Hello
There are two problems
1. Format of the video file is said h.264, but the file name what? I used mp4, h264, avi have to file, but they can not be opened will be displayed incorrectly formatted
2. How to achieve real-time video, now click on the button to display a screen can not be real-time display
private void button4_Click(object sender, EventArgs e) { // RecordORPlayback(@"C:\RecordTemp\" + DateTime.Now.ToString("yyyyMMddHHmmss") + ".h264", true); RecordORPlayback(@"C:\RecordTemp\" + DateTime.Now.ToString("yyyyMMddHHmmss") + ".mp4", true); } void RecordORPlayback(String file, Boolean record) { PXCMSenseManager sm = PXCMSenseManager.CreateInstance(); sm.captureManager.SetFileName(file, record); //sm.EnableStream(PXCMCapture.StreamType.STREAM_TYPE_COLOR, 640, 480, 0); sm.EnableStream(PXCMCapture.StreamType.STREAM_TYPE_COLOR, 640, 480); sm.captureManager.SetRealtime(true); sm.Init(); //for (int i = 0; i < 300; i++) //{ //Console.WriteLine(i); if (sm.AcquireFrame(true).IsError()) { } PXCMCapture.Sample sample = sm.QuerySample(); PXCMImage image = sample.color; PXCMImage dimage = sample.depth; PXCMImage.ImageData data; image.AcquireAccess( PXCMImage.Access.ACCESS_READ, PXCMImage.PixelFormat.PIXEL_FORMAT_RGB32, out data); Bitmap bm = data.ToBitmap(0, image.info.width, image.info.height); pictureBox1.Image = bm; sm.ReleaseFrame(); //} sm.Dispose(); }
video format is rssdk
but how to open this file ?
You have to use the SDK to view it. If you pass your RecordORPlayback method the filename of the video you saved and false, that should do it!
Yes i use RecordORPlayback method and change filename is .rssdk
RecordORPlayback(@"C:\RecordTemp\" + DateTime.Now.ToString("yyyyMMddHHmmss") + ".rssdk", true);
But how can I go to verify my video is correct? Or what I by reference the document?
If you call:
RecordORPlayback(
@"C:\RecordTemp\%name of file already saved%
.rssdk",
false
And run it, your app should play it back.
Alternatively, you could use the Raw Streams sample in Playback mode to view your video.
