Software Archive
Read-only legacy content
17060 Discussions
api-request-common.js error when try it on web services
Yetiskan_E_
I think there is a problem on latest version as there is no problem on version 1621 but 2366,2893 and 3240 versions have same problem as it gives 58889/http-services/api-explorer/iodocs/api-request-common.js sysntax error for below line
"});)(intel.xdk.services.credentials.EventBrite,intel.xdk.services.iodocs_.helpers);"
And it should be "}))(intel.xdk.services.credentials.EventBrite,intel.xdk.services.iodocs_.helpers);".
How should I change it?
PaulF_IntelCorp
I'll file a bug with our web services team letting them know. In the meantime, you can always make the corrections to the file yourself and simply use your copy of the library. The web services library is provided as a convenience, you are not required to use it if you understand how to make the AJAX calls yourself.
Yetiskan_E_
Error is below:
Uncaught SyntaxError: Unexpected token ; api-request-common.js:2982
Generated file is :
var intel;
if (!intel) intel = {};
if (typeof intel !== "object") throw new Error("Unexpected use of intelnamespace");
if (!intel.xdk) intel.xdk = {};
if (typeof intel.xdk !== "object") throw new Error("Unexpected use of intel.xdknamespace");
if (!intel.xdk.services) intel.xdk.services = {};
if (typeof intel.xdk.services !== "object") throw new Error("Unexpected use of intel.xdk.servicesnamespace");
intel.xdk.services.iodocs_ = (function () {
 * @license Copyright 2013 - 2014 Intel Corporation All Rights Reserved.
 * The source code, information and material ("Material") contained herein is owned by Intel Corporation or its
 * suppliers or licensors, and title to such Material remains with Intel Corporation or its suppliers or
 * licensors. The Material contains proprietary information of Intel or its suppliers and licensors. The
 * Material is protected by worldwide copyright laws and treaty provisions. No part of the Material may be used,
 * copied, reproduced, modified, published, uploaded, posted, transmitted, distributed or disclosed in any way
 * without Intel's prior express written permission. No license under any patent, copyright or other intellectual
 * property rights in the Material is granted to or conferred upon you, either expressly, by implication,
 * inducement, estoppel or otherwise. Any license under such intellectual property rights must be express and
 * approved by Intel in writing.
 * Unless otherwise agreed by Intel in writing, you may not remove or alter this notice or any other notice
 * embedded in Materials by Intel or Intel's suppliers or licensors in any way.
/* global X2JS */
/* This file contains helper functions for all api-requests (i.e., data bindings) */
  var exports = {};
  /* Merge the second argument into the first, return the first. A simple version of _.extend() */
  exports.mergeParams = function (params, runtimeParams) {
    runtimeParams = runtimeParams || {};
    for (var p in runtimeParams) {
      if (Object.prototype.hasOwnProperty.call(runtimeParams, p)) {
        params
= runtimeParams
    for (p in params) {
      if(params
        delete params
    return params;
  /* Invoke the given common function, run checks on the result, and run a filter function if provided */
  exports.bindCommon = function (functionName, commonFunc, params, runtimeParams) {
     * Pull xdkFilter from runtimeParams, otherwise the filter function may run before
     * the data is returned, which could cause any number of problems
    var filterFunc;
    if (runtimeParams && typeof runtimeParams.xdkFilter === 'function') {
      filterFunc = runtimeParams.xdkFilter;
      delete runtimeParams.xdkFilter;
    var p = commonFunc(exports.mergeParams(params, runtimeParams));
    return p.then(function (data, status, xhr) {
      var finalData = data;
      /* If the returned data is XML, convert it to JSON before sending out */
      if ($.isXMLDoc(data)) {
        var x2j = new X2JS();
        finalData = x2j.xml2json(data);
        finalData.xml2json = true;
      /* If the user passes a filter function, run that filter before returning the response */
      if (filterFunc) finalData = filterFunc(finalData);
      $(document).trigger(functionName, [finalData, status, xhr]);
      return finalData;
  exports.helpers = {};
  /* checks if url for OAuth flow ends with ? */
  function urlChecker(url){
    if (url.substr(-1) !== '?') url = url.concat('?');
    return url;
  /* OAuth 2.0 */
   * Launches window to input user credential for authentication
   * If already authenticated, then opens and closes window to get code/access_token
   * @param {object} url String containing url used for authentication
   * @param {object} params Object containing parameters passed along with url to authenticate (e.g. client_id, client_secret, etc)
   * @param {string} mode Determines the oauth mode (authCode, implicit, etc)
  function doOAuth2_(url, params, mode){
    var d = $.Deferred();
    var completeUrl = urlChecker(url) + $.param(params);
    var l = params.redirect_uri.length;
    var authWindow = window.open(completeUrl, '_blank', 'location=yes');
    /* services tab */
    $(document).on('OAuthSuccess', function(e){
      //OAuthSuccess event tells us we're at the redirect_uri, so no need to check
      if (mode === 'authCode'){
        var results = {};
        var code, error;
        if (e.originalEvent.detail.result.code){
          code = e.originalEvent.detail.result.code;
        } else if (e.originalEvent.detail.result.error){
          error = e.originalEvent.detail.result.error;
        if (code) results.code = code; //oauth2Callback sends the query string, so no need to parse the url
        if (error) results.error = error;
        $(document).off('OAuthSuccess');
        authWindow.close();
        d.resolve(results);
      } else if (mode === 'implicit'){
        var token = /access_token=([^&]+)/.exec(e.originalEvent.detail.hash);
        if (token) {
          authWindow.close();
          d.resolve(token[1]);
    /* emulator and device */
    $(authWindow).on('loadstart', function(e){
      var authUrl = e.originalEvent.url;
      if (authUrl.substring(0, l) === params.redirect_uri) {
          var results = {};
          var code = /\?code=(.+)(?=&)|\?code=(.+)(?=#)|\?code=(.+)$/.exec(e.originalEvent.url);
          if (code) results.code = code[1]||code[2]||code[3];
          results.error = /\?error=(.+)$/.exec(e.originalEvent.url);
          $(authWindow).off('loadstart');
          authWindow.close();
          d.resolve(results);
          var hash = /access_token=([^&]+)/.exec(e.originalEvent.url);
          if (hash) {
            authWindow.close();
            d.resolve(hash[1]);
    return d.promise();
   * Achieve authentication using authorization code OAuth2.0
   * @param {object} url Object containing urls used for authentication
   * @returns {string} Access token used in OAuth 2.0
  exports.helpers.oauth2AuthCode = function (url, params){
    return doOAuth2_(url.codeUrl, params.code, 'authCode')
    .then(function(e){
      if (e.code){
        var tokenParams = {
          code: encodeURIComponent(e.code),
          client_id: params.code.client_id,
          client_secret: params.token.client_secret,
          redirect_uri: params.code.redirect_uri,
          grant_type: 'authorization_code'
        return $.ajax({ //returns response containing access_token
          url: url.tokenUrl,
          type: 'POST',
          contentType: 'application/x-www-form-urlencoded',
          data: tokenParams,
          dataType: 'json',
          headers: {
            Accept : 'application/json'
      } else {
        d.reject(e.error);
        return d.promise();
   * Achieve authentication using implicit OAuth2.0
  exports.helpers.oauth2Implicit = function(url, params){
    return doOAuth2_(url, params, 'implicit');
   * Achieve authentication using client credential OAuth2.0
   * @param {object} url String containing urls used for authentication
  exports.helpers.oauth2CC = function(url, params, header){
    return $.ajax({
      url: urlChecker(url) + $.param(params),
      type: 'POST',
      contentType: 'application/x-www-form-urlencoded;charset=UTF-8',
      headers: {
        'Authorization': header
      data: 'grant_type=client_credentials',
      dataType: 'json'
    .then(function(response){
      d.resolve(response);
      return d.promise();
  return exports;
intel.xdk.services.iodocs_.usatoday = ((function (credentials) {
  var exports = {};
  var baseUrl = 'http://api.usatoday.com/open/';
  function getCensusData(path, params) {
    params = params || {};
    var url = baseUrl + 'census/' + path + '?api_key=' + credentials.apiKey + '&' + $.param(params);
    return $.ajax({url: url});
  exports.getLocations = getCensusData.bind(null, 'locations');
  exports.getEthnicity = getCensusData.bind(null, 'ethnicity');
  exports.getHousing = getCensusData.bind(null, 'housing');
  exports.getPopulation = getCensusData.bind(null, 'population');
  exports.getRace = getCensusData.bind(null, 'race');
  return exports;
}))(intel.xdk.services.credentials.usatoday,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.klout = ((function (credentials) {
  var exports = {};
  var baseUrl = 'http://api.klout.com/v2/';
  function getId(path, params) {
    var substring = '/' + params.Id + '?';
    if(params.screenName) {
      substring = '?' + 'screenName=' + params.screenName + '&';
    if(params.KId) {
      substring = '/' + params.KId + '/tw?';
    var url = baseUrl + 'identity.json/' + path + substring + 'key=' + credentials.apiKey;
  function getUser(path, params) {
    if (path) {path = '/' + path; }
    var url = baseUrl + 'user.json/' + params.kloutId +  path + '?key=' + credentials.apiKey;
  exports.getIdByTwitterId = getId.bind(null, 'tw');
  exports.getIdByGoogle = getId.bind(null, 'gp');
  exports.getIdByInstagram = getId.bind(null, 'ig');
  exports.getIdByTwitterName = getId.bind(null, 'twitter');
  exports.getTwitterIdByKloutId = getId.bind(null, 'klout');
  exports.showUser = getUser.bind(null, '');
  exports.Score = getUser.bind(null, 'score');
  exports.Topics = getUser.bind(null, 'topics');
  exports.Influence = getUser.bind(null, 'influence');
  return exports;
}))(intel.xdk.services.credentials.klout,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.sandbox = ((function (credentials) {
  var exports = {};
  exports.GET = function (params) {
    var url = params.URL ;
  exports.POST = function (params) {
    return $.ajax({url: url, type : 'POST'});
  return exports;
}))(intel.xdk.services.credentials.sandbox,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.rottentomatoes = ((function (credentials) {
  var exports = {};
  var baseUrl = 'http://api.rottentomatoes.com/api/public/v1.0/';
  function getList(path, params) {
    params.apiKey = credentials.apiKey;
    var url = baseUrl + path + '.json?' + $.param(params);
    return $.ajax({url: url, dataType: "json"});
  function getDetailedInfo(path, params) {
    var url = baseUrl + 'movies/' + params.id + path + '.json?';
    var params_temp = {};
    for (var prop in params) {
      if((prop!='id') && Object.prototype.hasOwnProperty.call(params,prop)){
        params_temp[prop] = params[prop];
    url = url + $.param(params_temp);
  exports.box_office = getList.bind(null, 'lists/movies/box_office');
