database" finished initialization
xdk:server:[2016-04-14T00:48:27.634Z]: (1460594907634): Component "core:version" starting import
xdk:server:[2016-04-14T00:48:27.634Z]: (1460594907634): Component "core:version" finished initialization
xdk:server:[2016-04-14T00:48:27.634Z]: (1460594907634): Component "core:userfs-name-converter" starting import
xdk:server:[2016-04-14T00:48:27.635Z]: (1460594907635): Component "core:userfs-name-converter" finished initialization
xdk:server:[2016-04-14T00:48:27.635Z]: (1460594907635): Component "core:crash-handler" starting import
xdk:server:[2016-04-14T00:48:27.636Z]: (1460594907636): Component "core:crash-handler" finished initialization
xdk:server:[2016-04-14T00:48:27.636Z]: (1460594907636): Component "core:i18n-support" starting import
xdk:server:[2016-04-14T00:48:27.636Z]: (1460594907636): Component "core:i18n-support" finished initialization
xdk:server:[2016-04-14T00:48:27.636Z]: (1460594907636): Component "core:theme" starting import
xdk:server:[2016-04-14T00:48:27.683Z]: (1460594907683): Component "core:theme" finished initialization
xdk:server:[2016-04-14T00:48:27.684Z]: (1460594907684): Component "server:userfs" starting import
xdk:server:[2016-04-14T00:48:27.691Z]: (1460594907691): Component "server:userfs" calling init()
xdk:server:[2016-04-14T00:48:27.732Z]: (1460594907732): Component "server:userfs" finished initialization
xdk:server:[2016-04-14T00:48:27.732Z]: (1460594907732): Component "server:user-profile" starting import
xdk:server:[2016-04-14T00:48:27.736Z]: (1460594907736): Component "server:user-profile" calling init()
xdk:server:[2016-04-14T00:48:27.736Z]: (1460594907736): Component "server:user-profile" finished initialization
xdk:server:[2016-04-14T00:48:27.737Z]: (1460594907737): Component "server:ui-builder" starting import
xdk:server:[2016-04-14T00:48:27.794Z]: (1460594907794): Component "server:ui-builder" calling init()
xdk:server:[2016-04-14T00:48:27.796Z]: (1460594907796): Component "server:ui-builder" finished initialization
xdk:server:[2016-04-14T00:48:27.796Z]: (1460594907796): Component "server:emulator-notification" starting import
xdk:server:[2016-04-14T00:48:27.800Z]: (1460594907800): Component "server:emulator-notification" calling init()
xdk:server:[2016-04-14T00:48:27.801Z]: (1460594907801): Component "server:emulator-notification" finished initialization
xdk:server:[2016-04-14T00:48:27.801Z]: (1460594907801): Component "server:emulator-webserver" starting import
xdk:server:[2016-04-14T00:48:27.802Z]: (1460594907802): Component "server:emulator-webserver" calling init()
xdk:server:[2016-04-14T00:48:27.803Z]: (1460594907803): Component "server:emulator-webserver" finished initialization
xdk:server:[2016-04-14T00:48:27.803Z]: (1460594907803): Component "server:zip-util" starting import
xdk:server:[2016-04-14T00:48:27.807Z]: (1460594907807): Component "server:zip-util" calling init()
xdk:server:[2016-04-14T00:48:27.807Z]: (1460594907807): Component "server:zip-util" finished initialization
xdk:server:[2016-04-14T00:48:27.807Z]: (1460594907807): Component "server:uuid-server" starting import
xdk:server:[2016-04-14T00:48:27.810Z]: (1460594907810): Component "server:uuid-server" calling init()
xdk:server:[2016-04-14T00:48:27.811Z]: (1460594907811): Component "server:uuid-server" finished initialization
xdk:server:[2016-04-14T00:48:27.811Z]: (1460594907811): Component "server:force-download" starting import
xdk:server:[2016-04-14T00:48:27.814Z]: (1460594907814): Component "server:force-download" calling init()
xdk:server:[2016-04-14T00:48:27.814Z]: (1460594907814): Component "server:force-download" finished initialization
xdk:server:[2016-04-14T00:48:27.814Z]: (1460594907814): Component "server:updater" starting import
xdk:server:[2016-04-14T00:48:27.819Z]: (1460594907819): Component "server:updater" calling init()
server:updater:[2016-04-14T00:48:27.819Z]: (1460594907819): config.base-auto
server:updater:[2016-04-14T00:48:27.819Z]: (1460594907819): url=auto
xdk:server:[2016-04-14T00:48:27.820Z]: (1460594907820): Component "server:updater" finished initialization
xdk:server:[2016-04-14T00:48:27.820Z]: (1460594907820): Component "server:editor-node" starting import
xdk:server:[2016-04-14T00:48:27.857Z]: (1460594907857): Component "server:editor-node" calling init()
xdk:server:[2016-04-14T00:48:27.858Z]: (1460594907858): Component "server:editor-node" waiting for delayed initialization
xdk:server:[2016-04-14T00:48:27.858Z]: (1460594907858): Component "server:cordova-lib" starting import
xdk:server:[2016-04-14T00:48:28.375Z]: (1460594908375): Component "server:cordova-lib" calling init()
xdk:server:[2016-04-14T00:48:28.573Z]: (1460594908573): Component "server:cordova-lib" finished initialization
xdk:server:[2016-04-14T00:48:28.573Z]: (1460594908573): Component "server:api-explorer" starting import
xdk:server:[2016-04-14T00:48:28.581Z]: (1460594908581): Component "server:api-explorer" calling init()
xdk:server:[2016-04-14T00:48:28.667Z]: (1460594908667): Component "server:api-explorer" finished initialization
xdk:server:[2016-04-14T00:48:28.667Z]: (1460594908667): Component "server:plugin-listener" starting import
xdk:server:[2016-04-14T00:48:28.670Z]: (1460594908670): Component "server:plugin-listener" calling init()
xdk:server:[2016-04-14T00:48:28.670Z]: (1460594908670): Component "server:plugin-listener" finished initialization
xdk:server:[2016-04-14T00:48:28.670Z]: (1460594908670): Component "server:git-runner" starting import
xdk:server:[2016-04-14T00:48:28.674Z]: (1460594908674): Component "server:git-runner" calling init()
xdk:server:[2016-04-14T00:48:28.674Z]: (1460594908674): Component "server:git-runner" finished initialization
server:editor-node:[2016-04-14T00:48:28.676Z]: (1460594908676): Starting Brackets node process "D:\Intel XDK\bin\node.exe" "D:\Intel XDK\bin\node-core"
server:editor-node:[2016-04-14T00:48:28.844Z]: (1460594908844): Brackets node is running on port 59479
xdk:server:[2016-04-14T00:48:28.845Z]: (1460594908845): Component "server:editor-node" finished delayed initialization
xdk:server:[2016-04-14T00:48:28.845Z]: (1460594908845): Component "server:ui-builder" calling start()
xdk:server:[2016-04-14T00:48:28.850Z]: (1460594908850): Component "server:ui-builder" finished start()
xdk:server:[2016-04-14T00:48:28.850Z]: (1460594908850): Component "server:emulator-webserver" calling start()
xdk:server:[2016-04-14T00:48:28.850Z]: (1460594908850): Component "server:emulator-webserver" finished start()
xdk:server:[2016-04-14T00:48:28.850Z]: (1460594908850): Component "server:editor-node" calling start()
xdk:server:[2016-04-14T00:48:28.850Z]: (1460594908850): Component "server:editor-node" finished start()
xdk:server:[2016-04-14T00:48:28.852Z]: (1460594908852): Intel XDK is initialized now
xdk:server:[2016-04-14T00:48:28.852Z]: (1460594908852): Writing to the server data file
xdk:server:[2016-04-14T00:48:28.854Z]: (1460594908854): Wrote server data to "C:\Users\Usuario\AppData\Local\XDK\server-data.txt"
xdk:client:[2016-04-14T00:48:28.895Z]: (1460594908895): Successfully read server data file
xdk:client:[2016-04-14T00:48:29.061Z]: (1460594909061): Component "core:assert" starting import
xdk:client:[2016-04-14T00:48:29.062Z]: (1460594909062): Component "core:assert" finished initialization
xdk:client:[2016-04-14T00:48:29.062Z]: (1460594909062): Component "core:component-error" starting import
xdk:client:[2016-04-14T00:48:29.062Z]: (1460594909062): Component "core:component-error" finished initialization
xdk:client:[2016-04-14T00:48:29.062Z]: (1460594909062): Component "core:command-line-options" starting import
xdk:client:[2016-04-14T00:48:29.062Z]: (1460594909062): Component "core:command-line-options" finished initialization
xdk:client:[2016-04-14T00:48:29.062Z]: (1460594909062): Component "core:service-error" starting import
xdk:client:[2016-04-14T00:48:29.063Z]: (1460594909063): Component "core:service-error" finished initialization
xdk:client:[2016-04-14T00:48:29.063Z]: (1460594909063): Component "core:buffer" starting import
xdk:client:[2016-04-14T00:48:29.063Z]: (1460594909063): Component "core:buffer" finished initialization
xdk:client:[2016-04-14T00:48:29.063Z]: (1460594909063): Component "core:signaler" starting import
xdk:client:[2016-04-14T00:48:29.064Z]: (1460594909064): Component "core:signaler" finished initialization
xdk:client:[2016-04-14T00:48:29.064Z]: (1460594909064): Component "core:signaler-group" starting import
xdk:client:[2016-04-14T00:48:29.066Z]: (1460594909066): Component "core:signaler-group" finished initialization
xdk:client:[2016-04-14T00:48:29.066Z]: (1460594909066): Component "core:logger" starting import
xdk:client:[2016-04-14T00:48:29.067Z]: (1460594909067): Component "core:logger" finished initialization
xdk:client:[2016-04-14T00:48:29.067Z]: (1460594909067): Component "core:http-request" starting import
xdk:client:[2016-04-14T00:48:29.068Z]: (1460594909068): Component "core:http-request" finished initialization
xdk:client:[2016-04-14T00:48:29.068Z]: (1460594909068): Component "core:version" starting import
xdk:client:[2016-04-14T00:48:29.068Z]: (1460594909068): Component "core:version" finished initialization
xdk:client:[2016-04-14T00:48:29.068Z]: (1460594909068): Component "core:exit-notifier" starting import
xdk:client:[2016-04-14T00:48:29.068Z]: (1460594909068): Component "core:exit-notifier" finished initialization
xdk:client:[2016-04-14T00:48:29.068Z]: (1460594909068): Component "core:userfs-name-converter" starting import
xdk:client:[2016-04-14T00:48:29.068Z]: (1460594909068): Component "core:userfs-name-converter" finished initialization
xdk:client:[2016-04-14T00:48:29.069Z]: (1460594909069): Component "core:crash-handler" starting import
xdk:client:[2016-04-14T00:48:29.069Z]: (1460594909069): Component "core:crash-handler" finished initialization
xdk:client:[2016-04-14T00:48:29.069Z]: (1460594909070): Component "core:analytics" starting import
xdk:client:[2016-04-14T00:48:29.070Z]: (1460594909070): Component "core:analytics" finished initialization
xdk:client:[2016-04-14T00:48:29.070Z]: (1460594909070): Component "core:i18n-support" starting import
xdk:client:[2016-04-14T00:48:29.070Z]: (1460594909070): Component "core:i18n-support" finished initialization
xdk:client:[2016-04-14T00:48:29.070Z]: (1460594909070): Component "core:theme" starting import
