Software Archive
Read-only legacy content
17060 Discussions
hInst in COM server
rahzan
A section in the doc discusses getting hInst in dllmain for dialog boxes. I;d like to know if this also applies to COM servers and if so, where in the general scheme of files does the Dllmain go?
Thanks, Tim
Intel_C_Intel
Yes, it does apply to DLL COM servers. Dllmain is in a file generated by the wizard, DLLMAIN.F90. That routine saves the hinst in a module, DllGlobal, in a variable named ghinst. In your code, you should be able to USE DllGlobal and get the value from ghinst.
Leo
rahzan
Sorry, this seems a little 'too" easy! so I have to check:
So all one needs is to stick in a "use dllglobal" in wherever needed and use the variable ghinst in the for hInst.
Tim
Intel_C_Intel
Correct!
Leo