  exports.in_theatres = getList.bind(null, 'lists/movies/in_theaters');
  exports.opening = getList.bind(null, 'lists/movies/opening');
  exports.upcoming = getList.bind(null, 'lists/movies/upcoming');
  exports.top_rentals = getList.bind(null, 'lists/dvds/top_rentals');
  exports.current_releases = getList.bind(null, 'lists/dvds/current_releases');
  exports.new_releases = getList.bind(null, 'lists/dvds/new_releases');
  exports.upcomingDVD = getList.bind(null, 'lists/dvds/upcoming');
  exports.movie_info = getDetailedInfo.bind(null,'');
  exports.cast_info = getDetailedInfo.bind(null, '/cast');
  exports.movie_clips = getDetailedInfo.bind(null, '/clips');
  exports.movie_reviews = getDetailedInfo.bind(null, '/reviews');
  exports.movie_similar = getDetailedInfo.bind(null, '/similar');
  exports.movie_alias = getList.bind(null, 'movie_alias');
  exports.search = getList.bind(null, 'movies');
  exports.listsDirectory = getList.bind(null, '');
  exports.movieListsDirectory = getList.bind(null, 'lists/movies');
  exports.dvdListsDirectory = getList.bind(null, 'lists/dvds');
  return exports;
}))(intel.xdk.services.credentials.rottentomatoes,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.googleplaces = ((function (credentials) {
  var exports = {};
  var baseUrl = 'https://maps.googleapis.com/maps/api/place/';
  function getPlaceData(path, params) {
    var url = baseUrl + path + '/json?key=' + credentials.apiKey + '&sensor=false&' + $.param(params);
  exports.placeSearch = getPlaceData.bind(null, 'nearbysearch');
  exports.textSearch = getPlaceData.bind(null, 'textsearch');
  exports.radarSearch = getPlaceData.bind(null, 'radarsearch');
  exports.placeDetails = getPlaceData.bind(null, 'details');
  return exports;
}))(intel.xdk.services.credentials.googleplaces,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.wunderground = ((function (credentials, helpers) {
  'use strict';
  var API = 'https://api.wunderground.com/api';
  var WU_SETTINGS = ['lang','pws','bestfct'];
  // get a WU API URI from a method name and parameters
  var wu_uri = function(method, params) {
    var key = credentials.apiKey;
    // history and planner methods optionally have a date (method_YYYYMMDD)
    var method = params.date ? (method + '_' + params.date) : method;
    var location = params.query;
    var settings = WU_SETTINGS.reduce(function(memo, setting) {
      var val = params[setting];
      if (val !== undefined && val !== '1') { // pws, bestfct default to 1
        memo += (setting + ':' + val) + '/';
      return memo;
    return API + '/' + key + '/' + method + settings + 'q/' + location + '.json';
  // get WU API data from a method name and parameters
  var wu_ajax = function(method, params) {
    return $.ajax({
      type: 'GET',
      dataType: 'json',
      url: wu_uri(method, params)
  return [
    'alerts', 'almanac', 'astronomy', 'conditions', 'currenthurricane',
    'forecast', 'forecast10day', 'geolookup', 'hourly', 'hourly10day',
    'rawtide', 'tide', 'webcams', 'yesterday', 'history', 'planner'
  ].reduce(function(exports, method) {
    exports[method] = function(params) {
      return wu_ajax(method, params);
    return exports;
)(intel.xdk.services.credentials.wunderground,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.spotify = ((function (credentials) {
  var exports = {};
  function jsonCleaner(x) {
    var type = typeof x;
    if (x instanceof Array) {
      type = 'array';
    if ((type == 'array') || (type == 'object')) {
      for (k in x) {
        var v = x;
        if ((v === '') && (type == 'object')) {
          delete x;
        } else {
          jsonCleaner(v);
      return x;
  var searchURL = 'https://api.spotify.com/v1/';
  function getSearchData(path, params) {
    params = jsonCleaner(params);
    var url = searchURL + path + "?" + $.param(params);
  function getSpecificData(path, params) {
    var url = searchURL + path + "/" + params.id;
  exports.search = getSearchData.bind(null, "search");
  exports.lookupArtist = getSpecificData.bind(null, "artists");
  exports.lookupAlbum = getSpecificData.bind(null, "albums");
  exports.lookupTrack = getSpecificData.bind(null, "tracks");
  return exports;
}))(intel.xdk.services.credentials.spotify,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.itunes = ((function (credentials, helpers) {
  'use strict';
  var ITUNES = 'https://itunes.apple.com/search?';
  return {
    search: function(params) {
      return $.ajax({
        type: 'GET',
        dataType: 'json',
        url: ITUNES + $.param(params)
)(intel.xdk.services.credentials.itunes,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.flickr = ((function (credentials, helpers) {
  var exports = {photos:{}, people:{}, galleries:{}, interestingness:{}, photosets:{}};
    var utils = {};
    utils.sprintf = function(format, etc)
        var arg = arguments;
        var i = 1;
        return format.replace(/%((%)|s)/g, function (m) { return m[2] || arg[i++] ;});
          type = 'array';
          for (var k in x) {
            var v = x;
              delete x;
            } else {
              jsonCleaner(v);
          return x;
     photo_object
        Object
        farm: 3
        isfamily: 0
        isfriend: 0
        ispublic: 1
        owner: "62591523@N08"
        secret: "e5d42a9a0d"
        server: "2933"
        title: "cat"
    function construct_url(photo_obj)
        //https://farm{farm-id}.staticflickr.com/{server-id}/{id}_{secret}.jpg
        var template = "https://farm%s.staticflickr.com/%s/%s_%s.jpg";
        return utils.sprintf(template, photo_obj.farm, photo_obj.server, photo_obj.id, photo_obj.secret);
    function get_method_call(method_name, append_url)
        return function(params)
                var url = 'https://api.flickr.com/services/rest/';
                params.method = "flickr." + method_name;
                params.api_key = credentials.apiKey;
                params.format = "json";
                if (params) url = url + '?' + $.param(jsonCleaner(params));
                var promise =  $.ajax({url: url, type: 'GET', dataType:'jsonp', jsonp:'jsoncallback'});
                if(append_url)
                    return promise.then(function(data)
                              //data.photos.photo[ {photoObj}...]
                              var photo_obj = data[append_url];
                              $.each(photo_obj.photo, function(index, photo_obj)
                                         photo_obj.url = construct_url(photo_obj);
                              return data;
                else
                    return promise;
  exports.photos_search             = get_method_call("photos.search", "photos");
  exports.people_getPublicPhotos    = get_method_call("people.getPublicPhotos", "photos");
  exports.people_getPhotosOf        = get_method_call("people.getPhotosOf", "photos");
  exports.galleries_getPhotos       = get_method_call("galleries.getPhotos", true);
  exports.galleries_getListForPhoto = get_method_call("galleries.getListForPhoto", false);
  exports.galleries_getList         = get_method_call("galleries.getList", false);
  exports.galleries_getInfo         = get_method_call("galleries.getInfo", false);
  exports.interestingness_getList   = get_method_call("interestingness.getList", "photos");
  exports.photosets_getPhotos       = get_method_call("photosets.getPhotos", "photoset");
  exports.photosets_getList         = get_method_call("photosets.getList", false);
  exports.photosets_getInfo         = get_method_call("photosets.getInfo", false);
  return exports;
}))(intel.xdk.services.credentials.flickr,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.foursquare = ((function (credentials, helpers) {
  var exports = {};
  /* helper functions */
      type = 'array';
      for (k in x) {
        var v = x;
          delete x;
        } else {
          jsonCleaner(v);
      return x;
  function currentDate(){
    // var d = new Date();
    // var m = d.getMonth()+1;
    // var day = d.getDate();
    // if(m < 10) m = '0'.concat(m);
    // if(day<10) day = '0'.concat(day);
    // return d.getFullYear() + '' + m + '' + day;
    return '20150101';
  function getToken() {
    var db = window.localStorage;
    return db.getItem('foursquare_access_token');
  function showError(message){
    console.log(message);
    return message;
  /* Authentication */
  exports.authenticate = function(params) {
    var url = {codeUrl: 'https://foursquare.com/oauth2/authenticate?',
               tokenUrl: 'https://foursquare.com/oauth2/access_token?'};
    var urlParams = {code: {
                        client_id: credentials.apiKey,
                        redirect_uri: params.redirect_uri,
                        response_type: params.response_type
                     token: {
                        client_secret: credentials.apiSecret,
    return helpers.oauth2AuthCode(url, urlParams)
    .then(function(token){
      db.setItem('foursquare_access_token', token);
      return token;
    .fail(function(err){
      return showError(err.responseText);
  /* Users */
  exports.user = function(params) {
    var token = getToken();
    if (!token) return showError('Need access token before making call');
    var urlParams = $.extend({},{client_id: credentials.apiKey,
                                 oauth_token: token,
                                 v:currentDate(),
                                 m:'foursquare'}, params);
    return $.ajax({
      url: 'https://api.foursquare.com/v2/users/' + params.USER_ID + '?' + $.param(urlParams),
      type: 'GET'
    .then(function(user){
      return user;
  exports.userLeaderboard = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/users/leaderboard?' + $.param(urlParams),
      type: 'GET'
    .then(function(leaderboard){
      return leaderboard;
  exports.userRequests = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/users/requests?' + $.param(urlParams),
      type: 'GET'
    .then(function(requests){
      return requests;
  exports.userSearch = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/users/search?' + $.param(urlParams),
      type: 'GET'
      return leaderboard;
  exports.userBadges = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/users/' + params.USER_ID + '/badges?' + $.param(urlParams),
      type: 'GET'
      return user;
  exports.userCheckins = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/users/' + params.USER_ID + '/checkins?' + $.param(urlParams),
      type: 'GET'
      return user;
  exports.userFriends = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/users/' + params.USER_ID + '/friends?' + $.param(urlParams),
      type: 'GET'
      return user;
  exports.userLists = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/users/' + params.USER_ID + '/lists?' + $.param(urlParams),
      type: 'GET'
      return user;
  exports.userMayorships = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/users/' + params.USER_ID + '/mayorships?' + $.param(urlParams),
      type: 'GET'
      return user;
  exports.userPhotos = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/users/' + params.USER_ID + '/photos?' + $.param(urlParams),
      type: 'GET'
      return user;
  exports.userVenueHistory = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/users/' + params.USER_ID + '/venuehistory?' + $.param(urlParams),
      type: 'GET'
      return user;