xdk:client:[2016-04-14T00:48:29.070Z]: (1460594909070): Component "core:theme" finished initialization
xdk:client:[2016-04-14T00:48:29.079Z]: (1460594909079): Analytics ID: 8f0b9b02-7fda-44db-ae35-f01f8384f966
xdk:client:[2016-04-14T00:48:29.080Z]: (1460594909080): onExit listener 0:
at Object.exports.onExit (D:\Intel XDK\xdk\core-modules\public\exit-notifier.js:17:2339)
at setupDefaultAnalytics (D:\Intel XDK\xdk\core-modules\public\analytics.js:17:1438)
at D:\Intel XDK\xdk\core-modules\public\analytics.js:17:6219
at D:\Intel XDK\xdk\node_modules\q\q.js:1229:26
at _fulfilled (D:\Intel XDK\xdk\node_modules\q\q.js:834:54)
at self.promiseDispatch.done (D:\Intel XDK\xdk\node_modules\q\q.js:863:30)
at Promise.promise.promiseDispatch (D:\Intel XDK\xdk\node_modules\q\q.js:796:13)
at D:\Intel XDK\xdk\node_modules\q\q.js:604:44
at runSingle (D:\Intel XDK\xdk\node_modules\q\q.js:137:13)
xdk:client:[2016-04-14T00:48:29.113Z]: (1460594909113): Component "client:app" starting import
xdk:client:[2016-04-14T00:48:29.113Z]: (1460594909113): Component "client:help-helper" starting import
xdk:client:[2016-04-14T00:48:29.113Z]: (1460594909113): Component "client:nativefs" starting import
xdk:client:[2016-04-14T00:48:29.113Z]: (1460594909113): Component "client:document-manager" starting import
xdk:client:[2016-04-14T00:48:29.113Z]: (1460594909113): Component "client:project-manager" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:aa-controller" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:build-validator" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:projects-renderers" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:projects-renderers-jsapp" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:projects-renderers-webapp" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:projects-renderers-iotapp" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:active-sync" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:apk-installer" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:appcenter-options" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-manager" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-cocos2d" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-cocos2djs" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-phaser" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-pixi" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-easeljs" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-plain" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-render-frame" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:resource-util" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:bower-package-manager" starting import
xdk:client:[2016-04-14T00:48:29.114Z]: (1460594909114): Component "client:services-tab" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:editor" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:live-preview" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:backend-services" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:backend-feeds" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:merged-feed" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:backend-services-ext" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:backend-service-utils" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:cert-manager" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:account-settings" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:ui-builder-client" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:project-meta" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:contenttype-registry" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:editor-registry" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:platform-registry" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:projecttype-registry" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:library-registry" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:cordova-registry" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:service-method" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:settings-db" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:adb" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:iosdb" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:device" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:device-discovery" starting import
xdk:client:[2016-04-14T00:48:29.115Z]: (1460594909115): Component "client:dialog-box" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:test-local-server" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:quick-tour" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:hot-keys" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:persistance" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:tabs" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:hash-utils" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:file-watcher" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:tool-tip" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:cordova" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:settings-ui" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:external-links" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:external-editors-runner" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:project-list-load" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:upload-manager" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:git-manager" starting import
xdk:client:[2016-04-14T00:48:29.116Z]: (1460594909116): Component "client:new-project-creator" starting import
xdk:client:[2016-04-14T00:48:29.174Z]: (1460594909174): Component "client:help-helper" finished initialization
xdk:client:[2016-04-14T00:48:29.175Z]: (1460594909175): Component "client:nativefs" finished initialization
xdk:client:[2016-04-14T00:48:29.191Z]: (1460594909191): Component "client:active-sync" calling init()
xdk:client:[2016-04-14T00:48:29.192Z]: (1460594909192): Component "client:active-sync" finished initialization
xdk:client:[2016-04-14T00:48:29.194Z]: (1460594909194): Component "client:apk-installer" calling init()
xdk:client:[2016-04-14T00:48:29.194Z]: (1460594909194): Component "client:apk-installer" finished initialization
xdk:client:[2016-04-14T00:48:29.223Z]: (1460594909223): Component "client:resource-render-frame" calling init()
xdk:client:[2016-04-14T00:48:29.223Z]: (1460594909223): Component "client:resource-render-frame" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.224Z]: (1460594909224): Component "client:resource-util" calling init()
xdk:client:[2016-04-14T00:48:29.224Z]: (1460594909224): Component "client:resource-util" finished initialization
xdk:client:[2016-04-14T00:48:29.231Z]: (1460594909231): Component "client:backend-services" calling init()
xdk:client:[2016-04-14T00:48:29.232Z]: (1460594909232): Component "client:backend-services" finished initialization
xdk:client:[2016-04-14T00:48:29.233Z]: (1460594909233): Component "client:backend-feeds" calling init()
xdk:client:[2016-04-14T00:48:29.233Z]: (1460594909233): Component "client:backend-feeds" finished initialization
xdk:client:[2016-04-14T00:48:29.234Z]: (1460594909234): Component "client:merged-feed" finished initialization
xdk:client:[2016-04-14T00:48:29.235Z]: (1460594909235): Component "client:backend-services-ext" calling init()
xdk:client:[2016-04-14T00:48:29.235Z]: (1460594909235): Component "client:backend-services-ext" finished initialization
xdk:client:[2016-04-14T00:48:29.236Z]: (1460594909236): Component "client:backend-service-utils" finished initialization
xdk:client:[2016-04-14T00:48:29.242Z]: (1460594909242): Component "client:project-meta" calling init()
xdk:client:[2016-04-14T00:48:29.243Z]: (1460594909243): Component "client:project-meta" finished initialization
xdk:client:[2016-04-14T00:48:29.249Z]: (1460594909249): Component "client:service-method" finished initialization
xdk:client:[2016-04-14T00:48:29.251Z]: (1460594909251): Component "client:settings-db" calling init()
xdk:client:[2016-04-14T00:48:29.251Z]: (1460594909251): Component "client:settings-db" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.252Z]: (1460594909252): Component "client:adb" calling init()
xdk:client:[2016-04-14T00:48:29.263Z]: (1460594909263): Component "client:adb" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.264Z]: (1460594909264): Component "client:iosdb" calling init()
xdk:client:[2016-04-14T00:48:29.264Z]: (1460594909264): Component "client:iosdb" finished initialization
xdk:client:[2016-04-14T00:48:29.271Z]: (1460594909271): Component "client:persistance" calling init()
xdk:client:[2016-04-14T00:48:29.271Z]: (1460594909271): Component "client:persistance" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.273Z]: (1460594909273): Component "client:file-watcher" calling init()
xdk:client:[2016-04-14T00:48:29.273Z]: (1460594909273): Component "client:file-watcher" finished initialization
xdk:client:[2016-04-14T00:48:29.277Z]: (1460594909277): Component "client:external-links" finished initialization
xdk:client:[2016-04-14T00:48:29.278Z]: (1460594909278): Component "client:external-editors-runner" calling init()
xdk:client:[2016-04-14T00:48:29.278Z]: (1460594909278): Component "client:external-editors-runner" finished initialization
xdk:client:[2016-04-14T00:48:29.279Z]: (1460594909279): Component "client:project-list-load" calling init()
xdk:client:[2016-04-14T00:48:29.279Z]: (1460594909279): Component "client:project-list-load" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.281Z]: (1460594909281): Component "client:upload-manager" calling init()
xdk:client:[2016-04-14T00:48:29.281Z]: (1460594909281): Component "client:upload-manager" finished initialization
xdk:client:[2016-04-14T00:48:29.282Z]: (1460594909282): Component "client:git-manager" calling init()
client:git-manager:[2016-04-14T00:48:29.283Z]: (1460594909283): git path = D:\Intel XDK\bin\git\bin\git.exe
xdk:client:[2016-04-14T00:48:29.283Z]: (1460594909283): Component "client:git-manager" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.284Z]: (1460594909284): Component "client:new-project-creator" calling init()
xdk:client:[2016-04-14T00:48:29.285Z]: (1460594909285): Component "client:new-project-creator" finished initialization
