Software Archive
Read-only legacy content
17061 Discussions
ialmrnt5 driver error
h_christine_73
Débutant
21 071 Visites
I am receiving an error.
Windows - Display Driver Stopped Responding.
The ialmrnt5 display driver has stopped working normally. Save yourwork and reboot the system to restore full display functionality. The next time you reboot the machine a dialog will be displayed giving you a chance to upload data about this failure to microsoft.
I tried downloading the most recent driver version from this site.
It's not working. Please help!
Thanks!
0 Compliments
82 Réponses
www_tgmduman
Débutant
7 273 Visites
Ihave the same problem. I dont know what I CAN DO. IF YOU HAVE FOUND A WAY PLEASE SEND E MEAL ABOUT.
0 Compliments
cher13ie
Débutant
7 273 Visites
Friday, February 09, 2007
shlew03
Thank you so much!! This worked for me so far. Tried a game I downloaded that blew my computer to the ialmrnt5 display driver error and yipee it worked. This has been driving me nuts for months. smiley [:-)]
0 Compliments
mistix
Débutant
7 273 Visites
I am having the same problem, but my chip set is different from others that are finding fixes..I have 82945G, I updated and still had the same problem. We are not playing WOW, but all the games we do play are doing the same as you WOW players. Anyone that has a suggestion of what we can do to fix this 'stupid' issue,,,I would be most appreciative.
0 Compliments
mistix
Débutant
7 273 Visites
Ok, an update, I tried versions 4497, problems still exists, tried version4342 and it wouldn't intall, tried version 3943 and it wouldn't install...I'm at a loss and having gaming withdraw.Angry smiley [:@]
0 Compliments
davistje
Débutant
7 273 Visites
I have been having the same problem aswell... except I am not playing any games other than online poker. Computer can be fine for hours that bam display driver crashes or I can be online playing for 30 mins and it will do it. My graphics chipset is thr 865G series. I have update the drivers to the newest ones and have also tried previously mentioned older version to without any joy, in fact the older driver game me a BSoD.
I also have an ATI 9600 Radeon that I have since stopped using since I was having much more problems with it. Going back to the onboard Intel 865G has reduced my problems however the problem persists. I though maybe it was my RAM however since i had the problem since before I upgraded all my RAM to OCZ Technologies' Dual Channel Premium/Performance series of RAM.
I am at a lost as to what maybe causing this problem! Hardware? Driver?
When I installed the old drivers and tried them and when I installed the new drivers I used the -overwrite switch when I ran setup to make sure it was overwriting older .dll's etc...
I have done sever searches online and find that we are not alone in this problem! However I have not found a solution that solves the problem.
I will follow up with some debug logs
0 Compliments
davistje
Débutant
7 273 Visites
Probably caused by : ialmdev5.DLL ( ialmdev5!GHALGetFctTable+5c66 )
Followup: MachineOwner
1: kd> !analyze -v;r;kv;lmtn;.logclose;q
* Bugcheck Analysis *
THREAD_STUCK_IN_DEVICE_DRIVER (ea)
The device driver is spinning in an infinite loop, most likely waiting for
hardware to become idle. This usually indicates problem with the hardware
itself or with the device driver programming the hardware incorrectly.
If the kernel debugger is connected and running when watchdog detects a
timeout condition then DbgBreakPoint() will be called instead of KeBugCheckEx()
and detailed message including bugcheck arguments will be printed to the
debugger. This way we can identify an offending thread, set breakpoints in it,
and hit go to return to the spinning code to debug it further. Because
KeBugCheckEx() is not called the .bugcheck directive will not return bugcheck
information in this case. The arguments are already printed out to the kernel
debugger. You can also retrieve them from a global variable via
"dd watchdog!g_WdBugCheckData l5" (use dq on NT64).
On MP machines (OS builds <= 3790) it is possible to hit a timeout when the spinning thread is
interrupted by hardware interrupt and ISR or DPC routine is running at the time
of the bugcheck (this is because the timeout's work item can be delivered and
handled on the second CPU and the same time). If this is the case you will have
to look deeper at the offending thread's stack (e.g. using dds) to determine
spinning code which caused the timeout to occur.
Arguments:
Arg1: 8917b020, Pointer to a stuck thread object. Do .thread then kb on it to find
the hung location.
Arg2: 89aea038, Pointer to a DEFERRED_WATCHDOG object.
Arg3: 896ebce8, Pointer to offending driver name.