  exports.userApprove = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/users/' + params.USER_ID + '/approve?' + $.param(urlParams),
      type: 'POST'
      return user;
  exports.userDeny = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/users/' + params.USER_ID + '/deny?' + $.param(urlParams),
      type: 'POST'
      return user;
  exports.userSetPings = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/users/' + params.USER_ID + '/setpings?' + $.param(urlParams),
      type: 'POST'
      return user;
  exports.userUnfriend = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/users/' + params.USER_ID + '/unfriend?' + $.param(urlParams),
      type: 'POST'
      return user;
  exports.userUpdate = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/users/' + params.USER_ID + '/update?' + $.param(urlParams),
      type: 'POST'
      return user;
  /* Venue */
  exports.venueDetail = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/venues/' + params.venue_id + '?' + $.param(urlParams),
      type: 'GET'
    .then(function(venue){
      return venue;
  exports.venueCategories = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/venues/categories?' + $.param(urlParams),
      type: 'GET'
      return venue;
  exports.venueExplore = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/venues/explore?' + $.param(urlParams),
      type: 'GET'
      return venue;
  exports.venueSearch = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/venues/search?' + $.param(urlParams),
      type: 'GET'
      return venue;
  /* Checkins */
  exports.checkin = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/checkins/' + params.checkin_id + '?' + $.param(urlParams),
      type: 'GET'
      return venue;
  exports.checkinAdd = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/checkins/add?' + $.param(urlParams),
      type: 'GET'
      return venue;
  /* Events */
  exports.events = function(params) {
                                 oauth_token: token,
                                 v:currentDate(),
    return $.ajax({
      url: 'https://api.foursquare.com/v2/events/' + params.event_id + '?' + $.param(urlParams),
      type: 'GET'
      return venue;
  return exports;
}))(intel.xdk.services.credentials.foursquare,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.MarkitOnDemand = ((function (credentials, helpers) {
  var exports = {};
    function get_method_call(method_name)
            var url = 'http://dev.markitondemand.com/Api/v2/' + method_name + '/json';
            if (params) url = url + '?' + $.param(params);
            return $.ajax({url: url, type: 'GET', dataType:'json'});
  exports.Lookup           = get_method_call('Lookup');
  exports.Quote            = get_method_call('Quote');
  return exports;
}))(intel.xdk.services.credentials.MarkitOnDemand,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.forecast = ((function (credentials, helpers) {
  'use strict';
  var FORECAST = 'https://api.forecast.io';
  var forecast_url = function(method, params) {
    return FORECAST + '/' + method + '/' + credentials.apiKey + '/' +
      params.latitude + ',' + params.longitude + (params.time ? (',' + params.time) : '');
  return {
    forecast: function(params) {
      return $.ajax({
        type: 'GET',
        dataType: 'json',
        url: forecast_url('forecast', params)
)(intel.xdk.services.credentials.forecast,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.woot = ((function (credentials, helpers) {
  'use strict';
  var WOOT = 'https://api.woot.com/2';
  var woot_uri = function(method, params) {
    var extra = '';
    if (method === 'offers') {
      extra = '/' + params.id;
      delete params.id;
    return WOOT + '/' + method + extra + '.json?key=' + credentials.apiKey + '&' + $.param(params);
  var woot_ajax = function(method, params) {
    return $.ajax({
      type: 'GET',
      dataType: 'json',
      url: woot_uri(method, params)
  return [
    'events', 'offers', 'monkeychats', 'polls', 'wootcasts'
      return woot_ajax(method, params);
    return exports;
)(intel.xdk.services.credentials.woot,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.instagram = ((function (credentials, helpers) {
  var exports = {};
    return db.getItem('instagram_access_token');
    return message;
  /* Users */
    var url = 'https://instagram.com/oauth/authorize/?';
    var param = {client_id: credentials.apiKey,
                 response_type: params.response_type};
    return helpers.oauth2Implicit(url, param)
      db.setItem('instagram_access_token', token);
      return token;
  exports.user = function(params){
    var urlParams = $.extend({access_token: token}, params);
    var completeUrl = 'https://api.instagram.com/v1/users/' + params.userId + '?' +  $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  exports.userFeed = function(params){
    var completeUrl = 'https://api.instagram.com/v1/users/self/feed?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
    .then(function(feed){
      return feed;
  exports.userRecent = function(params){
    var completeUrl = 'https://api.instagram.com/v1/users/' + params.userId + '/media/recent?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return feed;
  exports.userLiked = function(params){
    var completeUrl = 'https://api.instagram.com/v1/users/self/media/liked?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return feed;
  exports.userSearch = function(params){
    var completeUrl = 'https://api.instagram.com/v1/users/search?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  /* Relationships */
  exports.userFollows = function(params){
    var completeUrl = 'https://api.instagram.com/v1/users/' + params.userId + '/follows?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return feed;
  exports.userFollowedBy = function(params){
    var completeUrl = 'https://api.instagram.com/v1/users/' + params.userId + '/followed-by?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return feed;
  exports.userRequestedBy = function(params){
    var completeUrl = 'https://api.instagram.com/v1/users/self/requested-by?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return feed;
  exports.userRelationship = function(params){
    var completeUrl = 'https://api.instagram.com/v1/users/' + params.userId + '/relationship?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return feed;
  /* Media */
  exports.media = function(params){
    var completeUrl = 'https://api.instagram.com/v1/media/' + params.mediaId + '?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return feed;
  exports.mediaSearch = function(params){
    var completeUrl = 'https://api.instagram.com/v1/media/search?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return feed;
  exports.mediaPopular = function(params){
    var completeUrl = 'https://api.instagram.com/v1/media/popular?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return feed;
  /* Comments */
  exports.mediaComments = function(params){
    var completeUrl = 'https://api.instagram.com/v1/media/' + params.mediaId + '/comments?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  /* Likes */
  exports.mediaLikes = function(params){
    var completeUrl = 'https://api.instagram.com/v1/media/' + params.mediaId + '/likes?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  /* Tags */
  exports.tag = function(params){
    var completeUrl = 'https://api.instagram.com/v1/tags/' + params.tagName + '?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  exports.tagRecent = function(params){
    var completeUrl = 'https://api.instagram.com/v1/tags/' + params.tagName + '/media/recent?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  exports.tagSearch = function(params){
    var completeUrl = 'https://api.instagram.com/v1/tags/search?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  /* Locations */
  exports.location = function(params){
    var completeUrl = 'https://api.instagram.com/v1/locations/' + params.locationId + '?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  exports.locationRecent = function(params){
    var completeUrl = 'https://api.instagram.com/v1/locations/' + params.locationId + '/media/recent?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  exports.locationSearch = function(params){
    var completeUrl = 'https://api.instagram.com/v1/locations/search?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  /* Geographies */
  exports.geoRecent = function(params){
    var completeUrl = 'https://api.instagram.com/v1/geographies/' + params.geoId + '/media/recent?' + $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  return exports;
}))(intel.xdk.services.credentials.instagram,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.google_analytics = ((function (credentials) {
  var exports = {};
  function init() {
    (function(i,s,o,g,r,a,m){i['GoogleAnalyticsObject']=r;i=i||function(){
    (i.q=i.q||[]).push(arguments)},i.l=1*new Date();a=s.createElement(o),
    m=s.getElementsByTagName(o)[0];a.async=1;a.src=g;m.parentNode.insertBefore(a,m)
    })(window,document,'script','//www.google-analytics.com/analytics.js','ga');
    ga('create', credentials.apiKey, 'auto');
  exports.trackPageView = function(params) {
      init();
      if (params.Location) ga('set','location', params.Location);
      if (params.Page) ga('set','page', params.Page);
      if (params.Title) ga('set','title', params.Title);
      ga('send', 'pageview');
      d.resolve('Pageview sent!');
      return d.promise();
    exports.trackEvent = function(params) {
        init();
        if (params.Label) ga('set','eventLabel', params.Label);
        if (params.Value) ga('set','eventValue', params.Value);
        ga('send', 'event', params.Category, params.Action);
        d.resolve('Check your analytics account');
        return d.promise();
  return exports;
}))(intel.xdk.services.credentials.google_analytics,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.kinvey = ((function (credentials) {
  var exports = {};
  var isInit;
  /*Only Init*/
  function kinveyInit() {
    if(isInit) return emptyPromise();
    return kinveyToJqueryProm(Kinvey.init.bind(Kinvey,{appKey : credentials.apiKey, appSecret: credentials.apiSecret}))
    .then(function (result) {
      if(result) {isInit = true;}
      return result || {result: null};
    .fail(function (err) {
      isInit = false
      return err.name + ' : ' + err.description + '\n' + err.debug;
  function emptyPromise(){
    var deferred = $.Deferred();
    deferred.resolve();
    return deferred.promise();
  /*Init and then do the passed function. isSpecial = true, if passed function is not a kinvey promise;else false.*/
  function initThenCall(func, isSpecial) {
    isSpecial = isSpecial || false;
    return kinveyInit()
    .then(function (response)
      if(isSpecial) {return func();}
      else{ return kinveyToJqueryProm(func);}
  function kinveyToJqueryProm(func, params) {
    func()
    .then(function (response) {
      deferred.resolve(response || true );
    }, function(err) {
      deferred.reject(err.name + ' : ' + err.description + '\n' + err.debug);
  function getActiveUser_() {
    var user = Kinvey.getActiveUser();
    if(null !== user) { return user; }
    else { return {result : null}; }
  function logout_() {
    if(null !== user) { return Kinvey.User.logout() }
  function verificationStatus_() {
    if(null !== user) {
      emailStatus = new Kinvey.Metadata(user).getEmailVerification();