xdk:client:[2016-04-14T00:48:29.288Z]: (1460594909288): Component "client:resource-render-frame" finished delayed initialization
xdk:client:[2016-04-14T00:48:29.294Z]: (1460594909294): Component "client:build-validator" finished initialization
xdk:client:[2016-04-14T00:48:29.309Z]: (1460594909309): Component "client:tool-tip" finished initialization
xdk:client:[2016-04-14T00:48:29.319Z]: (1460594909319): Component "client:ui-builder-client" calling init()
xdk:client:[2016-04-14T00:48:29.319Z]: (1460594909319): Component "client:ui-builder-client" finished initialization
xdk:client:[2016-04-14T00:48:29.321Z]: (1460594909321): Component "client:dialog-box" finished initialization
xdk:client:[2016-04-14T00:48:29.322Z]: (1460594909322): Component "client:hot-keys" calling init()
xdk:client:[2016-04-14T00:48:29.322Z]: (1460594909323): Component "client:hot-keys" finished initialization
xdk:client:[2016-04-14T00:48:29.327Z]: (1460594909327): Component "client:settings-ui" finished initialization
xdk:client:[2016-04-14T00:48:29.331Z]: (1460594909331): Component "client:document-manager" calling init()
xdk:client:[2016-04-14T00:48:29.332Z]: (1460594909332): Component "client:document-manager" finished initialization
xdk:client:[2016-04-14T00:48:29.351Z]: (1460594909351): Component "client:aa-controller" calling init()
xdk:client:[2016-04-14T00:48:29.351Z]: (1460594909351): Component "client:aa-controller" finished initialization
xdk:client:[2016-04-14T00:48:29.431Z]: (1460594909431): Component "client:contenttype-registry" calling init()
xdk:client:[2016-04-14T00:48:29.432Z]: (1460594909432): Component "client:contenttype-registry" finished initialization
xdk:client:[2016-04-14T00:48:29.433Z]: (1460594909433): Component "client:editor-registry" finished initialization
xdk:client:[2016-04-14T00:48:29.442Z]: (1460594909442): Component "client:library-registry" calling init()
xdk:client:[2016-04-14T00:48:29.442Z]: (1460594909442): Component "client:library-registry" finished initialization
xdk:client:[2016-04-14T00:48:29.450Z]: (1460594909450): Component "client:device-discovery" calling init()
xdk:client:[2016-04-14T00:48:29.451Z]: (1460594909451): Component "client:device-discovery" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.452Z]: (1460594909452): Component "client:hash-utils" finished initialization
xdk:client:[2016-04-14T00:48:29.507Z]: (1460594909507): Component "client:cordova" calling init()
xdk:client:[2016-04-14T00:48:29.507Z]: (1460594909507): Component "client:cordova" waiting for delayed initialization
client:adb:[2016-04-14T00:48:29.533Z]: (1460594909533): Using existing adb at "D:\Intel XDK\bin\adb\adb.exe"
xdk:client:[2016-04-14T00:48:29.546Z]: (1460594909546): Component "client:resource-manager" calling init()
xdk:client:[2016-04-14T00:48:29.547Z]: (1460594909547): Component "client:resource-manager" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.558Z]: (1460594909558): Component "client:resource-cocos2djs" calling init()
xdk:client:[2016-04-14T00:48:29.558Z]: (1460594909558): Component "client:resource-cocos2djs" finished initialization
xdk:client:[2016-04-14T00:48:29.561Z]: (1460594909561): Component "client:resource-phaser" calling init()
xdk:client:[2016-04-14T00:48:29.561Z]: (1460594909561): Component "client:resource-phaser" finished initialization
xdk:client:[2016-04-14T00:48:29.563Z]: (1460594909563): Component "client:resource-pixi" calling init()
xdk:client:[2016-04-14T00:48:29.563Z]: (1460594909563): Component "client:resource-pixi" finished initialization
xdk:client:[2016-04-14T00:48:29.564Z]: (1460594909564): Component "client:resource-easeljs" calling init()
xdk:client:[2016-04-14T00:48:29.564Z]: (1460594909564): Component "client:resource-easeljs" finished initialization
xdk:client:[2016-04-14T00:48:29.565Z]: (1460594909565): Component "client:resource-plain" calling init()
xdk:client:[2016-04-14T00:48:29.565Z]: (1460594909565): Component "client:resource-plain" finished initialization
xdk:client:[2016-04-14T00:48:29.573Z]: (1460594909573): Component "client:cordova-registry" calling init()
xdk:client:[2016-04-14T00:48:29.573Z]: (1460594909573): Component "client:cordova-registry" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.578Z]: (1460594909578): Component "client:appcenter-options" calling init()
xdk:client:[2016-04-14T00:48:29.579Z]: (1460594909579): Component "client:appcenter-options" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.581Z]: (1460594909581): Component "client:services-tab" calling init()
xdk:client:[2016-04-14T00:48:29.582Z]: (1460594909582): Component "client:services-tab" finished initialization
xdk:client:[2016-04-14T00:48:29.583Z]: (1460594909583): Component "client:test-local-server" calling init()
xdk:client:[2016-04-14T00:48:29.610Z]: (1460594909610): Component "client:test-local-server" finished initialization
xdk:client:[2016-04-14T00:48:29.611Z]: (1460594909611): Component "client:tabs" finished initialization
xdk:client:[2016-04-14T00:48:29.622Z]: (1460594909622): Component "client:app" calling init()
xdk:client:[2016-04-14T00:48:29.634Z]: (1460594909634): Component "client:app" finished initialization
xdk:client:[2016-04-14T00:48:29.680Z]: (1460594909680): Component "client:cert-manager" finished initialization
xdk:client:[2016-04-14T00:48:29.687Z]: (1460594909687): Component "client:quick-tour" calling init()
xdk:client:[2016-04-14T00:48:29.687Z]: (1460594909687): Component "client:quick-tour" finished initialization
xdk:client:[2016-04-14T00:48:29.696Z]: (1460594909697): Component "client:project-manager" calling init()
xdk:client:[2016-04-14T00:48:29.697Z]: (1460594909697): Component "client:project-manager" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.702Z]: (1460594909702): Component "client:projects-renderers" calling init()
xdk:client:[2016-04-14T00:48:29.702Z]: (1460594909702): Component "client:projects-renderers" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.703Z]: (1460594909703): Component "client:projects-renderers-iotapp" calling init()
xdk:client:[2016-04-14T00:48:29.703Z]: (1460594909703): Component "client:projects-renderers-iotapp" finished initialization
xdk:client:[2016-04-14T00:48:29.718Z]: (1460594909718): Component "client:resource-cocos2d" calling init()
xdk:client:[2016-04-14T00:48:29.718Z]: (1460594909718): Component "client:resource-cocos2d" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.727Z]: (1460594909727): Component "client:account-settings" calling init()
xdk:client:[2016-04-14T00:48:29.727Z]: (1460594909727): Component "client:account-settings" finished initialization
xdk:client:[2016-04-14T00:48:29.731Z]: (1460594909731): Component "client:platform-registry" calling init()
xdk:client:[2016-04-14T00:48:29.732Z]: (1460594909732): Component "client:platform-registry" finished initialization
xdk:client:[2016-04-14T00:48:29.733Z]: (1460594909733): Component "client:projecttype-registry" calling init()
xdk:client:[2016-04-14T00:48:29.734Z]: (1460594909734): Component "client:projecttype-registry" finished initialization
xdk:client:[2016-04-14T00:48:29.738Z]: (1460594909738): Component "client:device" calling init()
xdk:client:[2016-04-14T00:48:29.807Z]: (1460594909807): Component "client:device" finished initialization
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:navbar" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:tweets" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:projects-tab" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:test-tab" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:profilingTab" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:emulator" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:remote-tab" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:build-tab" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:build-service" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:bower-client" starting import
xdk:client:[2016-04-14T00:48:29.808Z]: (1460594909808): Component "client:editor-tab" starting import
xdk:client:[2016-04-14T00:48:29.809Z]: (1460594909809): Component "client:account" starting import
xdk:client:[2016-04-14T00:48:29.809Z]: (1460594909809): Component "client:project-selector" starting import
xdk:client:[2016-04-14T00:48:29.809Z]: (1460594909809): Component "client:publish-tab" starting import
xdk:client:[2016-04-14T00:48:29.815Z]: (1460594909815): Component "client:device-discovery" finished delayed initialization
xdk:client:[2016-04-14T00:48:29.815Z]: (1460594909815): Component "client:resource-cocos2d" finished delayed initialization
xdk:client:[2016-04-14T00:48:29.817Z]: (1460594909817): Component "client:adb" finished delayed initialization
xdk:client:[2016-04-14T00:48:29.834Z]: (1460594909834): Component "client:bower-package-manager" calling init()
xdk:client:[2016-04-14T00:48:29.835Z]: (1460594909835): Component "client:bower-package-manager" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.852Z]: (1460594909852): Component "client:settings-db" finished delayed initialization
client:git-manager:[2016-04-14T00:48:29.881Z]: (1460594909881): Custom Git Client Path is D:\Intel XDK\bin\git\bin\git.exe
client:git-manager:[2016-04-14T00:48:29.881Z]: (1460594909881): Auto-Proxy setting is true
xdk:client:[2016-04-14T00:48:29.883Z]: (1460594909883): Component "client:bower-package-manager" finished delayed initialization
xdk:client:[2016-04-14T00:48:29.910Z]: (1460594909910): Component "client:editor" calling init()
xdk:client:[2016-04-14T00:48:29.910Z]: (1460594909910): Component "client:editor" finished initialization
xdk:client:[2016-04-14T00:48:29.911Z]: (1460594909911): Component "client:live-preview" calling init()
xdk:client:[2016-04-14T00:48:29.911Z]: (1460594909911): Component "client:live-preview" finished initialization
xdk:client:[2016-04-14T00:48:29.911Z]: (1460594909911): Component "client:editor-tab" getting UI region for "develop"
xdk:client:[2016-04-14T00:48:29.912Z]: (1460594909912): Component "client:editor-tab" calling init()
xdk:client:[2016-04-14T00:48:29.921Z]: (1460594909921): Component "client:editor-tab" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:29.937Z]: (1460594909937): Component "client:projects-renderers-webapp" calling init()
