Community
cancel
Showing results for
Search instead for
Did you mean:
Mark_N_
how to make an config.xml from intelxdk.config.*.xml files
I'm trying to move my xdk project to a different platform however the project is missing a config.xml. I understand that the config file is created on demand for the cordova build. On the new platform it is not. How does the xdk make the config file. is there anyway to capture that file? what parts of the intel.config.*.xml files make up the config file?
Tags (2)
PaulF_IntelCorp
Mark -- we are working on a config.xml export. Until then, use this quick summary as a starting point > https://software.intel.com/en-us/forums/intel-xdk/topic/685326#comment-1885441 < and come back here with additional questions. If you are already familiar with Cordova CLI it should be pretty straightforward, if not, you'll probably have a few questions.