Arg4: 00000001, Number of times this error occurred. If a debugger is attached,
this error is not always fatal -- see DESCRIPTION below. On the
blue screen, this wi ll always equal 1.
Debugging Details:
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: watchdog!_DEFERRED_WATCHDOG ***
***& nbsp; ***
FAULTING_THREAD: 8917b020
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_FAULT
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0xEA
PROCESS_NAME: OUTLOOK.exe
LAST_CONTROL_TRANSFER: from bfa20b81 to bfa2a436
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
b08ef3b8 bfa20b81 89745000 4edfede1 f793b000 ialmdev5!GHALGetFctTable+0x5c66
b08ef3d4 bfa20bde f793b000 00000000 e18872a0 ialmdev5!GmmGetFctTable+0x17961
b08ef40c bf9edfec e1818018 e1818018 b08ef430 ialmdev5!GmmGetFctTable+0x179be
b08ef41c bf9f7d63 e18872a0 00000000 00000000 ialmdnt5!DrvEnableDriver+0xe4c
b08ef430 bf9da231 e18872a0 00000000 00000000 ialmdnt5!OsFreeMem+0x3c82
b08ef44c bf8bdbb1 e18872a0 00000000 00000000 ialmrnt5+0x6231
b08ef488 bf8056e7 e18872a0 00000000 00000000 win32k!WatchdogDrvSynchronizeSurface+0x57
b08ef49c bf839c40 e18872a0 00000000 00000000 win32k!PDEVOBJ::vSync+0x36
b08ef6b8 bf9e4ee1 e108a2c0 e182f008 00000000 win32k!EngCopyBits+0x103
b08ef6e0 bf9e4ba7 e108a2c0 e18872a0 00000000 ialmdnt5+0x2ee1
b08efb18 bf9f762a e108a2c0 e18872a0 00000000 ialmdnt5+0x2ba7
b08efb40 bf9d9bf1 e108a2c0 e18872a0 00000000 ialmdnt5!OsFreeMem+0x3549
b08efbf8 bf805d3a e108a2c0 e18872a0 00000000 ialmrnt5+0x5bf1
b08efc44 bf849265 e108a2c0 e18872a0 00000000 win32k!WatchdogDrvCopyBits+0x53
b08efd50 804dd99f e12c2008 00000000 00000189 win32k!NtGdiGetPixel+0x1b2
b08efd50 7c90eb94 e12c2008 00000000 00000189 nt!KiFastCallEntry+0xfc
0013e06c 00000000 00000000 00000000 00000000 0x7c90eb94
STACK_COMMAND: .thread 0xffffffff8917b020 ; kb
FOLLOWUP_IP:
bfa2a436 8bc3 mov eax,ebx
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: ialmdev5!GHALGetFctTable+5c66
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: ialmdev5
IMAGE_NAME: ialmdev5.DLL
DEBUG_FLR_IMAGE_TIMESTAMP: 43304c54
FAILURE_BUCKET_ID: 0xEA_IMAGE_ialmdev5.DLL_DATE_2005_09_20
eax=00000000 ebx=4edfede1 ecx=10dfede1 edx=3e000000 esi=00000001 edi=89745000
eip=bfa2a436 esp=b08ef3b0 ebp=89745000 iopl=0 nv up ei pl nz na po nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000202
ialmdev5!GHALGetFctTable+0x5c66:
ChildEBP RetAddr Args to Child
b 08ef3b8 bfa20b81 89745000 4edfede1 f793b000 ialmdev5!GHALGetFctTable+0x5c66
b08ef488 bf8056e7 e18872a0 00000000 00000000 win32k!WatchdogDrvSynchronizeSurface+0x57 (FPO: [Non-Fpo])
b08ef49c bf839c40 e18872a0 00000000 00000000 win32k!PDEVOBJ::vSync+0x36 (FPO: [Non-Fpo])
b08ef6b8 bf9e4ee1 e108a2c0 e182f008 00000000 win32k!EngCopyBits+0x103 (FPO: [Non-Fpo])