xdk:client:[2016-04-14T00:48:29.938Z]: (1460594909938): Component "client:projects-renderers-webapp" finished initialization
xdk:client:[2016-04-14T00:48:29.943Z]: (1460594909943): Component "client:projects-renderers-jsapp" calling init()
xdk:client:[2016-04-14T00:48:29.943Z]: (1460594909943): Component "client:projects-renderers-jsapp" finished initialization
xdk:client:[2016-04-14T00:48:29.966Z]: (1460594909966): Component "client:build-service" getting UI region for "build"
xdk:client:[2016-04-14T00:48:29.966Z]: (1460594909966): Component "client:build-service" calling init()
xdk:client:[2016-04-14T00:48:29.966Z]: (1460594909966): Component "client:build-service" finished initialization
xdk:client:[2016-04-14T00:48:29.976Z]: (1460594909976): Component "client:projects-renderers" finished delayed initialization
xdk:client:[2016-04-14T00:48:29.983Z]: (1460594909983): Component "client:git-manager" finished delayed initialization
xdk:client:[2016-04-14T00:48:30.027Z]: (1460594910027): Component "client:account" getting UI region for "account"
xdk:client:[2016-04-14T00:48:30.027Z]: (1460594910027): Component "client:account" calling init()
xdk:client:[2016-04-14T00:48:30.032Z]: (1460594910032): Component "client:account" finished initialization
xdk:client:[2016-04-14T00:48:30.034Z]: (1460594910034): Component "client:project-selector" getting UI region for "project-selector"
xdk:client:[2016-04-14T00:48:30.034Z]: (1460594910034): Component "client:project-selector" calling init()
xdk:client:[2016-04-14T00:48:30.034Z]: (1460594910034): Component "client:project-selector" finished initialization
xdk:client:[2016-04-14T00:48:30.039Z]: (1460594910039): Component "client:tweets" finished initialization
xdk:client:[2016-04-14T00:48:30.040Z]: (1460594910040): Component "client:projects-tab" getting UI region for "project"
xdk:client:[2016-04-14T00:48:30.040Z]: (1460594910040): Component "client:projects-tab" calling init()
xdk:client:[2016-04-14T00:48:30.041Z]: (1460594910041): Component "client:projects-tab" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:30.042Z]: (1460594910042): Component "client:test-tab" getting UI region for "test"
xdk:client:[2016-04-14T00:48:30.043Z]: (1460594910043): Component "client:test-tab" calling init()
xdk:client:[2016-04-14T00:48:30.043Z]: (1460594910043): Component "client:test-tab" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:30.053Z]: (1460594910053): Component "client:emulator" getting UI region for "emulate"
xdk:client:[2016-04-14T00:48:30.053Z]: (1460594910053): Component "client:emulator" calling init()
xdk:client:[2016-04-14T00:48:30.056Z]: (1460594910056): Component "client:emulator" finished initialization
xdk:client:[2016-04-14T00:48:30.065Z]: (1460594910065): Component "client:remote-tab" getting UI region for "debug"
xdk:client:[2016-04-14T00:48:30.065Z]: (1460594910065): Component "client:remote-tab" calling init()
xdk:client:[2016-04-14T00:48:30.164Z]: (1460594910164): Component "client:remote-tab" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:30.178Z]: (1460594910178): Component "client:remote-tab" finished delayed initialization
xdk:client:[2016-04-14T00:48:30.183Z]: (1460594910183): Component "client:cordova" finished delayed initialization
xdk:client:[2016-04-14T00:48:30.187Z]: (1460594910187): Component "client:navbar" getting UI region for "navbar-common"
xdk:client:[2016-04-14T00:48:30.187Z]: (1460594910187): Component "client:navbar" calling init()
client:navbar:[2016-04-14T00:48:30.188Z]: (1460594910188): navbar options: {"common":{"servicesVersion":"release-2016-ww11"},"updatePollingInterval":1800,"forceUpdate":false}
xdk:client:[2016-04-14T00:48:30.188Z]: (1460594910188): Component "client:navbar" finished initialization
xdk:client:[2016-04-14T00:48:30.255Z]: (1460594910255): Component "client:build-tab" getting UI region for "build"
xdk:client:[2016-04-14T00:48:30.256Z]: (1460594910256): Component "client:build-tab" calling init()
xdk:client:[2016-04-14T00:48:30.266Z]: (1460594910266): Component "client:build-tab" waiting for delayed initialization
xdk:client:[2016-04-14T00:48:30.281Z]: (1460594910281): Component "client:publish-tab" getting UI region for "publish"
xdk:client:[2016-04-14T00:48:30.281Z]: (1460594910281): Component "client:publish-tab" calling init()
xdk:client:[2016-04-14T00:48:30.288Z]: (1460594910288): Component "client:build-tab" finished delayed initialization
xdk:client:[2016-04-14T00:48:30.290Z]: (1460594910290): Component "client:publish-tab" finished initialization
xdk:client:[2016-04-14T00:48:30.336Z]: (1460594910336): Component "client:bower-client" getting UI region for "deps-manager"
xdk:client:[2016-04-14T00:48:30.336Z]: (1460594910336): Component "client:bower-client" calling init()
xdk:client:[2016-04-14T00:48:30.337Z]: (1460594910337): Component "client:bower-client" finished initialization
xdk:client:[2016-04-14T00:48:30.434Z]: (1460594910434): Component "client:profilingTab" getting UI region for "profile"
xdk:client:[2016-04-14T00:48:30.434Z]: (1460594910434): Component "client:profilingTab" calling init()
xdk:client:[2016-04-14T00:48:30.436Z]: (1460594910436): Component "client:profilingTab" finished initialization
xdk:client:[2016-04-14T00:48:30.506Z]: (1460594910506): memmrk: 34606752 48555136
xdk:server:[2016-04-14T00:48:31.687Z]: (1460594911687): memmrk: 27384636 43419136
xdk:client:[2016-04-14T00:48:31.775Z]: (1460594911775): Component "client:persistance" finished delayed initialization
client:appcenter-options:[2016-04-14T00:48:32.046Z]: (1460594912046): Fetch Status: 1, Message: Feched latest appcenter-options info because network is available.
xdk:client:[2016-04-14T00:48:32.047Z]: (1460594912047): Component "client:appcenter-options" finished delayed initialization
xdk:client:[2016-04-14T00:48:32.050Z]: (1460594912050): Component "client:test-tab" finished delayed initialization
xdk:client:[2016-04-14T00:48:32.069Z]: (1460594912069): Component "client:cordova-registry" finished delayed initialization
xdk:client:[2016-04-14T00:48:32.386Z]: (1460594912386): Component "client:project-manager" finished delayed initialization
client:cordova:[2016-04-14T00:48:32.471Z]: (1460594912471): { xdkProjectStatus: 'all_same',
pluginStatus:
{ 'cordova-plugin-device': 'same',
'cordova-plugin-splashscreen': 'same',
'cordova-plugin-statusbar': 'same' } }
xdk:client:[2016-04-14T00:48:32.475Z]: (1460594912475): Component "client:project-list-load" finished delayed initialization
xdk:client:[2016-04-14T00:48:32.482Z]: (1460594912482): Component "client:resource-manager" finished delayed initialization
xdk:client:[2016-04-14T00:48:32.482Z]: (1460594912482): Component "client:projects-tab" finished delayed initialization
xdk:client:[2016-04-14T00:48:32.482Z]: (1460594912482): Component "client:projects-list" starting import
xdk:client:[2016-04-14T00:48:32.482Z]: (1460594912482): Component "client:projects-info" starting import
xdk:client:[2016-04-14T00:48:32.482Z]: (1460594912482): Component "client:projects-create-list" starting import
xdk:client:[2016-04-14T00:48:32.482Z]: (1460594912482): Component "client:projects-create-info" starting import
xdk:client:[2016-04-14T00:48:33.160Z]: (1460594913160): Component "client:projects-list" getting UI region for "existing-list"
xdk:client:[2016-04-14T00:48:33.161Z]: (1460594913161): Component "client:projects-list" calling init()
xdk:client:[2016-04-14T00:48:33.162Z]: (1460594913162): Component "client:projects-list" finished initialization
xdk:client:[2016-04-14T00:48:33.164Z]: (1460594913164): Component "client:projects-info" getting UI region for "existing-info"
xdk:client:[2016-04-14T00:48:33.164Z]: (1460594913164): Component "client:projects-info" calling init()
xdk:client:[2016-04-14T00:48:33.165Z]: (1460594913165): Component "client:projects-info" finished initialization
xdk:client:[2016-04-14T00:48:33.173Z]: (1460594913173): Component "client:projects-create-info" getting UI region for "create-info"
xdk:client:[2016-04-14T00:48:33.173Z]: (1460594913173): Component "client:projects-create-info" calling init()
xdk:client:[2016-04-14T00:48:33.173Z]: (1460594913173): Component "client:projects-create-info" finished initialization
xdk:client:[2016-04-14T00:48:33.179Z]: (1460594913179): Component "client:projects-create-list" getting UI region for "create-list"
xdk:client:[2016-04-14T00:48:33.179Z]: (1460594913179): Component "client:projects-create-list" calling init()
xdk:client:[2016-04-14T00:48:33.179Z]: (1460594913179): Component "client:projects-create-list" finished initialization
xdk:client:[2016-04-14T00:48:36.148Z]: (1460594916148): memmrk: 44739924 62750336
xdk:server:[2016-04-14T00:48:36.689Z]: (1460594916689): memmrk: 28567296 43419136
xdk:client:[2016-04-14T00:48:39.341Z]: (1460594919341): onExitRequest listener 1:
at Object.exports.onExitRequest (D:\Intel XDK\xdk\core-modules\public\exit-notifier.js:17:2170)
at Object.<anonymous> (file:///D:/Intel%20XDK/xdk/brackets/b/extensions/default/XDK/main.js:459:21)
at Object.context.execCb (file:///D:/Intel%20XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1658:33)
at Object.Module.check (file:///D:/Intel%20XDK/xdk/brackets/b/thirdparty/requirejs/require.js:869:55)
at Object.<anonymous> (file:///D:/Intel%20XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1121:34)
at file:///D:/Intel%20XDK/xdk/brackets/b/thirdparty/requirejs/require.js:132:23
at file:///D:/Intel%20XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1164:21
at each (file:///D:/Intel%20XDK/xdk/brackets/b/thirdparty/requirejs/require.js:57:31)
at Object.Module.emit (file:///D:/Intel%20XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1163:17)
xdk:client:[2016-04-14T00:48:41.146Z]: (1460594921146): memmrk: 56869056 71867136
xdk:server:[2016-04-14T00:48:41.690Z]: (1460594921690): memmrk: 20673188 43419136
client:services-tab:[2016-04-14T00:48:42.322Z]: (1460594922322): component:services-tab : Container provided by brackets :
client:services-tab:[2016-04-14T00:48:42.322Z]: (1460594922322): component:services-tab : mainContainer_ = XDKMiniServices-main
client:services-tab:[2016-04-14T00:48:42.322Z]: (1460594922322): component:services-tab : sidebarContainer = XDKMiniServices-list
client:services-tab:[2016-04-14T00:48:42.322Z]: (1460594922322): component:services-tab : Iframes inserted by services-tab : .
