For some reason, whenever I have a spawn and sync inside a cilk_for it seems as though the spawn does not get recognized. I end up getting a compile time error of Expected _Cilk_spawn before _Cilk_sync. As an example consider the following (overly simple) program:
void foo(){ cout << "foo"; } void bar(){ cout << "bar"; } void baz(){ cout << "baz"; } int main(){ cilk_for(int i-0; i<10; i++){ cilk_spawn foo(); bar(); cilk_sync; baz(); } }
If I try to compile this I get the above mentioned error. Does anyone have any idea as to why this might be happening and/or how I can solve it. (If I move the spawn and sync into a separate helper method it solves the problem, but unfortunately in my real use case it would mean passing a lot of variables by pointer.) I am using g++ 4.8.1 with cilkplus.
Thanks!
- Meir
It's a bug in the gcc implementation. icc compiled it without complaint (after I fixed the "int i-0" typo and added the obvious includes/using). I'll try to get this reported to the code maintainer.
Yes, this looks like a bug in GCC's Cilkplus branch. Unfortunately there are no plans to support separate branches anymnore since now we are integrating Cilk_for support into the GCC trunk (it will be version 5.0) thus all Cilk+ features will be there together. Of course, we will make sure that given test works in the trunk after we finish integration
