Plugin: com.hutchind.cordova.plugins.launcher
version: 0.22
XDK works fine compiling for android but with iOS compiler it doesn't work.
https://github.com/nchutchind/App-Launcher-Cordova-Plugin
They wrote: iOS: Copy Launcher.h
and Launcher.m
to platforms/ios/<ProjectName>/Plugins
Maybe this is the problem?
I can't do anything by my side?
Gianluca
- Tags:
- HTML5
- Intel® XDK
Can you attach the log generated from iOS build?
It's a compatibility issue with the plugin.
There is an open issue about the same compile error:
Try contacting the plugin developer
Topic Options