client:services-tab:[2016-04-14T00:48:42.322Z]: (1460594922322): component:services-tab : $mainContainer_ = mini-api-explorer
client:services-tab:[2016-04-14T00:48:42.322Z]: (1460594922322): component:services-tab : $sidebarContainer_ = api-sidebar
xdk:client:[2016-04-14T00:48:42.477Z]: (1460594922477): Component "client:editor-tab" finished delayed initialization
xdk:client:[2016-04-14T00:48:42.479Z]: (1460594922479): Component "client:app" calling start()
xdk:client:[2016-04-14T00:48:42.501Z]: (1460594922501): Component "client:app" finished start()
xdk:client:[2016-04-14T00:48:42.501Z]: (1460594922501): Component "client:navbar" calling start()
xdk:client:[2016-04-14T00:48:42.518Z]: (1460594922518): Component "client:navbar" finished start()
xdk:client:[2016-04-14T00:48:42.518Z]: (1460594922518): Component "client:project-manager" calling start()
xdk:client:[2016-04-14T00:48:42.519Z]: (1460594922519): Component "client:project-manager" finished start()
xdk:client:[2016-04-14T00:48:42.519Z]: (1460594922519): Component "client:aa-controller" calling start()
xdk:client:[2016-04-14T00:48:42.519Z]: (1460594922519): Component "client:aa-controller" finished start()
xdk:client:[2016-04-14T00:48:42.520Z]: (1460594922520): Component "client:projects-tab" calling start()
xdk:client:[2016-04-14T00:48:42.527Z]: (1460594922527): Component "client:projects-tab" finished start()
xdk:client:[2016-04-14T00:48:42.527Z]: (1460594922527): Component "client:projects-list" calling start()
xdk:client:[2016-04-14T00:48:42.530Z]: (1460594922530): Component "client:projects-list" finished start()
xdk:client:[2016-04-14T00:48:42.530Z]: (1460594922530): Component "client:projects-info" calling start()
xdk:client:[2016-04-14T00:48:42.631Z]: (1460594922631): Component "client:projects-info" finished start()
xdk:client:[2016-04-14T00:48:42.631Z]: (1460594922631): Component "client:projects-create-list" calling start()
xdk:client:[2016-04-14T00:48:42.675Z]: (1460594922675): Component "client:projects-create-list" finished start()
xdk:client:[2016-04-14T00:48:42.675Z]: (1460594922675): Component "client:projects-create-info" calling start()
xdk:client:[2016-04-14T00:48:42.682Z]: (1460594922682): Component "client:projects-create-info" finished start()
xdk:client:[2016-04-14T00:48:42.682Z]: (1460594922682): Component "client:test-tab" calling start()
xdk:client:[2016-04-14T00:48:42.686Z]: (1460594922686): Component "client:test-tab" finished start()
xdk:client:[2016-04-14T00:48:42.686Z]: (1460594922686): Component "client:profilingTab" calling start()
xdk:client:[2016-04-14T00:48:42.739Z]: (1460594922739): Component "client:profilingTab" finished start()
xdk:client:[2016-04-14T00:48:42.739Z]: (1460594922739): Component "client:emulator" calling start()
xdk:client:[2016-04-14T00:48:42.740Z]: (1460594922740): Component "client:emulator" finished start()
xdk:client:[2016-04-14T00:48:42.740Z]: (1460594922740): Component "client:remote-tab" calling start()
xdk:client:[2016-04-14T00:48:42.746Z]: (1460594922746): onExitRequest listener 2:
at Object.myExports.start (file:///D:/Intel%20XDK/xdk/components/client/remote-tab/remote-tab.js:20:3484)
at resumeClientInit (D:\Intel XDK\xdk\core-modules\private\main.js:17:12040)
at D:\Intel XDK\xdk\core-modules\private\main.js:17:1734
xdk:client:[2016-04-14T00:48:42.747Z]: (1460594922747): Component "client:remote-tab" finished start()
xdk:client:[2016-04-14T00:48:42.747Z]: (1460594922747): Component "client:build-tab" calling start()
xdk:client:[2016-04-14T00:48:42.750Z]: (1460594922750): Component "client:build-tab" finished start()
xdk:client:[2016-04-14T00:48:42.750Z]: (1460594922750): Component "client:active-sync" calling start()
xdk:client:[2016-04-14T00:48:42.751Z]: (1460594922751): Component "client:active-sync" finished start()
xdk:client:[2016-04-14T00:48:42.751Z]: (1460594922751): Component "client:apk-installer" calling start()
xdk:client:[2016-04-14T00:48:42.751Z]: (1460594922751): Component "client:apk-installer" finished start()
xdk:client:[2016-04-14T00:48:42.751Z]: (1460594922751): Component "client:resource-manager" calling start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-manager" finished start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-cocos2d" calling start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-cocos2d" finished start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-cocos2djs" calling start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-cocos2djs" finished start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-phaser" calling start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-phaser" finished start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-pixi" calling start()
xdk:client:[2016-04-14T00:48:42.752Z]: (1460594922752): Component "client:resource-pixi" finished start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:resource-easeljs" calling start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:resource-easeljs" finished start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:resource-plain" calling start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:resource-plain" finished start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:resource-render-frame" calling start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:resource-render-frame" finished start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:resource-util" calling start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:resource-util" finished start()
xdk:client:[2016-04-14T00:48:42.753Z]: (1460594922753): Component "client:bower-client" calling start()
xdk:client:[2016-04-14T00:48:42.754Z]: (1460594922754): Component "client:bower-client" finished start()
xdk:client:[2016-04-14T00:48:42.754Z]: (1460594922754): Component "client:editor" calling start()
xdk:client:[2016-04-14T00:48:42.754Z]: (1460594922754): Component "client:editor" finished start()
xdk:client:[2016-04-14T00:48:42.754Z]: (1460594922754): Component "client:editor-tab" calling start()
xdk:client:[2016-04-14T00:48:42.787Z]: (1460594922787): Component "client:editor-tab" finished start()
xdk:client:[2016-04-14T00:48:42.787Z]: (1460594922787): Component "client:live-preview" calling start()
xdk:client:[2016-04-14T00:48:42.787Z]: (1460594922787): Component "client:live-preview" finished start()
xdk:client:[2016-04-14T00:48:42.787Z]: (1460594922787): Component "client:account" calling start()
xdk:client:[2016-04-14T00:48:42.788Z]: (1460594922788): Component "client:account" finished start()
xdk:client:[2016-04-14T00:48:42.788Z]: (1460594922788): Component "client:project-selector" calling start()
xdk:client:[2016-04-14T00:48:42.790Z]: (1460594922790): Component "client:project-selector" finished start()
xdk:client:[2016-04-14T00:48:42.790Z]: (1460594922790): Component "client:ui-builder-client" calling start()
xdk:client:[2016-04-14T00:48:42.791Z]: (1460594922791): Component "client:ui-builder-client" finished start()
xdk:client:[2016-04-14T00:48:42.791Z]: (1460594922791): Component "client:project-meta" calling start()
xdk:client:[2016-04-14T00:48:42.792Z]: (1460594922792): Component "client:project-meta" finished start()
xdk:client:[2016-04-14T00:48:42.792Z]: (1460594922792): Component "client:cordova-registry" calling start()
xdk:client:[2016-04-14T00:48:42.792Z]: (1460594922792): Component "client:cordova-registry" finished start()
xdk:client:[2016-04-14T00:48:42.792Z]: (1460594922792): Component "client:adb" calling start()
xdk:client:[2016-04-14T00:48:42.792Z]: (1460594922792): Component "client:adb" finished start()
xdk:client:[2016-04-14T00:48:42.792Z]: (1460594922792): Component "client:iosdb" calling start()
xdk:client:[2016-04-14T00:48:42.794Z]: (1460594922794): Component "client:iosdb" finished start()
xdk:client:[2016-04-14T00:48:42.794Z]: (1460594922794): Component "client:device-discovery" calling start()
xdk:client:[2016-04-14T00:48:42.796Z]: (1460594922796): onExitRequest listener 3:
at Object.start (file:///D:/Intel%20XDK/xdk/components/client/device-discovery/device-discovery.js:17:9195)
xdk:client:[2016-04-14T00:48:42.796Z]: (1460594922796): Component "client:device-discovery" finished start()
xdk:client:[2016-04-14T00:48:42.796Z]: (1460594922796): Component "client:test-local-server" calling start()
xdk:client:[2016-04-14T00:48:42.797Z]: (1460594922797): Component "client:test-local-server" finished start()
xdk:client:[2016-04-14T00:48:42.797Z]: (1460594922797): Component "client:quick-tour" calling start()
xdk:client:[2016-04-14T00:48:42.797Z]: (1460594922797): Component "client:quick-tour" finished start()
xdk:client:[2016-04-14T00:48:42.797Z]: (1460594922797): Component "client:hot-keys" calling start()
xdk:client:[2016-04-14T00:48:42.799Z]: (1460594922799): Component "client:hot-keys" finished start()
xdk:client:[2016-04-14T00:48:42.799Z]: (1460594922799): Component "client:persistance" calling start()
xdk:client:[2016-04-14T00:48:42.800Z]: (1460594922800): onExit listener 4:
at Object.start (file:///D:/Intel%20XDK/xdk/components/client/persistance/persistance.js:17:4613)
xdk:client:[2016-04-14T00:48:42.800Z]: (1460594922800): Component "client:persistance" finished start()
xdk:client:[2016-04-14T00:48:42.800Z]: (1460594922800): Component "client:file-watcher" calling start()
xdk:client:[2016-04-14T00:48:42.801Z]: (1460594922801): Component "client:file-watcher" finished start()
xdk:client:[2016-04-14T00:48:42.801Z]: (1460594922801): Component "client:cordova" calling start()
xdk:client:[2016-04-14T00:48:42.801Z]: (1460594922801): Component "client:cordova" finished start()
xdk:client:[2016-04-14T00:48:42.801Z]: (1460594922801): Component "client:external-editors-runner" calling start()
xdk:client:[2016-04-14T00:48:42.802Z]: (1460594922802): Component "client:external-editors-runner" finished start()
xdk:client:[2016-04-14T00:48:42.802Z]: (1460594922802): Component "client:upload-manager" calling start()
xdk:client:[2016-04-14T00:48:42.802Z]: (1460594922802): Component "client:upload-manager" finished start()
xdk:client:[2016-04-14T00:48:42.802Z]: (1460594922802): Component "client:publish-tab" calling start()
xdk:client:[2016-04-14T00:48:42.805Z]: (1460594922805): onExitRequest listener 5:
at AutofillController.registerForEvents_ (file:///D:/Intel%20XDK/xdk/components/client/publish-tab/autofill-form-controller.js:17:1607)
at new AutofillController (file:///D:/Intel%20XDK/xdk/components/client/publish-tab/autofill-form-controller.js:17:470)
at Object.myExports.start (file:///D:/Intel%20XDK/xdk/components/client/publish-tab/publish-tab.js:17:4918)
xdk:client:[2016-04-14T00:48:42.849Z]: (1460594922849): Component "client:publish-tab" finished start()
xdk:client:[2016-04-14T00:48:42.851Z]: (1460594922851): Intel XDK is initialized now
bower-package-manager:[2016-04-14T00:48:42.896Z]: (1460594922896): Bower packages not found { [Error: An error ocurred while trying to check for the file "C:/Users/Usuario/Documents/TheTower/bower.json".]