      return { status : emailStatus };
  function exists_(params) {
    return Kinvey.User.exists(params.username)
    .then(function(exists){
      return {result : (exists ? 'true':'false')};
  function count_(params) {
    return Kinvey.DataStore.count(params.collection_name)
    .then(function(count){
      return {result : count};
  exports.init = function (params) {
    isInit = false;
    return kinveyInit();
  exports.getActiveUser = function () {
    return initThenCall(
      getActiveUser_.bind(Kinvey),
      true
  exports.signup = function(params) {
      Kinvey.User.signup.bind(Kinvey.User, params)
  exports.destroy = function(params) {
      Kinvey.User.destroy.bind(Kinvey.User, params.user_id)
  exports.login = function(params) {
      Kinvey.User.login.bind(Kinvey.User, params)
  exports.logout = function() {
      logout_.bind(Kinvey)
  exports.verifyEmail = function(params) {
      Kinvey.User.verifyEmail.bind(Kinvey.User, params)
  exports.getActiveUserEmailVerification = function() {
      verificationStatus_.bind(Kinvey),
      true
  exports.resetPassword = function(params) {
      Kinvey.User.resetPassword.bind(Kinvey.User, params)
  exports.forgotUsername = function(params) {
      Kinvey.User.forgotUsername.bind(Kinvey.User, params)
  exports.exists = function(params) {
      exists_.bind(Kinvey.User, params)
  exports.Datastore_save = function (params) {
    var obj = {};
    obj[params.propName] = params.propValue;
      Kinvey.DataStore.save.bind(Kinvey.Datastore, params.collection_name, obj)
  exports.Datastore_update = function (params) {
    var obj = {};
    obj['_id'] = params.entity_id;
      Kinvey.DataStore.update.bind(Kinvey.Datastore, params.collection_name, obj)
  exports.Datastore_get = function (params) {
      Kinvey.DataStore.get.bind(Kinvey.Datastore, params.collection_name, params.entity_id)
  exports.Datastore_findAll = function (params) {
      Kinvey.DataStore.find.bind(Kinvey.Datastore, params.collection_name, null)
  exports.Datastore_destroy = function (params) {
      Kinvey.DataStore.destroy.bind(Kinvey.Datastore, params.collection_name, params.entity_id)
  exports.Datastore_clean = function (params) {
      Kinvey.DataStore.clean.bind(Kinvey.Datastore, params.collection_name)
  exports.Datastore_count = function (params) {
      count_.bind(Kinvey.Datastore, params)
  return exports;
}))(intel.xdk.services.credentials.kinvey,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.tms = ((function (credentials, helpers) {
  var exports = {};
  var version = 'v1.1';
      type = 'array';
      for (var k in x) {
        var v = x;
          delete x;
        } else {
          jsonCleaner(v);
      return x;
  //a helper function
  exports.dateToISO8601 = function(d)
      return d.toISOString().match(/[^:]*:[^:]*/)[0] + 'Z';
  get_tms_iso8601_method = function(endpoint_uri)
        var url = endpoint_uri;
        if(!params.startDateTime) //oddly, startDateTime is required.
            var now = new Date();
            params.startDateTime = exports.dateToISO8601(now);
        return $.ajax({url: url, type: 'GET'});
  exports.movieShowings = function(params) {
        var url = 'http://data.tmsapi.com/'+ version +'/movies/showings';
        if(!params.startDate) //oddly, startDate is required.
            var now_str = now.toISOString();
            params.startDate = now_str.match(/[^T]*/)[0];
  exports.newShowAirings = get_tms_iso8601_method('http://data.tmsapi.com/'+ version +'/programs/newShowAirings');
  exports.movieAirings = get_tms_iso8601_method('http://data.tmsapi.com/'+ version +'/movies/airings');
  exports.sportEventAirings = function(params)
    var url = 'http://data.tmsapi.com/'+ version +'/sports/';
    url += params.sportsId;
    delete params.sportsId;
    url += '/events/airings';
  exports.newShowAirings = function(params) {
        var url = 'http://data.tmsapi.com/v1/programs/newShowAirings';
  return exports;
}))(intel.xdk.services.credentials.tms,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.jambase = ((function (credentials, helpers) {
  var exports = {};
      type = 'array';
      for (var k in x) {
        var v = x;
          delete x;
        } else {
          jsonCleaner(v);
      return x;
  /* Data Feed Function */
  exports.methodA1 = function (params) {
    var url = 'http://example.api/methodA1?api_key_var_name=' + credentials.apiKey;
  function get_jambase_handler(endpoint_uri)
      return function(params) {
  //all the 'eventById, eventListByZipcode, etc are just the same endpoint with different param combinations.
  function get_eventBy_method()
      return get_jambase_handler('http://api.jambase.com/events');
  function get_artistBy_method()
      return get_jambase_handler('http://api.jambase.com/artists');
  function get_venuesBy_method()
      return get_jambase_handler('http://api.jambase.com/venues');
  exports.eventById           = get_eventBy_method();
  exports.eventListByZipcode  = get_eventBy_method()
  exports.eventListByArtistId = get_eventBy_method();
  exports.eventListByVenueId  = get_eventBy_method();
  exports.artistsByName       = get_artistBy_method();
  exports.artistById          = get_artistBy_method();
  exports.venuesByName        = get_venuesBy_method();
  exports.venuesByZipcode     = get_venuesBy_method();
  exports.venueById           = get_venuesBy_method();
  return exports;
}))(intel.xdk.services.credentials.jambase,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.db_core = ((function (credentials, helpers) {
  var exports = {};
    return window.localStorage.getItem('dropbox_access_token');
    return message;
  /* OAuth 2.0 */
  exports.authorize = function (params) {
    var urls = {codeUrl:'https://www.dropbox.com/1/oauth2/authorize?',
               tokenUrl: 'https://api.dropbox.com/1/oauth2/token?'};
    var urlParams = {
                     code: {
                     token: {
    if (params.state !== '') urlParams.code.state = params.state;
    if (params.force_reapprove !== '') urlParams.code.force_reapprove = params.force_reapprove;
    if (params.disable_signup !== '') urlParams.code.disable_signup = params.disable_signup;
    return helpers.oauth2AuthCode(urls, urlParams)
      db.setItem('dropbox_access_token', token);
      return token;
      console.log(err.responseText);
  /* Dropbox Accounts */
  exports.accountInfo = function (params) {
    var urlParams = {oauth_consumer_key: credentials.apiKey,
                     oauth_secret: credentials.apiSecret,
                     access_token: token};
    var url = 'https://api.dropbox.com/1/account/info?' + $.param(urlParams);
    return $.ajax({
      url: url,
      type: 'GET',
      dataType: 'json'
      return response;
    .fail(function(error){
      return error;
  /* Files and Metadata */
  exports.metadata = function (params) {
    var urlParams = $.extend({oauth_consumer_key: credentials.apiKey,
    var url = 'https://api.dropbox.com/1/metadata/' + params.root + '/' + params.path + '?' + $.param(urlParams);
    return $.ajax({
      url: url,
      type: 'GET',
      dataType: 'json'
    .then(function(metadata){
      return metadata;
      return error;
  exports.delta = function (params) {
    var url = 'https://api.dropbox.com/1/delta?' + $.param(urlParams);
    return $.ajax({
      url: url,
      type: 'POST',
      dataType: 'json'
      return response;
      return error;
  exports.longpoll_delta = function (params) {
    var url = 'https://api-notify.dropbox.com/1/longpoll_delta?' + $.param(urlParams);
    return $.ajax({
      url: url,
      type: 'GET',
      dataType: 'json'
      return response;
      return error;
  exports.revisions = function (params) {
    var url = 'https://api.dropbox.com/1/revisions/' + params.root + '/' + params.path + '?' + $.param(urlParams);
    return $.ajax({
      url: url,
      type: 'GET',
      dataType: 'json'
      return metadata;
      return error;
  exports.restore = function (params) {
    var url = 'https://api.dropbox.com/1/restore/' + params.root + '/' + params.path + '?' + $.param(urlParams);
    return $.ajax({
      url: url,
      type: 'POST',
      dataType: 'json'
      return metadata;
      return error;
  exports.search = function (params) {
    var url = 'https://api.dropbox.com/1/search/' + params.root + '/' + params.path + '?' + $.param(urlParams);
    return $.ajax({
      url: url,
      type: 'GET',
      dataType: 'json'
      return metadata;
      return error;
  exports.shares = function (params) {
    var url = 'https://api.dropbox.com/1/shares/' + params.root + '/' + params.path + '?' + $.param(urlParams);
    return $.ajax({
      url: url,
      type: 'POST',
      dataType: 'json'
      return metadata;
      return error;
  exports.media = function (params) {
    var url = 'https://api.dropbox.com/1/media/' + params.root + '/' + params.path + '?' + $.param(urlParams);
    return $.ajax({
      url: url,
      type: 'POST',
      dataType: 'json'
      return metadata;
      return error;
  exports.copy_ref = function (params) {
    var url = 'https://api.dropbox.com/1/copy_ref/' + params.root + '/' + params.path + '?' + $.param(urlParams);
    return $.ajax({
      url: url,
      type: 'GET',
      dataType: 'json'
      return metadata;
      return error;
  /* File Operations */
  exports.copy = function (params) {
    var url = 'https://api.dropbox.com/1/fileops/copy?' + $.param(urlParams);
    return $.ajax({
      url: url,
      type: 'POST',
      dataType: 'json'
      return metadata;
      return error;
  exports.create_folder = function (params) {
    var url = 'https://api.dropbox.com/1/fileops/create_folder?' + $.param(urlParams);
    return $.ajax({
      url: url,
      type: 'POST',
      dataType: 'json'
      return metadata;
      return error;
  exports.delete = function (params) {
    var url = 'https://api.dropbox.com/1/fileops/delete?' + $.param(urlParams);
    return $.ajax({
      url: url,
      type: 'POST',
      dataType: 'json'
      return metadata;
      return error;
  exports.move = function (params) {
    var url = 'https://api.dropbox.com/1/fileops/move?' + $.param(urlParams);
    return $.ajax({
      url: url,
      type: 'POST',
      dataType: 'json'
      return metadata;
      error.responseText
  exports.upload_file = function(params)
      //params = jsonCleaner(params);
      var file = params.file;
      var path = encodeURI(params.path || file.name);
      delete params.path;
      delete params.file;
      var url = 'https://api-content.dropbox.com/1/files_put/auto/' +
                 path +
      if(file == '-')
          deferred.resolve({'status':'ok'});
      else
          //var fd = new FormData();
          //fd.append(path, file);
          return $.ajax({
                  url: url,
                  type: "PUT",
                  data: file,
                  processData: false,  // tell jQuery not to process the data
                  contentType: false   // tell jQuery not to set contentType
  return exports;
}))(intel.xdk.services.credentials.db_core,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.soundcloud = ((function (credentials, helpers) {
  var exports = {};
    return window.localStorage.getItem('soundcloud_access_token');
  /* OAuth Functions */
    var url = {
      codeUrl: 'https://soundcloud.com/connect?',
      tokenUrl: 'https://api.soundcloud.com/oauth2/token?'
