Software Archive
Read-only legacy content
17060 Discussions
can notebook select conda kernels ?
JWill45
I have my own conda env which I need to use in Jupyter notebook . But Jupyter notebook seems only apply intel built-in python kernels, can anyone tell me how to make conda kernels available?
Hi Jake,
I would recommend you try out the solution provided below:
source activate  conda install ipykernel ipython kernel install --name --user
Once this is done, launch your python code from hub.colfaxresearch.com
Select Kernel -> Change Kernel ->
Do try out and check if this works!
Sandhiya
Hi Jake,
Sandhiya
JWill45