b08efc44 bf849265 e108a2c0 e18872a0 00000000 win32k!WatchdogDrvCopyBits+0x53 (FPO: [Non-Fpo])
b08efd50 804dd99f e12c2008 00000000 00000189 win32k!NtGdiGetPixel+0x1b2 (FPO: [Non-Fpo])
b08efd50 7c90eb94 e12c2008 00000000 00000189 nt!KiFastCallEntry+0xfc (FPO: [0,0] TrapFrame @ b08efd64)
start end module name
804d7000 806fd000 nt ntkrnlmp.exe Mon Oct 30 06:25:01 2006 (4545D2FD)
806fd000 8071dd00 hal halmacpi.dll Mon Oct 30 05:50:16 2006 (4545CAD8)
b074d000 b0777180 kmixer kmixer.sys Wed Jun 14 04:47:45 2006 (448FCD31)
b0ea2000 b0eb6400 wdmaud wdmaud.sys Wed Jun 14 05:00:44 2006 (448FD03C)
b0fe7000 b0ff5d80 sysaudio sysaudio.sys Wed Aug 04 02:15:54 2004 (41107F1A)
b1033000 b1036ae0 aswRdr aswRdr.SYS Mon Jan 15 12:26:05 2007 (45ABB92D)
b1297000 b1299d00 vstor2 vstor2.sys Mon Nov 13 15:43:11 2006 (4558D8DF)
b1367000 b13b8480 srv srv.sys Mon Aug 14 06:34:39 2006 (44E051BF)
b13cd000 b13d0d00 vmnetuserif vmnetuserif.sys Mon Nov 13 15:40:06 2006 (4558D826)
b1409000 b1449280 HTTP HTTP.sys Thu Mar 16 20:33:09 2006 (441A03C5)
b149a000 b14af580 aswMon2 aswMon2.SYS Wed Nov 01 10:54:26 2006 (4548B522)
b14b0000 b14c7580 vmx86 vmx86.sys Mon Nov 13 15:29:48 2006 (4558D5BC)
b14f0000 b151c400 mrxdav mrxdav.sys Wed Aug 04 02:00:49 2004 (41107B91)
b1751000 b1754280 ndisuio ndisuio.sys Wed Aug 04 02:03:10 2004 (41107C1E)
b1b46000 b1bb4a00 mrxsmb mrxsmb.sys Fri May 05 05:41:42 2006 (445B1DD6)
b1bb5000 b1bdfa00 rdbss rdbss.sys Fri May 05 05:47:55 2006 (445B1F4B)
b1be0000 b1c01d00 afd afd.sys Wed Aug 04 02:14:13 2004 (41107EB5)
b1c02000 b1c29c00 netbt netbt.sys Wed Aug 04 02:14:36 2004 (41107ECC)
b1c2a000 b1c4af00 ipnat ipnat.sys Wed Sep 29 18:28:36 2004 (415B3714)
b1c4b000 b1ca2d80 tcpip tcpip.sys Thu Apr 20 07:51:47 2006 (444775D3)
b1ca3000 b1cb5400 ipsec ipsec.sys Wed Aug 04 02:14:27 2004 (41107EC3)
b1ef4000 b1ef9b00 vmnetbridge vmnetbridge.sys Mon Nov 13 15:40:07 2006 (4558D827)
b1efc000 b1f00ca0 TVICHW32 TVICHW32.SYS Sun Oct 09 00:05:15 2005 (434896FB)
b1f49000 b1f4b900 Dxapi Dxapi.sys Fri Aug 17 16:53:19 2001 (3B7D843F)
b9ff5000 ba028200 update update.sys Wed Aug 04 01:58:32 2004 (41107B08)
ba029000 ba059100 rdpdr rdpdr.sys Wed Aug 04 02:01:10 2004 (41107BA6)
ba05a000 ba06ae00 psched psched.sys Wed Aug 04 02:04:16 2004 (41107C60)
ba06b000 ba081680 ndiswan ndiswan.sys Wed Aug 04 02:14:30 2004 (41107EC6)
ba082000 ba0a5980 portcls portcls.sys Wed Aug 04 02:15:47 2004 (41107F13)
ba0a6000 ba47d440 ALCXWDM ALCXWDM.SYS Thu Jan 25 03:37:13 2007 (45B86C39)
ba47e000 ba4a0680 ks ks.sys Wed Aug 04 02:15:20 2004 (41107EF8)
ba4a1000 ba4b4900 parport parport.sys Wed Aug 04 01:59:04 2004 (41107B28)
ba4b5000 ba4f9800 MRV8335XP MRV8335XP.sys Mon Aug 22 03:04:13 2005 (430978ED)