    var urlParams = {
      code: {
        response_type: 'code',
        scope: 'non-expiring',
        display: 'popup'
      token: {
      db.setItem('soundcloud_access_token', token);
      return token;
  exports.users = function(params) {
    var url = 'http://api.soundcloud.com/users/' + params.id + '.json?client_id=' + credentials.apiKey;
    return $.ajax({
      url: url,
      type: 'GET'
  exports.tracks = function(params) {
    var url = 'http://api.soundcloud.com/tracks/' + params.id + '.json?client_id=' + credentials.apiKey;
    return $.ajax({
      url: url,
      type: 'GET'
  exports.playlists = function(params) {
    var url = 'http://api.soundcloud.com/playlists/' + params.id + '.json?client_id=' + credentials.apiKey;
    return $.ajax({
      url: url,
      type: 'GET'
  exports.groups = function(params) {
    var url = 'http://api.soundcloud.com/groups/' + params.id + '.json?client_id=' + credentials.apiKey;
    return $.ajax({
      url: url,
      type: 'GET'
  exports.comments = function(params) {
    var url = 'http://api.soundcloud.com/comments/' + params.id + '.json?client_id=' + credentials.apiKey;
    return $.ajax({
      url: url,
      type: 'GET'
  exports.me = function(params){
    var url = 'https://api.soundcloud.com/me.json?oauth_token=' + token;
    return $.ajax({
      url: url,
      type: 'GET'
  exports.meConnections = function(params){
    var url = 'https://api.soundcloud.com/me/connections.json?oauth_token=' + token;
    return $.ajax({
      url: url,
      type: 'GET'
  exports.meActivities = function(params){
    var url = 'https://api.soundcloud.com/me/activities?limit=' + params.limit + '&oauth_token=' + token;
    return $.ajax({
      url: url,
      type: 'GET'
  exports.apps = function(params){
    var url = 'http://api.soundcloud.com/apps/' + params.appId + '/tracks?client_id=' + credentials.apiKey + '&limit=' + params.limit;
    return $.ajax({
      url: url,
      type: 'GET'
  return exports;
}))(intel.xdk.services.credentials.soundcloud,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.Weibo = ((function (credentials, helpers) {
  var exports = {};
  function getCachedToken () {
    if ($.jStorage && $.jStorage.storageAvailable()) {
      return $.jStorage.get("intel_xdk_services_sina_weibo_access_token_");
    return null;
  function showError(msg) {
    console.log(msg);
    return msg;
  exports.get_access_token = function(params) {
    var url = {
      codeUrl: 'https://api.weibo.com/oauth2/authorize?',
      tokenUrl: 'https://api.weibo.com/oauth2/access_token?'
    var jStorageAvailable = false, keyName, accessToken;
      jStorageAvailable = true;
      keyName = "intel_xdk_services_sina_weibo_access_token_";
      accessToken = $.jStorage.get(keyName);
      if (accessToken) {
        deferred.resolve({access_token: accessToken});
    var urlParams = {
      code: {
        response_type: "code",
        scope: params.scope,
        forcelogin: params.forcelogin
      token: {
    //helper oauth functions return access token. check to see if service uses authentication code or implicit oauth
    .then(function(access_token){
      if (jStorageAvailable) {
        $.jStorage.set(keyName, access_token, {TTL: 24 * 3600 * 1000});
      deferred.resolve({ access_token: access_token });
      deferred.reject(err);
  exports.update = function(params) {
    var filteredParams = {}, d = $.Deferred();
    for (var k in params) {
      if (params.hasOwnProperty(k) && params) {
        filteredParams = params;
    var access_token;
    if (!filteredParams.access_token) {
      access_token= getCachedToken();
      if (!access_token) {
        d.reject(showError("Need access token before making call"));
        return d.promise();
      } else {
        filteredParams.access_token = access_token;
    var url = "https://api.weibo.com/2/statuses/update.json";
    return $.ajax({
      url: url,
      type: 'POST',
      data: filteredParams
  exports.upload = function(params) {
    var access_token;
    if (!params.access_token) {
      access_token = getCachedToken();
        return d.promise();
      } else {
        params.access_token = access_token;
    var url = "https://upload.api.weibo.com/2/statuses/upload.json";
    var fd;
    if(params.pic == '-')
      return d.promise();
    for (var i in params) {
      if (params.hasOwnProperty(i) && params) {
        fd.append(i, params);
    return $.ajax({
      url: url,
      type: "POST",
      data: fd,
  return exports;
}))(intel.xdk.services.credentials.Weibo,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.mapquest = ((function (credentials, helpers) {
  'use strict';
  var MAPQUEST = 'https://www.mapquestapi.com/traffic/v2/';
  return {
    incidents: function(params) {
      var url = MAPQUEST + 'incidents?inFormat=kvp&key=' + credentials.apiKey;
      url += '&boundingBox=' + params.boundingBox;
      url += '&incidents=';
      var incidents = {
        incidents: params.incidents,
        construction: params.construction,
        event: params.event,
        congestion: params.congestion
      url += Object.keys(incidents).filter(function(incident) {
        return incidents[incident] === 'true';
      }).join(',');
      return $.ajax({
        type: 'GET',
        url:  url
)(intel.xdk.services.credentials.mapquest,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.BaiduMap = ((function (credentials, helpers) {
    var exports = {};
    exports.getIPLocation = function (params) {
        var url = 'http://api.map.baidu.com/location/ip?ak=' + credentials.apiKey + '&coor=bd09ll';
        return $.ajax({
            url : url,
            type: 'GET',
            dataType: 'json',
            data: {
                ip: params.ip_address
    exports.enGeoCode = function (params) {
        var url = 'http://api.map.baidu.com/geocoder/v2/?output=json&ak=' + credentials.apiKey;
        return $.ajax({
            url : url,
            type: 'GET',
            dataType: 'json',
            data: {
                address: params.address
    exports.deGeoCode = function (params) {
        return $.ajax({
            url : url,
            type: 'GET',
            dataType: 'json',
            data: {
    exports.roundNearBy = function (params) {
        var url = 'http://api.map.baidu.com/place/v2/search?output=json&ak=' + credentials.apiKey;
        return $.ajax({
            url : url,
            type: 'GET',
            dataType: 'json',
            data: {
                query: params.query,
                radius: params.radius
    exports.getNearByGrouponInfo = function (params) {
        var url = 'http://api.map.baidu.com/place/v2/eventsearch?event=groupon&output=json&ak=' + credentials.apiKey;
        return $.ajax({
            url : url,
            type: 'GET',
            dataType: 'json',
            data: {
                region: params.region,
                radius: params.radius,
                page_size: params.page_size
    exports.getPlaceByCity = function (params) {
        return $.ajax({
            url : url,
            type: 'GET',
            dataType: 'json',
            data: {
                page_num: params.page_num,
    exports.getPlacesByRectangleArea = function (params) {
        return $.ajax({
            url : url,
            type: 'GET',
            dataType: 'json',
            data: {
                bounds: params.bounds,
    exports.getPlacesByRoundArea = function (params) {
        return $.ajax({
            url : url,
            type: 'GET',
            dataType: 'json',
            data: {
    exports.getDirection = function (params) {
        var url = 'http://api.map.baidu.com/direction/v1?output=json&ak=' + credentials.apiKey;
        return $.ajax({
            url : url,
            type: 'GET',
            dataType: 'json',
            data: {
                mode: params.mode,
                origin: params.origin,
                destination: params.destination,
                origin_region: params.origin_region,
                destination_region: params.destination_region,
                tactics: params.tactics
    return exports;
}))(intel.xdk.services.credentials.BaiduMap,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.bing_search = ((function (credentials, helpers) {
  var exports = {};
      type = 'array';
      for (k in x) {
        var v = x;
          delete x;
        } else {
          jsonCleaner(v);
      return x;
  exports.search = function(params) {
      //http://api.bing.net/json.aspx?Appid=<Your App ID HERE!>&query=sushi&sources=web.