code: 22,
message: 'An error ocurred while trying to check for the file "C:/Users/Usuario/Documents/TheTower/bower.json".',
originalMessage: 'NotFound',
originalError: null }
client:build-tab:[2016-04-14T00:48:43.032Z]: (1460594923032): [refreshPage] Unable to generate project hash. { message_: 'Cannot generate app id without user identifiers',
code_: null,
componentName_: null,
stack_: 'Error\n at Object.createXdkAppId (D:\\Intel XDK\\xdk\\core-modules\\private\\service\\http-wrappers.js:17:543)\n at Object.exports.generateProjectHash (file:///D:/Intel%20XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1574)\n at _refreshPage (file:///D:/Intel%20XDK/xdk/components/client/build-tab/build-tab.js:17:6994)\n at Object.start (file:///D:/Intel%20XDK/xdk/components/client/build-tab/build-tab.js:17:3869)\n at resumeClientInit (D:\\Intel XDK\\xdk\\core-modules\\private\\main.js:17:12040)\n at D:\\Intel XDK\\xdk\\core-modules\\private\\main.js:17:1734\n at _fulfilled (D:\\Intel XDK\\xdk\\node_modules\\q\\q.js:834:54)\n at self.promiseDispatch.done (D:\\Intel XDK\\xdk\\node_modules\\q\\q.js:863:30)\n at Promise.promise.promiseDispatch (D:\\Intel XDK\\xdk\\node_modules\\q\\q.js:796:13)\n at D:\\Intel XDK\\xdk\\node_modules\\q\\q.js:604:44',
httpCode_: 400 }
client:build-tab:[2016-04-14T00:48:43.033Z]: (1460594923033): [updatePageStatus] Set Status: PAGE_STATUS_ERROR
xdk:client:[2016-04-14T00:48:43.049Z]: (1460594923049): onExitRequest listener 6:
at file:///D:/Intel%20XDK/xdk/components/client/project-manager/project-manager.js:18:10467
at _fulfilled (file:///D:/Intel%20XDK/xdk/node_modules/q/q.js:834:54)
at self.promiseDispatch.done (file:///D:/Intel%20XDK/xdk/node_modules/q/q.js:863:30)
at Promise.promise.promiseDispatch (file:///D:/Intel%20XDK/xdk/node_modules/q/q.js:796:13)
at file:///D:/Intel%20XDK/xdk/node_modules/q/q.js:604:44
at runSingle (file:///D:/Intel%20XDK/xdk/node_modules/q/q.js:137:13)
at flush (file:///D:/Intel%20XDK/xdk/node_modules/q/q.js:125:13)
at process._tickCallback (node.js:393:11)
builds:[2016-04-14T00:48:43.162Z]: (1460594923163): Error building UI for: certificateId
client:navbar:[2016-04-14T00:48:44.312Z]: (1460594924313): pollForUpdates called
client:build-tab:[2016-04-14T00:48:44.316Z]: (1460594924316): [refreshPage] projectId PzLOkvhfLv2VzYrK7IzFT0UxW8x_fO0uAvSFsozb0yA
client:build-tab:[2016-04-14T00:48:44.316Z]: (1460594924316): [updatePageState] Set State: PAGE_STATE_LOADING
client:build-tab:[2016-04-14T00:48:44.318Z]: (1460594924318): [getBuildTargets] Getting available targets for project PzLOkvhfLv2VzYrK7IzFT0UxW8x_fO0uAvSFsozb0yA
client:build-tab:[2016-04-14T00:48:44.319Z]: (1460594924319): [refreshProjectInfo] Getting project info.
client:build-tab:[2016-04-14T00:48:44.320Z]: (1460594924320): [refreshBuildAssetsDate] Getting latest upload date for project files
client:build-tab:[2016-04-14T00:48:44.700Z]: (1460594924700): [getBuildTargets] Targets retrieved for project PzLOkvhfLv2VzYrK7IzFT0UxW8x_fO0uAvSFsozb0yA
client:build-tab:[2016-04-14T00:48:44.739Z]: (1460594924739): [updatePageStatus] Set Status: PAGE_STATUS_READY
client:build-tab:[2016-04-14T00:48:44.739Z]: (1460594924739): [updatePageState] Set State: PAGE_STATE_IDLE
client:build-tab:[2016-04-14T00:48:44.748Z]: (1460594924748): [startUpdateStatusProcess] Starting build pulling process. Project: PzLOkvhfLv2VzYrK7IzFT0UxW8x_fO0uAvSFsozb0yA
client:build-tab:[2016-04-14T00:48:44.748Z]: (1460594924748): [updatePageState] Set State: PAGE_STATE_UPDATING
client:build-service:[2016-04-14T00:48:44.750Z]: (1460594924750): [startUpdateStatusProcess] Starting polling. Project: PzLOkvhfLv2VzYrK7IzFT0UxW8x_fO0uAvSFsozb0yA
client:publish-tab:[2016-04-14T00:48:45.410Z]: (1460594925410): Stores data feed has been successfully loaded.
xdk:client:[2016-04-14T00:48:46.147Z]: (1460594926147): memmrk: 52901860 79968256
xdk:server:[2016-04-14T00:48:46.691Z]: (1460594926691): memmrk: 21818604 29832704
client:navbar:[2016-04-14T00:48:46.771Z]: (1460594926771): polling up-to-date
client:build-service:[2016-04-14T00:48:49.118Z]: (1460594929118): [startUpdateStatusProcess] Polling process has finished.
client:build-tab:[2016-04-14T00:48:49.119Z]: (1460594929119): [updatePageState] Set State: PAGE_BUILDING
client:build-tab:[2016-04-14T00:48:49.125Z]: (1460594929125): [updatePageStatus] Set Status: PAGE_STATUS_READY
client:build-tab:[2016-04-14T00:48:49.125Z]: (1460594929125): [updatePageState] Set State: PAGE_STATE_IDLE
client:build-tab:[2016-04-14T00:48:49.413Z]: (1460594929413): [refreshBuildAssetsDate] latest upload date Sat Apr 02 2016 22:17:12 GMT-0300 (Hora estándar de Argentina)
xdk:client:[2016-04-14T00:48:51.165Z]: (1460594931165): memmrk: 61110528 84494080
client:services-tab:[2016-04-14T00:48:51.369Z]: (1460594931369): Iframe onLoad resolved for : http://127.0.0.1:58889/http-services/api-explorer/iodocs/sidebar?
client:services-tab:[2016-04-14T00:48:51.594Z]: (1460594931594): Iframe onLoad resolved for : http://127.0.0.1:58889/http-services/api-explorer/iodocs/index?
client:services-tab:[2016-04-14T00:48:51.598Z]: (1460594931598): Both iframes loaded promise resolved.
client:services-tab:[2016-04-14T00:48:51.620Z]: (1460594931620): Calling postmessage for user refresh.
client:services-tab:[2016-04-14T00:48:51.621Z]: (1460594931621): main container window : true
client:services-tab:[2016-04-14T00:48:51.621Z]: (1460594931621): main container document : true
client:services-tab:[2016-04-14T00:48:51.621Z]: (1460594931621): component:services-tab:postMessageToWindow target = user
xdk:server:[2016-04-14T00:48:51.691Z]: (1460594931691): memmrk: 65924232 80968448
xdk:client:[2016-04-14T00:48:56.167Z]: (1460594936167): memmrk: 65659568 87528960
xdk:server:[2016-04-14T00:48:56.692Z]: (1460594936692): memmrk: 66432200 80968448
xdk:client:[2016-04-14T00:49:01.167Z]: (1460594941167): memmrk: 65834520 87528960
xdk:server:[2016-04-14T00:49:01.692Z]: (1460594941692): memmrk: 66441856 80968448
xdk:client:[2016-04-14T00:49:06.168Z]: (1460594946168): memmrk: 65943872 87528960
xdk:server:[2016-04-14T00:49:06.692Z]: (1460594946692): memmrk: 26121688 63732736
xdk:client:[2016-04-14T00:49:11.168Z]: (1460594951168): memmrk: 66114312 87528960
xdk:server:[2016-04-14T00:49:11.693Z]: (1460594951693): memmrk: 26134776 63732736
xdk:server:[2016-04-14T00:49:16.693Z]: (1460594956693): memmrk: 22626948 34911104
xdk:client:[2016-04-14T00:49:17.146Z]: (1460594957146): memmrk: 50587320 66794880
xdk:server:[2016-04-14T00:49:21.694Z]: (1460594961694): memmrk: 20617756 34911104
xdk:client:[2016-04-14T00:49:22.145Z]: (1460594962145): memmrk: 43929536 58242816
xdk:server:[2016-04-14T00:49:26.695Z]: (1460594966695): memmrk: 20627784 34911104
xdk:client:[2016-04-14T00:49:27.148Z]: (1460594967148): memmrk: 42511592 56223616
xdk:server:[2016-04-14T00:49:31.695Z]: (1460594971695): memmrk: 20634868 34911104
xdk:client:[2016-04-14T00:49:32.148Z]: (1460594972148): memmrk: 42256032 55220096
xdk:server:[2016-04-14T00:49:36.695Z]: (1460594976695): memmrk: 20641936 34911104
xdk:client:[2016-04-14T00:49:37.147Z]: (1460594977147): memmrk: 42527184 54237312
xdk:server:[2016-04-14T00:49:41.695Z]: (1460594981695): memmrk: 20650220 34911104
xdk:client:[2016-04-14T00:49:42.147Z]: (1460594982147): memmrk: 41296816 54237312
xdk:server:[2016-04-14T00:49:46.696Z]: (1460594986696): memmrk: 20657288 34911104
xdk:client:[2016-04-14T00:49:47.147Z]: (1460594987147): memmrk: 41468824 54237312
xdk:server:[2016-04-14T00:49:51.696Z]: (1460594991696): memmrk: 20664372 34911104
xdk:client:[2016-04-14T00:49:52.147Z]: (1460594992147): memmrk: 41578004 54237312
xdk:server:[2016-04-14T00:49:56.697Z]: (1460594996697): memmrk: 20671440 34911104
xdk:client:[2016-04-14T00:49:57.147Z]: (1460594997147): memmrk: 41742972 54237312
xdk:server:[2016-04-14T00:50:01.696Z]: (1460595001696): memmrk: 20678508 34911104
xdk:client:[2016-04-14T00:50:02.146Z]: (1460595002146): memmrk: 41848404 54237312
xdk:server:[2016-04-14T00:50:06.697Z]: (1460595006697): memmrk: 20685592 34911104
xdk:client:[2016-04-14T00:50:07.146Z]: (1460595007146): memmrk: 42043280 54237312
