Software Archive
Read-only legacy content
17060 Discussions
Yocto, How to install packages: python-serial python-pyparsing python-numpy python-wxgtk2.8
Ilya_K_2
Good day.
In debian i can to run:
sudo apt-get install python-opencv python-serial python-pyparsing python-numpy python-wxgtk2.8
How to do it on yocto?
1) build from source it all with building from source all dependencies?
2) is a good solution - install apt-get on yocto?
3) Maybe, i can to use opkg for installing it, (but in "opkg list" i can't see, for example, python-wxgtk2.8 ) ?
Thank you!
Brendan_L_Intel
pyserial & numpy are available in the repo here: http://iotdk.intel.com/repos/1.1/iotdk/i586/
We don't build all packages but you can certainly either rebuild from sources, rebuild yocto pacakges based on meta-intel-iot-devkit by adding them or simply using easy_install.
Matthias_H_Intel
in order to use the repo on http://iotdk.intel.com/repos/1.1/iotdk/i586/ you would need to create a file in "/etc/opkg" folder (e.g. /etc/opkg/iot-devkit.config") with the repo sources as entry, i.e. something like
cat > /etc/opkg/iot-devkit.config <<EOF
src iot-devkit http://iotdk.intel.com/repos/1.1/iotdk/
EOF
afterwards you need to call
opkg update
with that you can "opkg search" for or "opkg install" packages likewise you're used to with "apt-get" (or yum or zypper or ...)
Ilya_K_2
mattias-hahn, thank you but:
root@clanton:~# cat > /etc/opkg/iot-devkit.config <<EOF
> EOF
root@clanton:~# opkg update
Downloading http://repo.opkg.net/galileo/repo/clanton/Packages.gz.
Downloading http://repo.opkg.net/galileo/repo/i586/Packages.gz.
Collected errors:
 * opkg_conf_parse_file: /etc/opkg/base-feeds.conf:1: Ignoring invalid line: `rc/gz all     http://repo.opkg.net/galileo/repo/all'
 * opkg_download: Failed to download http://repo.opkg.net/galileo/repo/clanton/Packages.gz, wget returned 8.
 * opkg_download: Failed to download http://repo.opkg.net/galileo/repo/i586/Packages.gz, wget returned 8.
EOF
opkg update
Brendan_L_Intel
This is a uclibc based pkg repo, it cannot be used with this eglibc image. Only the iotdk.intel.com repo will work.
Matthias_H_Intel
@Brendan:
only the iotdk.intel.com repo will work
well, any repo built against the Intel(R) IoT devkit would work. In particular it needs to be build against eglibc rather uclibc
@Ilya:
apparently you have already set up a repo in /etc/opkg. Pls check the files in that folder. Make sure to use the right repo. If you have the Intel(R) IoT devkit image you can't use a uclibc based repository. If you use a uclibc image like you can't use http://iotdk.intel.com/repos/1.1/iotdk/ but rather a repo like AlexT repo.