ba4fa000 ba51cf00 USBPORT USBPORT.SYS Tue Oct 25 19:39:41 2005 (435EC23D)
ba51d000 ba530780 VIDEOPRT VIDEOPRT.SYS Wed Aug 04 02:07:04 2004 (41107D08)
ba531000 ba66eec0 ialmnt5 ialmnt5.sys Tue Sep 20 14:00:52 2005 (43304E54)
ba679000 ba681900 msgpc msgpc.sys Wed Aug 04 02:04:11 2004 (41107C5B)
ba689000 ba694d00 raspptp raspptp.sys Wed Aug 04 02:14:26 2004 (41107EC2)
ba699000 ba6a3200 raspppoe raspppoe.sys Wed Aug 04 02:05:06 2004 (41107C92)
ba6a9000 ba6b5880 rasl2tp rasl2tp.sys Wed Aug 04 02:14:21 2004 (41107EBD)
ba6b9000 ba6c7b80 drmk drmk.sys Wed Aug 04 02:07:54 2004 (41107D3A)
ba6c9000 ba6d7080 redbook redbook.sys Wed Aug 04 01:59:34 2004 (41107B46)
ba6d9000 ba6e5180 cdrom cdrom.sys Wed Aug 04 01:59:52 2004 (41107B58)
ba6e9000 ba6f3380 imapi imapi.sys Wed Aug 04 02:00:12 2004 (41107B6C)
ba6f9000 ba705e00 i8042prt i8042prt.sys Wed Aug 04 02:14:36 2004 (41107ECC)
ba709000 ba718d80 serial serial.sys Wed Aug 04 02:15:51 2004 (41107F17)
ba818000 ba818d00 dxgthk dxgthk.sys Fri Aug 17 16:53:12 2001 (3B7D8438)
baaa0000 baaa2800 VMNET VMNET.SYS Thu Dec 16 03:13:19 2004 (41C1439F)
baaa4000 baaa6580 vmnetadapter vmnetadapter.sys Thu Dec 16 03:13:25 2004 (41C143A5)
baaa8000 baaabc80 mssmbios mssmbios.sys Wed Aug 04 02:07:47 2004 (41107D33)
bacd5000 bace 4900 Cdfs Cdfs.SYS Wed Aug 04 02:14:09 2004 (41107EB1)
bad15000 bad17580 ndistapi ndistapi.sys Fri Aug 17 16:55:29 2001 (3B7D84C1)
bad21000 bad23980 gameenum gameenum.sys Wed Aug 04 02:08:20 2004 (41107D54)
bad25000 bad28c80 serenum serenum.sys Wed Aug 04 01:59:06 2004 (41107B2A)
bad3d000 bad3f280 rasacd rasacd.sys Fri Aug 17 16:55:39 2001 (3B7D84CB)
bad85000 bad9f580 Mup Mup.sys Wed Aug 04 02:15:20 2004 (41107EF8)
bada0000 badcca80 NDIS NDIS.sys Wed Aug 04 02:14:27 2004 (41107EC3)
badcd000 bae59480 Ntfs Ntfs.sys Wed Aug 04 02:15:06 2004 (41107EEA)
bae5a000 bae70780 KSecDD KSecDD.sys Wed Aug 04 01:59:45 2004 (41107B51)
bae71000 bae82f00 sr sr.sys Wed Aug 04 02:06:22 2004 (41107CDE)
bae83000 baea2780 fltMgr fltMgr.sys Mon Aug 21 05:14:57 2006 (44E97991)
baea3000 baeba480 atapi atapi.sys Wed Aug 04 01:59:41 2004 (41107B4D)
baebb000 baee0700 dmio dmio.sys Wed Aug 04 02:07:13 2004 (41107D11)
baee1000 baeff880 ftdisk ftdisk.sys Fri Aug 17 16:52:41 2001 (3B7D8419)
baf30000 baf38880 Fips Fips.SYS Fri Aug 17 21:31:49 2001 (3B7DC585)
baf40000 baf48700 netbios netbios.sys Wed Aug 04 02:03:19 2004 (41107C27)
baf50000 baf58700 wanarp wanarp.sys Wed Aug 04 02:04:57 2004 (41107C89)
baf60000 baf68360 aswTdi aswTdi.SYS Mon Jan 15 12:25:22 2007 (45ABB902)
baf70000 baf7a000 hcmon hcmon.sys Mon Nov 13 15:39:38 2006 (4558D80A)
bafa0000 bafb0a80 pci pci.sys Wed Aug 04 02:07:45 2004 (41107D31)
bafb1000 bafded80 ACPI ACPI.sys Wed Aug 04 02:07:35 2004 (41107D27)
