hi,
i have installed xeon phi dev env on windows 7 enterpise X64 on a dell R7610
first (I):
i have installed MPSS3.2.1
sometimes after PC starts the xeon phi is not seen in the windows device manager
after desintall / reinstall MPSS => it 's ok the xeon phi is seen
second (II)
i try to make a personal benchmark using CAO offload mode. (FFT with MKL and FFTW3 )
i generate a 64 bits exe with visual studio and intel c++ 14.0
but in the execution i got an :
"offload error : cannot find offload entry" during the OFFLOADREPORT trace
when i used visual studio 2012 which call intel C++ 14.0 compiler threre's some
options offloading in both
- intel specific compilation : "offload otions"
- intel specific link : "offload options"
i set also "mandatory"
do i need to specify someting in these compilation setting for CAO? or let it blank?
see https://software.intel.com/en-us/node/463638
offload options topic
thanks
bertrand
I gather from your comments the uninstall/re-install of MPSS resolved the issue with coprocessors not being recognized.
The run-time error you noted suggests that a routine was referenced during the offload that was not decorated accordingly to declare it available during offload. To help determine that routine, under the IDE, you can use the Additional Options for MIC Offload Linker option and set the value to: -zdefs
This should provide an indication at link-time of the routine that requires decoration with: __declspec(target (mic))
Using MKL’s CAO feature does not require any specific settings under the offload options you noted.
I do know whether this would be of interest/need. The article Intel® Math Kernel Library (Intel MKL) Compiler Assisted Offload and Automatic Offload example on Intel Xeon Phi contains more information.
If you have not already seen this, there is specific section in the MKL User’s Guide on Compiler Assisted Offload.