    var url = 'https://api.datamarket.azure.com/Bing/Search/';
    var searchSpace = params.SearchSpace;
    delete params.SearchSpace;
    params.Query = "'" + params.Query + "'";
    url = url + searchSpace +  '?' + $.param(params) + "&$format=JSON";
    var username = "";
    var password = credentials.apiKey;
                   type: 'GET',
                   headers: {"Authorization":"Basic " + btoa(username + ":" + password)}
  return exports;
}))(intel.xdk.services.credentials.bing_search,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.Etsy = ((function (credentials) {
  var exports = {};
      type = 'array';
      for (k in x) {
        var v = x;
          delete x;
        } else {
          jsonCleaner(v);
      return x;
  var baseUrl = 'https://openapi.etsy.com/v2/';
  function getEtsyData(path, params){
    var url = baseUrl + path + '?api_key=' + credentials.apiKey + "&" + $.param(params);
  exports.listingSearch = getEtsyData.bind('null', 'listings/active');
  exports.listingTrending = getEtsyData.bind('null', 'listings/trending');
  exports.shopSearch = getEtsyData.bind('null', 'shops');
  exports.treasurySearch = getEtsyData.bind('null', 'treasuries');
  exports.userSearch = getEtsyData.bind('null', 'users');
  return exports;
}))(intel.xdk.services.credentials.Etsy,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.EventBrite = ((function (credentials, helpers) {
  var exports = {};
    return db.getItem('eventbrite_access_token');
    return message;
  function convertKey(params, base, updated){
    if(params[base]){
      var temp = params[base];
      delete params[base];
      params[updated] = temp;
    return params;
    var url ='https://www.eventbrite.com/oauth/authorize?';
    var urlParams = {
    return helpers.oauth2Implicit(url, urlParams)
      db.setItem('eventbrite_access_token', token);
      return token;
  exports.eventSearch = function(params){
    convertKey(params, "venue_city", "venue.city");
    convertKey(params, "start_date_keyword", "start_date.keyword");
    var urlParams = $.extend({token: token}, params);
    var completeUrl = 'https://www.eventbriteapi.com/v3/events/search/?' +  $.param(urlParams);
    return $.ajax({
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  return exports;
intel.xdk.services.iodocs_.OpenTable = ((function (credentials, helpers) {
  var exports = {};
      type = 'array';
      for (k in x) {
        var v = x;
          delete x;
        } else {
          jsonCleaner(v);
      return x;
  exports.stats = function (params) {
    var url = 'http://opentable.herokuapp.com/api/';
    url += 'stats';
  exports.cities = function (params) {
    url += 'cities';
  exports.restaurants = function (params) {
    url += 'restaurants';
  exports.restaurant_by_id = function (params) {
    url += 'restaurants/' + params.id;
    //if (params) url = url + '?' + $.param(params);
  return exports;
}))(intel.xdk.services.credentials.OpenTable,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.amazon_product_search = ((function (credentials, helpers) {
  var exports = {};
      type = 'array';
      for (var k in x) {
        var v = x;
          delete x;
        } else {
          jsonCleaner(v);
      return x;
    function sort_params(params)
        var keys = Object.keys(params);
        keys.sort();
        var newparams  ={}
        keys.forEach(function(k){ newparams = params; });
        return newparams;
    function timestamp(date) {
    //var date = new Date();
    var y = date.getUTCFullYear().toString();
    var m = (date.getUTCMonth() + 1).toString();
    var d = date.getUTCDate().toString();
    var h = date.getUTCHours().toString();
    var min = date.getUTCMinutes().toString();
    var s = date.getUTCSeconds().toString();
    if(m.length < 2) { m = "0" + m; }
    if(d.length < 2) { d = "0" + d; }
    if(h.length < 2) { h = "0" + h; }
    if(min.length < 2) { min = "0" + min; }
    if(s.length < 2) { s = "0" + s}
    var date = y + "-" + m + "-" + d;
    var time = h + ":" + min + ":" + s;
    return date + "T" + time + "Z";
    function sha256(stringToSign, secretKey)
        var hex = CryptoJS.HmacSHA256(stringToSign, secretKey);
        return hex.toString(CryptoJS.enc.Base64);
    function date_string(now)
        var date_str = now.toISOString().match(/[^T]*/)[0];
        return date_str.replace(/-/g, "");
    function get_aws_cs_function(operation)
                var url = 'http://webservices.amazon.com/onca/xml';
                params.Service = 'AWSECommerceService';
                params.Operation = operation;
                params.AWSAccessKeyId = credentials.apiKey;
                params.Timestamp = timestamp(now); //now.toISOString();
                params = sort_params(params);
                var paramString = $.param(params);
                var signingKey = "GET\n" + "webservices.amazon.com\n" + "/onca/xml\n" + paramString;
                var signature = sha256(signingKey, credentials.apiSecret);
                params.Signature = signature;
    exports.ItemSearch       = get_aws_cs_function('ItemSearch');
    exports.BrowseNodeLookup = get_aws_cs_function('BrowseNodeLookup');
    exports.ItemLookup       = get_aws_cs_function('ItemLookup');
    exports.SimilarityLookup = get_aws_cs_function('SimilarityLookup');
  exports.ItemSearch = function(params) {
    params.Operation = 'ItemSearch';
    function getAmazonItemInfo(barcode) {
    var PrivateKey = "";
    var PublicKey = "";
    var AssociateTag = "";
    var parameters = [];
    parameters.push("AWSAccessKeyId=" + PublicKey);
    parameters.push("ItemId=" + barcode);
    parameters.push("Operation=ItemLookup");
    parameters.push("Service=AWSECommerceService");
    parameters.push("Timestamp=" + encodeURIComponent(timestamp()));
    parameters.push("Version=2011-08-01");
parameters.push("AssociateTag=" + AssociateTag);
    parameters.sort();
    var paramString = parameters.join('&');
    var signature = sha256(signingKey,PrivateKey);
        signature = encodeURIComponent(signature);
    var amazonUrl =  "http://webservices.amazon.com/onca/xml?" + paramString + "&Signature=" + signature;
    console.log(amazonUrl);
  return exports;
}))(intel.xdk.services.credentials.amazon_product_search,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.youtube = ((function (credentials, helpers) {
  var exports = {};
  var aToken;
  var baseURL = 'https://www.googleapis.com/youtube/v3';
  function getList(path, params){
    var paramsExpanded = jsonCleaner(params);
    url = baseURL + '/' + path + '?' + $.param(paramsExpanded) + '&key=' + credentials.apiKey;
    /* authentication */
  function authenticate(params) {
    if (aToken) {
      d.resolve('Already authenticated');
      return d.promise();
    var url = {codeUrl: 'https://accounts.google.com/o/oauth2/auth?',
               tokenUrl: 'https://accounts.google.com/o/oauth2/token?'};
                        client_id: params.client_id,
                        response_type: params.response_type,
                        scope: params.scope_list,
                        access_type : 'offline'
                     token: {
      aToken = token;
      return token;
  function auth_post(func, params) {
    var authParams = {} //TODO
    return exports.authenticate(authParams)
    .then(function (youtube) {
      var paramIn = 'id=' + params.id + ',rating=' + params.rating;
      return youtube.videos().rate(paramIn);
      type = 'array';
      for (k in x) {
        var v = x;
          delete x;
        } else {
          jsonCleaner(v);
      return x;
  exports.authenticate = authenticate.bind(null);
  exports.rateVideos = auth_post.bind(null,'rateVideos');
  exports.listActivities = getList.bind(null,'activities');
  exports.listGuideCategories = getList.bind(null,'guideCategories');
  exports.listPlaylistItems = getList.bind(null,'playlistItems');
  exports.listPlaylists = getList.bind(null,'playlists');
  exports.listSearch = getList.bind(null,'search');
  exports.listVideos = getList.bind(null,'videos');
  return exports;
}))(intel.xdk.services.credentials.youtube,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.github = ((function (credentials, helpers) {
  var exports = {};
    var url = {
      codeUrl: 'https://github.com/login/oauth/authorize?',
      tokenUrl: 'https://github.com/login/oauth/access_token?'