bf800000 bf9c1180 win32k win32k.sys Wed Oct 05 20:05:44 2005 (43446A58)
bf9c2000 bf9d3580 dxg dxg.sys Wed Aug 04 02:00:51 2004 (41107B93)
bf9d4000 bf9e2000 ialmrnt5 ialmrnt5.dll Tue Sep 20 13:52:37 2005 (43304C65)
bf9e2000 bfa04000 ialmdnt5 ialmdnt5.dll Tue Sep 20 13:52:31 2005 (43304C5F)
bfa04000 bfa380a0 ialmdev5 ialmdev5.DLL Tue Sep 20 13:52:20 2005 (43304C54)
bfa39000 bfb1b000 ialmdd5 ialmdd5.DLL Tue Sep 20 13:59:53 2005 (43304E19)
bffa0000 bffe5c00 ATMFD ATMFD.DLL Wed Aug 04 03:56:56 2004 (411096C8)
f75f7000 f75ffc00 isapnp isapnp.sys Fri Aug 17 16:58:01 2001 (3B7D8559)
f7607000 f7611500 MountMgr MountMgr.sys Wed Aug 04 01:58:29 2004 (41107B05)
f7617000 f7623c80 VolSnap VolSnap.s ys Wed Aug 04 02:00:14 2004 (41107B6E)
f7627000 f762fe00 disk disk.sys Wed Aug 04 01:59:53 2004 (41107B59)
f7637000 f7643200 CLASSPNP CLASSPNP.SYS Wed Aug 04 02:14:26 2004 (41107EC2)
f7647000 f764fb80 PxHelp20 PxHelp20.sys Wed Oct 18 13:33:53 2006 (45366581)
f7657000 f7661580 agp440 agp440.sys Wed Aug 04 02:07:40 2004 (41107D2C)
f7697000 f769fd00 intelppm intelppm.sys Wed Aug 04 01:59:19 2004 (41107B37)
f76a7000 f76b0f00 termdd termdd.sys Wed Aug 04 01:58:52 2004 (41107B1C)
f76b7000 f76c0480 NDProxy NDProxy.SYS Fri Aug 17 16:55:30 2001 (3B7D84C2)
f76d7000 f76e5100 usbhub usbhub.sys Wed Aug 04 02:08:40 2004 (41107D68)
f7707000 f770d200 PCIIDEX PCIIDEX.SYS Wed Aug 04 01:59:40 2004 (41107B4C)
f770f000 f7713900 PartMgr PartMgr.sys Fri Aug 17 21:32:23 2001 (3B7DC5A7)
f771f000 f7723080 raspti raspti.sys Fri Aug 17 16:55:32 2001 (3B7D84C4)
f775f000 f7764000 flpydisk flpydisk.sys Wed Aug 04 01:59:24 2004 (41107B3C)
f776f000 f7775180 HIDPARSE HIDPARSE.SYS Wed Aug 04 02:08:15 2004 (41107D4F)
f7777000 f777c200 vga vga.sys Wed Aug 04 02:07:06 2004 (41107D0A)
f777f000 f7783a80 Msfs Msfs.SYS Wed Aug 04 02:00:37 2004 (41107B85)
f7787000 f778e880 Npfs Npfs.SYS Wed Aug 04 02:00:38 2004 (41107B86)
f778f000 f7796000 VMparport VMparport.sys Mon Nov 13 15:38:45 2006 (4558D7D5)
f7797000 f779cb00 Aavmker4 Aavmker4.SYS Wed Dec 20 18:51:55 2006 (4589CC9B)
f77df000 f77e3500 watchdog watchdog.sys Wed Aug 04 02:07:32 2004 (41107D24)
f77ef000 f77f4000 usbuhci usbuhci.sys Wed Aug 04 02:08:34 2004 (41107D62)
f77f7000 f77fda80 usbehci usbehci.sys Tue Oct 25 19:39:41 2005 (435EC23D)
f77ff000 f7800000 fdc fdc.sys unavailable (00000000)
f7807000 f780ca00 mouclass mouclass.sys Wed Aug 04 01:58:32 2004 (41107B08)
f780f000 f7815000 kbdclass kbdclass.sys Wed Aug 04 01:58:32 2004 (41107B08)
f7817000 f781b880 TDI TDI.SYS Wed Aug 04 02:07:47 2004 (41107D33)
f781f000 f7823580 ptilink ptilink.sys Fri Aug 17 16:49:53 2001 (3B7D8371)
f7897000 f789a000 BOOTVID BOOTVID.dll Fri Aug 17 16:49:09 2001 (3B7D8345)
f7987000 f7988b80 kdcom kdcom.dll Fri Aug 17 16:49:10 2001 (3B7D8346)