xdk:server:[2016-04-14T00:50:11.697Z]: (1460595011697): memmrk: 20692656 34911104
xdk:client:[2016-04-14T00:50:12.147Z]: (1460595012147): memmrk: 42232132 54237312
xdk:server:[2016-04-14T00:50:16.697Z]: (1460595016697): memmrk: 20699724 34911104
xdk:client:[2016-04-14T00:50:17.146Z]: (1460595017146): memmrk: 41655992 54237312
xdk:server:[2016-04-14T00:50:21.698Z]: (1460595021698): memmrk: 20706792 34911104
xdk:client:[2016-04-14T00:50:22.147Z]: (1460595022147): memmrk: 41760912 54237312
xdk:server:[2016-04-14T00:50:26.697Z]: (1460595026697): memmrk: 20713860 34911104
xdk:client:[2016-04-14T00:50:27.147Z]: (1460595027147): memmrk: 41919840 54237312
xdk:server:[2016-04-14T00:50:31.698Z]: (1460595031698): memmrk: 20723516 34911104
xdk:client:[2016-04-14T00:50:32.146Z]: (1460595032146): memmrk: 42026024 54237312
xdk:server:[2016-04-14T00:50:36.699Z]: (1460595036699): memmrk: 20730568 34911104
xdk:client:[2016-04-14T00:50:37.146Z]: (1460595037146): memmrk: 42298548 54237312
xdk:server:[2016-04-14T00:50:41.699Z]: (1460595041699): memmrk: 20737636 34911104
xdk:client:[2016-04-14T00:50:42.147Z]: (1460595042147): memmrk: 42467964 54237312
xdk:server:[2016-04-14T00:50:46.700Z]: (1460595046700): memmrk: 20744688 34911104
xdk:client:[2016-04-14T00:50:47.147Z]: (1460595047147): memmrk: 42479000 55240832
xdk:server:[2016-04-14T00:50:51.701Z]: (1460595051701): memmrk: 20751756 34911104
xdk:client:[2016-04-14T00:50:52.148Z]: (1460595052148): memmrk: 43076112 55240832
xdk:server:[2016-04-14T00:50:56.701Z]: (1460595056701): memmrk: 20759952 34911104
xdk:client:[2016-04-14T00:50:57.148Z]: (1460595057148): memmrk: 43254328 55240832
xdk:server:[2016-04-14T00:51:01.701Z]: (1460595061701): memmrk: 20768184 34911104
xdk:client:[2016-04-14T00:51:02.150Z]: (1460595062150): memmrk: 43359112 55240832
xdk:server:[2016-04-14T00:51:06.701Z]: (1460595066701): memmrk: 20778336 34911104
xdk:client:[2016-04-14T00:51:07.150Z]: (1460595067150): memmrk: 43515756 55240832
xdk:server:[2016-04-14T00:51:11.702Z]: (1460595071702): memmrk: 20785404 34911104
xdk:client:[2016-04-14T00:51:12.151Z]: (1460595072151): memmrk: 42974660 58353664
xdk:server:[2016-04-14T00:51:16.701Z]: (1460595076701): memmrk: 20792472 34911104
xdk:client:[2016-04-14T00:51:17.152Z]: (1460595077152): memmrk: 43128868 58353664
xdk:server:[2016-04-14T00:51:21.702Z]: (1460595081702): memmrk: 20799524 34911104
xdk:client:[2016-04-14T00:51:22.153Z]: (1460595082153): memmrk: 43232468 58353664
xdk:server:[2016-04-14T00:51:26.701Z]: (1460595086702): memmrk: 20812656 34911104
xdk:client:[2016-04-14T00:51:27.154Z]: (1460595087154): memmrk: 43386656 58353664
xdk:server:[2016-04-14T00:51:31.702Z]: (1460595091702): memmrk: 20832540 34911104
xdk:client:[2016-04-14T00:51:32.155Z]: (1460595092155): memmrk: 43490256 58353664
xdk:server:[2016-04-14T00:51:36.702Z]: (1460595096702): memmrk: 20840820 34911104
xdk:client:[2016-04-14T00:51:37.155Z]: (1460595097155): memmrk: 43654296 58353664
xdk:server:[2016-04-14T00:51:41.702Z]: (1460595101702): memmrk: 20851096 34911104
xdk:client:[2016-04-14T00:51:42.156Z]: (1460595102156): memmrk: 43757880 58353664
xdk:server:[2016-04-14T00:51:46.702Z]: (1460595106702): memmrk: 20859108 34911104
xdk:client:[2016-04-14T00:51:47.157Z]: (1460595107157): memmrk: 43912092 58353664
xdk:server:[2016-04-14T00:51:51.703Z]: (1460595111704): memmrk: 20866144 34911104
xdk:client:[2016-04-14T00:51:52.158Z]: (1460595112158): memmrk: 44016668 58353664
xdk:server:[2016-04-14T00:51:56.704Z]: (1460595116704): memmrk: 20885088 34911104
xdk:client:[2016-04-14T00:51:57.158Z]: (1460595117158): memmrk: 44187572 58353664
xdk:server:[2016-04-14T00:52:01.704Z]: (1460595121704): memmrk: 20893980 34911104
xdk:client:[2016-04-14T00:52:02.158Z]: (1460595122158): memmrk: 44291156 58353664
xdk:server:[2016-04-14T00:52:06.705Z]: (1460595126705): memmrk: 20901016 34911104
xdk:client:[2016-04-14T00:52:07.159Z]: (1460595127159): memmrk: 44445344 58353664
xdk:server:[2016-04-14T00:52:11.705Z]: (1460595131705): memmrk: 20908068 34911104
xdk:client:[2016-04-14T00:52:12.159Z]: (1460595132159): memmrk: 44551472 58353664
xdk:server:[2016-04-14T00:52:16.705Z]: (1460595136705): memmrk: 20915088 34911104
xdk:client:[2016-04-14T00:52:17.161Z]: (1460595137161): memmrk: 44705644 58353664
xdk:server:[2016-04-14T00:52:21.705Z]: (1460595141705): memmrk: 20922108 34911104
xdk:client:[2016-04-14T00:52:22.162Z]: (1460595142162): memmrk: 44809244 58353664
xdk:server:[2016-04-14T00:52:26.706Z]: (1460595146706): memmrk: 20929128 34911104
xdk:client:[2016-04-14T00:52:27.162Z]: (1460595147162): memmrk: 44963432 58353664
xdk:server:[2016-04-14T00:52:31.707Z]: (1460595151707): memmrk: 20936164 34911104
xdk:client:[2016-04-14T00:52:32.162Z]: (1460595152162): memmrk: 45068624 58353664
xdk:server:[2016-04-14T00:52:36.707Z]: (1460595156707): memmrk: 20943200 34911104
xdk:client:[2016-04-14T00:52:37.163Z]: (1460595157163): memmrk: 45086872 58353664
xdk:server:[2016-04-14T00:52:41.707Z]: (1460595161707): memmrk: 20950220 34911104
xdk:client:[2016-04-14T00:52:42.163Z]: (1460595162163): memmrk: 45224584 58353664
xdk:server:[2016-04-14T00:52:46.708Z]: (1460595166708): memmrk: 20957240 34911104
xdk:client:[2016-04-14T00:52:47.164Z]: (1460595167164): memmrk: 45381700 58353664
xdk:server:[2016-04-14T00:52:51.709Z]: (1460595171709): memmrk: 20963352 34911104
xdk:client:[2016-04-14T00:52:52.164Z]: (1460595172164): memmrk: 43283532 58353664
xdk:server:[2016-04-14T00:52:56.709Z]: (1460595176709): memmrk: 20970388 34911104
xdk:client:[2016-04-14T00:52:57.165Z]: (1460595177165): memmrk: 43479528 58353664
xdk:server:[2016-04-14T00:53:01.709Z]: (1460595181709): memmrk: 20977408 34911104
xdk:client:[2016-04-14T00:53:02.165Z]: (1460595182165): memmrk: 43594092 58353664
xdk:server:[2016-04-14T00:53:06.709Z]: (1460595186709): memmrk: 20984444 34911104
xdk:client:[2016-04-14T00:53:07.165Z]: (1460595187165): memmrk: 43079784 52173056
xdk:server:[2016-04-14T00:53:11.709Z]: (1460595191710): memmrk: 20991480 34911104
xdk:client:[2016-04-14T00:53:12.166Z]: (1460595192166): memmrk: 43187712 52173056
xdk:server:[2016-04-14T00:53:16.709Z]: (1460595196709): memmrk: 20998500 34911104
xdk:client:[2016-04-14T00:53:17.167Z]: (1460595197167): memmrk: 43347352 52173056
xdk:server:[2016-04-14T00:53:21.709Z]: (1460595201709): memmrk: 21008296 34911104
xdk:client:[2016-04-14T00:53:22.167Z]: (1460595202167): memmrk: 42939980 52173056
xdk:server:[2016-04-14T00:53:26.709Z]: (1460595206709): memmrk: 21015316 34911104
xdk:client:[2016-04-14T00:53:27.167Z]: (1460595207167): memmrk: 43133136 52173056
xdk:server:[2016-04-14T00:53:31.709Z]: (1460595211709): memmrk: 21024572 34911104
xdk:client:[2016-04-14T00:53:32.167Z]: (1460595212167): memmrk: 42474300 52173056
xdk:server:[2016-04-14T00:53:36.710Z]: (1460595216710): memmrk: 21031592 34911104
xdk:client:[2016-04-14T00:53:37.168Z]: (1460595217168): memmrk: 42719472 52173056
xdk:server:[2016-04-14T00:53:41.710Z]: (1460595221710): memmrk: 21038628 34911104
xdk:client:[2016-04-14T00:53:42.168Z]: (1460595222168): memmrk: 42828112 52173056
xdk:server:[2016-04-14T00:53:46.710Z]: (1460595226710): memmrk: 21045648 34911104
xdk:client:[2016-04-14T00:53:47.169Z]: (1460595227169): memmrk: 42648608 52173056
xdk:server:[2016-04-14T00:53:51.710Z]: (1460595231710): memmrk: 21052668 34911104
xdk:client:[2016-04-14T00:53:52.169Z]: (1460595232169): memmrk: 42724904 53221632
xdk:server:[2016-04-14T00:53:56.711Z]: (1460595236711): memmrk: 21059688 34911104
xdk:client:[2016-04-14T00:53:57.170Z]: (1460595237170): memmrk: 41432016 53221632
xdk:server:[2016-04-14T00:54:01.711Z]: (1460595241711): memmrk: 21153468 34911104
xdk:client:[2016-04-14T00:54:02.170Z]: (1460595242170): memmrk: 41630052 53221632
xdk:server:[2016-04-14T00:54:06.711Z]: (1460595246711): memmrk: 21161856 34911104
xdk:client:[2016-04-14T00:54:07.170Z]: (1460595247170): memmrk: 41785316 53221632
xdk:server:[2016-04-14T00:54:11.712Z]: (1460595251712): memmrk: 21168892 34911104
xdk:client:[2016-04-14T00:54:12.171Z]: (1460595252171): memmrk: 41888804 53221632
xdk:server:[2016-04-14T00:54:16.711Z]: (1460595256711): memmrk: 21175928 34911104