    var urlParams = {
      code: {
        scope: params.scope
      token: {
      db.setItem('github_access_token', token);
      return token;
  function getNotifications(path, params){
    var token = window.localStorage.getItem('github_access_token');
    if (!token) return 'Need access token before making call';
    var completeUrl = 'https://api.github.com/' + path + '?' + $.param(urlParams);
    return $.ajax({
      headers: {
        Accept : "application/vnd.github.v3+json"
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
      return err.responseText;
  function getRepoNotifications(path, params){
    var owner = params.owner;
    var repo = params.repo;
    delete params.owner;
    delete params.repo;
    var completeUrl = 'https://api.github.com/repos/' + owner + '/' + repo + '/' + path + '?' + $.param(urlParams);
    return $.ajax({
      headers: {
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  function getEvents(params){
    var completeUrl = 'https://api.github.com/events';
    return $.ajax({
      headers: {
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  function getRepoEvents(params){
    var completeUrl = 'https://api.github.com/repos/' + owner + '/' + repo + '/events';
    return $.ajax({
      headers: {
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  function getIssueEvents(params){
    var completeUrl = 'https://api.github.com/repos/' + owner + '/' + repo + '/issues/events';
    return $.ajax({
      headers: {
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  function getUserReceivedEvents(params){
    var username = params.username;
    var completeUrl = 'https://api.github.com/users/' + username + '/received_events';
    return $.ajax({
      headers: {
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  function getUserPerformedEvents(params){
    var completeUrl = 'https://api.github.com/users/' + username + '/events';
    return $.ajax({
      headers: {
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  function getIssues(params){
    var completeUrl = 'https://api.github.com/issues' + '?' + $.param(urlParams);
    return $.ajax({
      headers: {
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  function getRepos(params){
    var completeUrl = 'https://api.github.com/user/repos' + '?' + $.param(urlParams);
    return $.ajax({
      headers: {
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  function getUserRepos(params){
    var completeUrl = 'https://api.github.com/users/' + username + '/repos';
    return $.ajax({
      headers: {
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  function getAllRepos(params){
    var completeUrl = 'https://api.github.com/repositories' + '?' + $.param(params);
    return $.ajax({
      headers: {
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  function searchRepositories(params){
    if(token) {
      params = $.extend({access_token: token}, params);
    var completeUrl = 'https://api.github.com/search/repositories' + '?' + $.param(params);
    return $.ajax({
      headers: {
      url: completeUrl,
      type: 'GET',
      dataType: 'json'})
      return response;
  exports.getNotifications = getNotifications.bind(null, 'notifications');
  exports.getEvents = getEvents.bind(null);
  exports.getRepoEvents = getRepoEvents.bind(null);
  exports.getIssueEvents = getIssueEvents.bind(null);
  exports.getUserReceivedEvents = getUserReceivedEvents.bind(null);
  exports.getUserPerformedEvents = getUserPerformedEvents.bind(null);
  exports.getIssues = getIssues.bind(null);
  exports.getRepos = getRepos.bind(null);
  exports.getUserRepos = getUserRepos.bind(null);
  exports.getAllRepos = getAllRepos.bind(null);
  exports.searchRepositories = searchRepositories.bind(null);
  return exports;
}))(intel.xdk.services.credentials.github,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.UPS = ((function (credentials, helpers) {
  var exports = {};
  function createRequest(){
  function createAccessSubstr(account_no, user_id, password){
      return '<?xml version="1.0"?><AccessRequest xml:lang="en-US"><AccessLicenseNumber>'+ account_no + '</AccessLicenseNumber>            <UserId>'+ user_id +'</UserId><Password>' + password +'</Password></AccessRequest>';
  function createRequestTypeSubstr(request_type, customer_context, request_action, request_option, request_details_string){
      return '<?xml version="1.0"?><'+ request_type+ ' xml:lang="en-US"><Request><TransactionReference><CustomerContext>' + customer_context + '</CustomerContext><XpciVersion>1.0</XpciVersion></TransactionReference><RequestAction>'+ request_action +'</RequestAction><RequestOption>'+ request_option +'</RequestOption></Request>' + request_details_string + '</'+request_type+'>';
  exports.tracking = function (params) {
    var url = 'https://www.ups.com/ups.app/xml/Track' ;
      var request_type = 'TrackRequest';
      var customer_context = 'QAST Track';
      var request_action = 'Track';
      var request_option = 'activity';
      var access_string = createAccessSubstr(params.account_no, params.user_id, params.password);
      var request_details_string = '<TrackingNumber>' + params.tracking_no +'</TrackingNumber>';
      var request_string = createRequestTypeSubstr(request_type, customer_context, request_action, request_option, request_details_string);
      var xml_req = access_string + request_string;
                   data: xml_req,
                   type: 'POST'
  exports.address_validation = function (params) {
    var url = 'https://www.ups.com/ups.app/xml/AV' ;
    var request_type = 'AddressValidationRequest';
    var customer_context = 'Maryam Dennis-Customer Data';
    var request_action = 'AV';
      var request_option = '';
      var request_details_string = '<Address><City>' + params.city +'</City><StateProvinceCode>' + params.StateProvinceCode + '</StateProvinceCode></Address>';
                   data: xml_req,
                   type: 'POST'
    exports.street_address_validation = function (params) {
    var url = 'https://www.ups.com/ups.app/xml/XAV' ;
    var customer_context = '';
    var request_action = 'XAV';
      var request_option = '3';
      var request_details_string = '<AddressKeyFormat><AddressLine>' + params.address_line1 +'</AddressLine><AddressLine>' + params.address_line2 +'</AddressLine><PostCodePrimaryLow>' + params.postcode_primary + '</PostCodePrimaryLow><CountryCode>'+ params.country_code +'</CountryCode></AddressKeyFormat>';
                   data: xml_req,
                   type: 'POST'
    exports.locator = function (params) {
    var url = 'https://www.ups.com/ups.app/xml/Locator' ;
    var request_type = 'LocatorRequest';
    var request_action = 'Locator';
      var request_option = '1';
      var request_details_string = '<OriginAddress><AddressKeyFormat><AddressLine>' + params.address_line1 +'</AddressLine><AddressLine>' + params.address_line2 +'</AddressLine><PostCodePrimaryLow>' + params.postcode_primary + '</PostCodePrimaryLow><CountryCode>'+ params.country_code +'</CountryCode></AddressKeyFormat></OriginAddress>';
        request_details_string = request_details_string + '<Translate><LanguageCode>ENG</LanguageCode></Translate>';
        request_details_string = request_details_string + '<LocationSearchCriteria><SearchOption><OptionType><Code>' + params.search_criteria + '</Code></OptionType></SearchOption></LocationSearchCriteria>';
      var xml_req = access_string + request_string ;
                   data: xml_req,
                   type: 'POST'
  return exports;
}))(intel.xdk.services.credentials.UPS,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.RSS = ((function (credentials, helpers) {
  var exports = {};
  exports.Request = function (params) {
    return $.ajax(params);
  return exports;
}))(intel.xdk.services.credentials.RSS,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.centralIndex = ((function (credentials, helpers) {
  var exports = {};
  var baseUrl = 'http://api.centralindex.com';
  function getCentralIndexData(type, path, params) {
    console.log(credentials.apiKey);
    var url = baseUrl + path + '?api_key=' + credentials.apiKey + $.param(params);
    return $.ajax({
      type: type,
      url: url
  exports.advertiserUpdated =  getCentralIndexData.bind(null, 'GET', '/v1/advertiser/updated');
  exports.autocompleteCategory = getCentralIndexData.bind(null, 'GET', '/v1/autocomplete/category');
  exports.autocompleteKeyword = getCentralIndexData.bind(null, 'GET', '/v1/autocomplete/keyword');
  exports.autocompleteLocation = getCentralIndexData.bind(null, 'GET', '/v1/autocomplete/location');
  exports.entity = getCentralIndexData.bind(null, 'GET', '/v1/entity');
  exports.entityAdvertisers = getCentralIndexData.bind(null, 'GET', '/v1/entity/advertisers');
  exports.entitySupplier = getCentralIndexData.bind(null, 'GET', '/v1/entity/by_supplier_id');
  exports.entitySearchKeywordNearest = getCentralIndexData.bind(null, 'GET', '/v1/entity/search/keyword/bynearest');
  exports.entitySearchWhat = getCentralIndexData.bind(null, 'GET', '/v1/entity/search/what');
  exports.entitySeatchWhatLocation = getCentralIndexData.bind(null, 'GET', '/v1/entity/search/what/bylocation');
  exports.entitySearchWhatBoundingBox = getCentralIndexData.bind(null, 'GET', '/v1/entity/search/what/byboundingbox');
  exports.entitySearchWhatNearest = getCentralIndexData.bind(null, 'GET', '/v1/entity/search/what/bynearest');
  exports.entitySearchWho = getCentralIndexData.bind(null, 'GET', '/v1/entity/search/what/bylocation');
  exports.entitySearchWhoLocation = getCentralIndexData.bind(null, 'GET', '/v1/entity/search/who/bylocation');
  exports.entitySearchWhatBoundingBox = getCentralIndexData.bind(null, 'GET', '/v1/entity/search/who/byboundingbox');
  exports.entitySearchWhatNearest = getCentralIndexData.bind(null, 'GET', '/v1/entity/search/who/bynearest');
  exports.locationContext = getCentralIndexData.bind(null, 'GET', '/v1/location/context');
  return exports;
}))(intel.xdk.services.credentials.centralIndex,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.twitter = ((function (credentials, helpers) {
  var exports = {};
      type = 'array';
      for (k in x) {
        var v = x;
          delete x;
        } else {
          jsonCleaner(v);
      return x;
    return db.getItem('twitter_access_token');
    var url = 'https://api.twitter.com/oauth2/token';
    var rfcConsumerKey = credentials.apiKey;
    var rfcConsumerSecret = credentials.apiSecret;
    var bearerToken = rfcConsumerKey + ':' + rfcConsumerSecret;
    var b64BearerToken = btoa(bearerToken);
    var header = 'Basic ' + b64BearerToken;
    var twitParams = {};
    return helpers.oauth2CC(url, twitParams, header)
    .then(function(response){
      db.setItem('twitter_access_token', response.access_token);
      return response.access_token;
      console.log(JSON.stringify(err));
  /* Timelines */
  exports.user_timeline = function(params) {
    var header = 'Bearer ' + token;
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/statuses/user_timeline.json?' + $.param(params),
      headers: {
        'Authorization': header
      return response;
  /* Tweets */
  exports.get_retweets = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/statuses/retweets/' + params.id + '.json?' + $.param(params),
      headers: {
      return response;
  exports.get_tweets = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/statuses/show.json?' + $.param(params),
      headers: {
      return response;
  exports.get_retweeters = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/statuses/retweeters/ids.json?' + $.param(params),
      headers: {
      return response;
  exports.search_tweets = function(params) {
    params.q = encodeURIComponent(params.q);
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/search/tweets.json?' + $.param(params),
      headers: {
      return response;
  /* Friends & Followers */
  exports.get_friends = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/friends/ids.json?' + $.param(params),
      headers: {
      return response;
  exports.get_followers = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/followers/ids.json?' + $.param(params),
      headers: {
      return response;
  exports.show_friendship = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/friendships/show.json?' + $.param(params),
      headers: {
      return response;
  exports.get_friend_list = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/friends/list.json?' + $.param(params),
      headers: {
      return response;
  /* Users */
  exports.lookup_user = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/users/lookup.json?' + $.param(params),
      headers: {
      return response;
  exports.show_user = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/users/show.json?' + $.param(params),
      headers: {
      return response;
  /* Lists */
  exports.get_user_lists = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/lists/list.json?' + $.param(params),
      headers: {
      return response;
  exports.get_list_statuses = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/lists/statuses.json?' + $.param(params),
      headers: {
      return response;
  exports.get_list_memberships = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/lists/memberships.json?' + $.param(params),
      headers: {
      return response;
  exports.get_list_subscribers = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/lists/subscribers.json?' + $.param(params),
      headers: {
      return response;
  exports.get_list_members = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/lists/members.json?' + $.param(params),
      headers: {
      return response;
  exports.get_list = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/lists/show.json?' + $.param(params),
      headers: {
      return response;
  /* Trends */
  exports.get_trends_place = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/trends/place.json?' + $.param(params),
      headers: {
      return response;
  exports.get_trends_available = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/trends/available.json?' + $.param(params),
      headers: {
      return response;
  exports.get_trends_closest = function(params) {
    return $.ajax({
      type: 'GET',
      url: 'https://api.twitter.com/1.1/trends/closest.json?' + $.param(params),
      headers: {
      return response;
  return exports;
}))(intel.xdk.services.credentials.twitter,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.edmunds = ((function (credentials, helpers) {
  var exports = {};
    function make_request(params, url)
        params.fmt     = 'json';
    function by_id_function(url_str, post_url)
            var id = params.id;
            delete params.id;
            var url = url_str + id + (post_url || '');
            return make_request(params, url);
    function by_style_zip_function(url_str)
         return function (params)
             var styleid = params.styleid;
             var zip     = params.zip;
             delete params.styleid;
             delete params.zip
             var url = url_str + styleid + '/' + zip;
    function by_args_function(url_str, args, post_url)
             var url = url_str;
             for(var i=0; i< args.length; i++)
                 var val = params[args];
                 delete params[args];
                 url += '/' + val;
             url += (post_url || '');
    function by_url_function(url)
  // VEHICLE MAKE
  exports.GetAllMakes = by_url_function('https://api.edmunds.com/api/vehicle/v2/makes');
  exports.CarDetailsByName = function (params) {
    var make = params.make;
    delete params.make;
    var url = 'https://api.edmunds.com/api/vehicle/v2/' + make ;
  exports.GetMakesCount = by_url_function('https://api.edmunds.com/api/vehicle/v2/makes/count');
  //VEHICLE MODEL
  exports.DetailsByMakeAndModel = function (params) {
    var model  = params.model;
    delete params.make;
    delete params.model;
    var url = 'https://api.edmunds.com/api/vehicle/v2/' + make + '/' + model ;
  exports.GetAllCarModelsByCarMake = function (params) {
    delete params.make;
    var url = 'https://api.edmunds.com/api/vehicle/v2/' + make + '/models' ;
  exports.GetCarModelsCount = function (params) {
    delete params.make;
    var url = 'https://api.edmunds.com/api/vehicle/v2/' + make + '/models/count' ;
  //VEHICLE MODEL YEAR
  exports.GetCarModelYearByCarMakeAndModel = function (params) {
    delete params.make;
    var url = 'https://api.edmunds.com/api/vehicle/v2/' + make + '/' + model + '/years';
  exports.GetInfoByCarMakeAndModelAndCarYear = function (params) {
    var year   = params.year;
    delete params.make;
    delete params.year;
    var url = 'https://api.edmunds.com/api/vehicle/v2/' + make + '/' + model + '/' + year;
  exports.GetCarModelYearsCountByMakeAndModel = function (params) {
    delete params.make;
    var url = 'https://api.edmunds.com/api/vehicle/v2/' + make + '/' + model + '/years/count';
  //VEHICLE STYLE
  exports.GetStyleDetails = by_id_function('https://api.edmunds.com/api/vehicle/v2/styles/');
  exports.GetStyleDetailsByMakeModelYear = function (params) {
    delete params.make;
    delete params.year;
    var url = 'https://api.edmunds.com/api/vehicle/v2/' + make + '/' + model + '/' + year + '/styles';
  exports.GetStylesCountByMakeModelYear = function (params) {
    delete params.make;
    delete params.year;
    var url = 'https://api.edmunds.com/api/vehicle/v2/' + make + '/' + model + '/' + year + '/styles/count';
  exports.GetStylesCountByMakeModel = function (params) {
    delete params.make;
    var url = 'https://api.edmunds.com/api/vehicle/v2/' + make + '/' + model + '/' + '/styles/count';
   exports.GetStylesCountByMake = function (params) {
    delete params.make;
    var url = 'https://api.edmunds.com/api/vehicle/v2/' + make +  '/styles/count';
  exports.GetStylesCount = by_url_function('https://api.edmunds.com/api/vehicle/v2/styles/count');
  exports.GetStylesDetailsByVehicleChromeID = function (params) {
    var chromeid   = params.chromeid;
    delete params.chromeid;
    var url = 'https://api.edmunds.com/api/vehicle/v2/partners/chrome/styles/' + chromeid;
  exports.GetListOfOptionsByStyleID    = by_id_function('https://api.edmunds.com/api/vehicle/v2/styles/', '/options');
  exports.GetOptionsDetailsByID        = by_id_function('https://api.edmunds.com/api/vehicle/v2/options/');
  exports.GetListOfColorsByStyleID     = by_id_function('https://api.edmunds.com/api/vehicle/v2/styles/', '/colors');
  exports.GetColorDetailsByID          = by_id_function('https://api.edmunds.com/api/vehicle/v2/colors/');
  exports.GetEnginesByStyleID          = by_id_function('https://api.edmunds.com/api/vehicle/v2/styles/', '/engines');
  exports.GetEnginesDetailsByID        = by_id_function('https://api.edmunds.com/api/vehicle/v2/engines/');
  exports.GetTransmissionsByStyleID    = by_id_function('https://api.edmunds.com/api/vehicle/v2/styles/', '/transmissions' );
  exports.GetTransmissionDetailsByID   = by_id_function('https://api.edmunds.com/api/vehicle/v2/transmissions/');
  exports.GetEquipmentDetailsByStyleID = by_id_function('https://api.edmunds.com/api/vehicle/v2/styles/', '/equipment');
  exports.GetEquipmentDetailsByID      = by_id_function('https://api.edmunds.com/api/vehicle/v2/equipment/');
  exports.GetVehicleDetailsBySquishVIN = by_id_function('https://api.edmunds.com/api/vehicle/v2/squishvins/');
  exports.GetConfiguredVehicleByZipAndStyle = by_url_function('https://api.edmunds.com/v1/api/configurator/default');
  exports.GetConfiguredVehicleWithOptions   = by_url_function('https://api.edmunds.com/v1/api/configurator/withOptions');
  exports.GetPhotoByStyleID = function (params) {
    var url = 'https://api.edmunds.com/v1/api/vehiclephoto/service/findphotosbystyleid';
    //the final request has URL partials in it. I'd love to reconstruct a full image URL from them,
    //but can't find the docs for how to do so.
 exports.NewTCObyStyleAndZip             = by_style_zip_function('https://api.edmunds.com/v1/api/tco/newtruecosttoownbystyleidandzip/');
 exports.UsedTCObyStyleAndZip            = by_style_zip_function('https://api.edmunds.com/v1/api/tco/usedtruecosttoownbystyleidandzip/');
 exports.NewTotalCashPriceByStyleAndZip  = by_style_zip_function('https://api.edmunds.com/v1/api/tco/newtotalcashpricebystyleidandzip/');
 exports.UsedTotalCashPriceByStyleAndZip = by_style_zip_function('https://api.edmunds.com/v1/api/tco/usedtotalcashpricebystyleidandzip/');
 exports.GetVehicleMakesWithTCOdata      = by_url_function('https://api.edmunds.com/v1/api/tco/getmakeswithtcodata');
 exports.GetVehicleModelsWithTCOdata     = by_url_function('https://api.edmunds.com/v1/api/tco/getmodelswithtcodata');
 exports.GetVehicleStylesWithTCOdata     = by_url_function('https://api.edmunds.com/v1/api/tco/getstyleswithtcodatabysubmodel');
 exports.AllNewTCObyStyleAndZipAndState  = by_args_function('https://api.edmunds.com/api/tco/v1/details/allnewtcobystyleidzipandstate', ['styleid', 'zip', 'state']);
 exports.AllUsedTCObyStyleAndZipAndState = by_args_function('https://api.edmunds.com/api/tco/v1/details/allusedtcobystyleidzipandstate', ['styleid', 'zip', 'state']);
 exports.TMVforNameYearMSRPandZip = by_args_function('https://api.edmunds.com/api/v1/vehicle', ['make', 'year'], '/price');
 exports.TMVforVINandMSRPandZip   = by_args_function('https://api.edmunds.com/api/v1/vehicle/vin', ['vin'], '/price');
 exports.TMVforStyleAndZip        = by_url_function('https://api.edmunds.com/v1/api/tmv/tmvservice/calculatenewtmv');
 exports.TMVforUsed               = by_url_function('https://api.edmunds.com/v1/api/tmv/tmvservice/calculateusedtmv');
 exports.TMVforTypical            = by_url_function('https://api.edmunds.com/v1/api/tmv/tmvservice/calculatetypicallyequippedusedtmv');
 exports.TMV_Certified            = by_url_function('https://api.edmunds.com/v1/api/tmv/tmvservice/findcertifiedpriceforstyle');
 exports.GetRatingByMakeModelYear = by_args_function('https://api.edmunds.com/api/vehicle/v2/grade', ['make', 'model', 'year']);
 exports.GetRatingByStyle         = by_args_function('https://api.edmunds.com/api/vehicle/v2/grade', ['styleid']);
 exports.GetReviewByMakeModelYear = by_args_function('https://api.edmunds.com/api/vehiclereviews/v2/', ['make', 'model', 'year']);
 exports.GetReviewByStyle         = by_args_function('https://api.edmunds.com/api/vehiclereviews/v2/styles', ['styleid']);
  return exports;
}))(intel.xdk.services.credentials.edmunds,intel.xdk.services.iodocs_.helpers);
intel.xdk.services.iodocs_.Holizon = ((function (credentials, helpers) {
  var exports = {};
  exports.itemAdd = function(params) {
    var url = 'http://localhost:8080/Holizon_Ghome/webresources/Item/AddItem';
    url = url + '/' + params.masterItemId+ '/'+ params.UUID+'/';
    var parameters = "name="+params.name+"&state="+params.state+"&itemType_itemTypeId="+params.itemType_itemTypeId+"&usageType_usageTypeId="+params.usageType_usageTypeId+"&status_statusId="+params.status_statusId;
    url = url + parameters;
    return $.ajax({url: url, type:  'PUT'});
  return exports;
})  )(intel.xdk.services.credentials.Holizon,intel.xdk.services.iodocs_.helpers);
PaulF_IntelCorp
I'll file a bug with our web services team letting them know. In the meantime, you can always make the corrections to the file yourself and simply use your copy of the library. The web services library is provided as a convenience, you are not required to use it if you understand how to make the AJAX calls yourself.
Chris_P_Intel
Thanks for reporting this. It was a problem on the server. It should be working now.  If not, let me know.
Yetiskan_E_
Ok it is working now. Thanks