xdk:client:[2016-04-14T00:54:17.172Z]: (1460595257172): memmrk: 42043540 53221632
xdk:server:[2016-04-14T00:54:21.712Z]: (1460595261712): memmrk: 21182948 34911104
xdk:client:[2016-04-14T00:54:22.172Z]: (1460595262172): memmrk: 42148416 53221632
xdk:server:[2016-04-14T00:54:26.712Z]: (1460595266712): memmrk: 21189968 34911104
xdk:client:[2016-04-14T00:54:27.173Z]: (1460595267173): memmrk: 42306932 53221632
xdk:server:[2016-04-14T00:54:31.712Z]: (1460595271712): memmrk: 21201192 34911104
xdk:client:[2016-04-14T00:54:32.174Z]: (1460595272174): memmrk: 42414264 53221632
xdk:server:[2016-04-14T00:54:36.713Z]: (1460595276713): memmrk: 21208212 34911104
xdk:client:[2016-04-14T00:54:37.174Z]: (1460595277174): memmrk: 42578552 53221632
xdk:server:[2016-04-14T00:54:41.713Z]: (1460595281713): memmrk: 21233728 34911104
xdk:client:[2016-04-14T00:54:42.174Z]: (1460595282174): memmrk: 41947564 53221632
xdk:server:[2016-04-14T00:54:46.713Z]: (1460595286713): memmrk: 21254612 34911104
xdk:client:[2016-04-14T00:54:47.175Z]: (1460595287175): memmrk: 42101464 53221632
xdk:server:[2016-04-14T00:54:51.713Z]: (1460595291713): memmrk: 21263624 34911104
xdk:client:[2016-04-14T00:54:52.175Z]: (1460595292175): memmrk: 42208872 53221632
xdk:server:[2016-04-14T00:54:56.714Z]: (1460595296714): memmrk: 21279052 34911104
xdk:client:[2016-04-14T00:54:57.175Z]: (1460595297175): memmrk: 42362772 53221632
xdk:server:[2016-04-14T00:55:01.714Z]: (1460595301714): memmrk: 21287012 34911104
xdk:client:[2016-04-14T00:55:02.176Z]: (1460595302176): memmrk: 42466696 53221632
xdk:server:[2016-04-14T00:55:06.714Z]: (1460595306714): memmrk: 21314160 34911104
xdk:client:[2016-04-14T00:55:07.178Z]: (1460595307178): memmrk: 42623072 53221632
xdk:server:[2016-04-14T00:55:11.714Z]: (1460595311714): memmrk: 21321012 34911104
xdk:client:[2016-04-14T00:55:12.179Z]: (1460595312179): memmrk: 42743360 53221632
xdk:server:[2016-04-14T00:55:16.714Z]: (1460595316714): memmrk: 21331408 34911104
xdk:client:[2016-04-14T00:55:17.179Z]: (1460595317179): memmrk: 42348568 55318784
xdk:server:[2016-04-14T00:55:21.715Z]: (1460595321715): memmrk: 21338244 34911104
xdk:client:[2016-04-14T00:55:22.180Z]: (1460595322180): memmrk: 42469116 55318784
xdk:server:[2016-04-14T00:55:26.715Z]: (1460595326715): memmrk: 21345096 34911104
xdk:client:[2016-04-14T00:55:27.180Z]: (1460595327180): memmrk: 42630476 55318784
xdk:server:[2016-04-14T00:55:31.715Z]: (1460595331715): memmrk: 21351932 34911104
xdk:client:[2016-04-14T00:55:32.180Z]: (1460595332180): memmrk: 42733868 55318784
xdk:server:[2016-04-14T00:55:36.715Z]: (1460595336715): memmrk: 21358768 34911104
xdk:client:[2016-04-14T00:55:37.182Z]: (1460595337182): memmrk: 42887752 55318784
xdk:server:[2016-04-14T00:55:41.715Z]: (1460595341715): memmrk: 21365604 34911104
xdk:client:[2016-04-14T00:55:42.181Z]: (1460595342181): memmrk: 42991160 55318784
xdk:server:[2016-04-14T00:55:46.715Z]: (1460595346715): memmrk: 21372440 34911104
xdk:client:[2016-04-14T00:55:47.182Z]: (1460595347182): memmrk: 43145060 55318784
xdk:server:[2016-04-14T00:55:51.716Z]: (1460595351716): memmrk: 21379276 34911104
xdk:client:[2016-04-14T00:55:52.183Z]: (1460595352183): memmrk: 43602304 55318784
xdk:server:[2016-04-14T00:55:56.716Z]: (1460595356716): memmrk: 21386128 34911104
xdk:client:[2016-04-14T00:55:57.184Z]: (1460595357184): memmrk: 43959800 56322304
xdk:server:[2016-04-14T00:56:01.716Z]: (1460595361716): memmrk: 21392964 34911104
xdk:client:[2016-04-14T00:56:02.185Z]: (1460595362185): memmrk: 44251460 56322304
xdk:server:[2016-04-14T00:56:06.717Z]: (1460595366717): memmrk: 21401396 34911104
xdk:client:[2016-04-14T00:56:07.186Z]: (1460595367186): memmrk: 45304124 56322304
xdk:server:[2016-04-14T00:56:11.717Z]: (1460595371717): memmrk: 21410452 34911104
xdk:client:[2016-04-14T00:56:12.186Z]: (1460595372186): memmrk: 44076604 57337984
xdk:server:[2016-04-14T00:56:16.717Z]: (1460595376717): memmrk: 21417288 34911104
xdk:client:[2016-04-14T00:56:17.188Z]: (1460595377188): memmrk: 44230508 57337984
xdk:server:[2016-04-14T00:56:21.717Z]: (1460595381717): memmrk: 21424124 34911104
xdk:client:[2016-04-14T00:56:22.188Z]: (1460595382188): memmrk: 44333916 57337984
xdk:server:[2016-04-14T00:56:26.718Z]: (1460595386718): memmrk: 21894672 34911104
xdk:client:[2016-04-14T00:56:27.192Z]: (1460595387192): memmrk: 45733084 57337984
client:build-tab:[2016-04-14T00:56:27.370Z]: (1460595387370): [updatePageState] Set State: PAGE_STATE_PREPARING
client:build-tab:[2016-04-14T00:56:27.371Z]: (1460595387371): [uploadBuildAssets] Uploading project files
xdk:server:[2016-04-14T00:56:31.719Z]: (1460595391719): memmrk: 35538384 51556736
xdk:client:[2016-04-14T00:56:32.194Z]: (1460595392194): memmrk: 44114256 62547968
xdk:server:[2016-04-14T00:56:36.721Z]: (1460595396721): memmrk: 43936184 58666496
xdk:client:[2016-04-14T00:56:37.194Z]: (1460595397194): memmrk: 44272680 62547968
xdk:server:[2016-04-14T00:56:41.736Z]: (1460595401736): memmrk: 28575768 59682176
xdk:client:[2016-04-14T00:56:42.195Z]: (1460595402195): memmrk: 48550372 63551488
client:build-tab:[2016-04-14T00:56:42.431Z]: (1460595402431): [updatePageState] Set State: PAGE_UPLOADING_PROJECT
xdk:server:[2016-04-14T00:56:46.737Z]: (1460595406737): memmrk: 37012244 59682176
xdk:client:[2016-04-14T00:56:48.120Z]: (1460595408120): memmrk: 42948356 68905216
Node Webkit Error log:
[37272:0413/214825:INFO:CONSOLE(17)] ""xdk:client:[2016-04-14T00:48:25.785Z]: (1460594905785): Failed to load theme: xdk" {"code":"MODULE_NOT_FOUND"}", source: D:\Intel XDK\xdk\core-modules\private\logger.js (17)
[37272:0413/214842:INFO:CONSOLE(212)] ""NW proxy string: DIRECT"", source: /brackets.js (212)
[37272:0413/214843:INFO:CONSOLE(17)] ""client:build-tab:[2016-04-14T00:48:43.032Z]: (1460594923032): [refreshPage] Unable to generate project hash." {"message_":"Cannot generate app id without user identifiers","code_":null,"componentName_":null,"stack_":"Error\n at Object.createXdkAppId (D:\\Intel XDK\\xdk\\core-modules\\private\\service\\http-wrappers.js:17:543)\n at Object.exports.generateProjectHash (file:///D:/Intel%20XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1574)\n at _refreshPage (file:///D:/Intel%20XDK/xdk/components/client/build-tab/build-tab.js:17:6994)\n at Object.start (file:///D:/Intel%20XDK/xdk/components/client/build-tab/build-tab.js:17:3869)\n at resumeClientInit (D:\\Intel XDK\\xdk\\core-modules\\private\\main.js:17:12040)\n at D:\\Intel XDK\\xdk\\core-modules\\private\\main.js:17:1734\n at _fulfilled (D:\\Intel XDK\\xdk\\node_modules\\q\\q.js:834:54)\n at self.promiseDispatch.done (D:\\Intel XDK\\xdk\\node_modules\\q\\q.js:863:30)\n at Promise.promise.promiseDispatch (D:\\Intel XDK\\xdk\\node_modules\\q\\q.js:796:13)\n at D:\\Intel XDK\\xdk\\node_modules\\q\\q.js:604:44","httpCode_":400}", source: D:\Intel XDK\xdk\core-modules\private\logger.js (17)
[37272:0413/214843:INFO:CONSOLE(17)] ""builds:[2016-04-14T00:48:43.162Z]: (1460594923163): Error building UI for: certificateId"", source: D:\Intel XDK\xdk\core-modules\private\logger.js (17)
[37272:0413/215642:INFO:CONSOLE(0)] "Refused to set unsafe header "Content-Length"", source: file:///D:/Intel%20XDK/xdk/public/index-node-webkit.html (0)
[37272:0413/215647:INFO:CONSOLE(0)] "Refused to set unsafe header "Content-Length"", source: file:///D:/Intel%20XDK/xdk/public/index-node-webkit.html (0)
[37272:0413/215648:ERROR:ipc_channel_reader.cc(65)] IPC message is too big
[37272:0413/215648:INFO:dispatcher_host.cc(157)] [NW.JS]RenderProcessGone
XDK exit code & signal: 258, null
Crash minidump not found in XDK data folder. Falling back to TEMP...
Crash minidump NOT FOUND.
NW Crash Detected.
- Tags:
- HTML5
- Intel® XDK
It might be possible the resources your using in the app might be too large. Like an image which might be too large. Remove such resources and build it again.
Guillermo -- how big is your project folder and all the folders and files contained within? Can you build one of the sample apps? Is your problem limited to this project or do all apps (including the sample apps) cause the XDK to crash?