f7989000 f798a100 WMILIB WMILIB.SYS Fri Aug 17 17:07:23 2001 (3B7D878B)
f798b000 f798c580 intelide intelide.sys Wed Aug 04 01:59:40 2004 (41107B4C)
f798d000 f798e700 dmload dmload.sys Fri Aug 17 16:58:15 2001 (3B7D8567)
f79c3000 f79c4100 swenum swenum.sys Wed Aug 04 01:58:41 2004 (41107B11)
f79c5000 f79c6280 USBD& nbsp; USBD.SYS Fri Aug 17 17:02:58 2001 (3B7D8682)
f79cb000 f79ccf00 Fs_Rec Fs_Rec.SYS Fri Aug 17 16:49:37 2001 (3B7D8361)
f79cd000 f79ce080 Beep Beep.SYS Fri Aug 17 16:47:33 2001 (3B7D82E5)
f79cf000 f79d0080 mnmdd mnmdd.SYS Fri Aug 17 16:57:28 2001 (3B7D8538)
f79d1000 f79d2080 RDPCDD RDPCDD.sys Fri Aug 17 16:46:56 2001 (3B7D82C0)
f79eb000 f79eca80 ParVdm ParVdm.SYS Fri Aug 17 16:49:49 2001 (3B7D836D)
f7a4f000 f7a4fd00 pciide pciide.sys Fri Aug 17 16:51:49 2001 (3B7D83E5)
f7aa1000 f7aa1c00 audstub audstub.sys Fri Aug 17 16:59:40 2001 (3B7D85BC)
f7aaf000 f7aafb80 Null Null.SYS Fri Aug 17 16:47:39 2001 (3B7D82EB)
Mini Kernel Dump does not contain unloaded driver list
Closing open log file c:debuglog.txt
0 Compliments
davistje
Débutant
7 273 Visites
Probably caused by : ialmdev5.DLL ( ialmdev5!GHALGetFctTable+5c51 )
Arguments:
Arg1: 890dd020, Pointer to a stuck thread object. Do .thread then kb on it to find
the hung location.
Arg2: 8943f8e0, Pointer to a DEFERRED_WATCHDOG object.
Arg3: 896dd0e8, Pointer to offending driver name.
Debugging Details:
*** work. ***
***& nbsp; ***
FAULTING_THREAD: 890dd020
CUSTOMER_CRASH_COUNT: 2
BUGCHECK_STR: 0xEA
PROCESS_NAME: HoldemInspector
LAST_CONTROL_TRANSFER: from bfa20b81 to bfa2a421
STACK_TEXT:
b0df83b8 bfa20b81 89778000 5ffef561 f7947000 ialmdev5!GHALGetFctTable+0x5c51
b0df83d4 bfa20bde f7947000 00000000 e181e858 ialmdev5!GmmGetFctTable+0x17961
b0df840c bf9edfec e188e690 e188e690 b0df8430 ialmdev5!GmmGetFctTable+0x179be
b0df841c bf9f7d63 e181e858 00000000 00000000 ialmdnt5!DrvEnableDriver+0xe4c
b0df8430 bf9da231 e181e858 00000000 00000000 ialmdnt5!OsFreeMem+0x3c82
b0df844c bf8bdbb1 e181e858 00000000 00000000 ialmrnt5+0x6231
b0df8488 bf8056e7 e181e858 00000000 00000000 win32k!WatchdogDrvSynchronizeSurface+0x57
b0df849c bf839c40 e181e858 00000000 00000000 win32k!PDEVOBJ::vSync+0x36
b0df86b8 bf9e4ee1 e5e86828 e197b2d8 00000000 win32k!EngCopyBits+0x103
b0df86e0 bf9e4ba7 e5e86828 e181e858 00000000 ialmdnt5+0x2ee1
b0df8b18 bf9f762a e5e86828 e181e858 00000000 ialmdnt5+0x2ba7
b0df8b40 bf9d9bf1 e5e86828 e181e858 00000000 ialmdnt5!OsFreeMem+0x3549
b0df8bf8 bf805d3a e5e86828 e181e858 00000000 ialmrnt5+0x5bf1
b0df8c44 bf849265 e5e86828 e181e858 00000000 win32k!WatchdogDrvCopyBits+0x53
b0df8d50 804dd99f e5802008 00000000 0000012c win32k!NtGdiGetPixel+0x1b2
b0df8d50 7c90eb94 e5802008 00000000 0000012c nt!KiFastCallEntry+0xfc
001adf0c 00000000 00000000 00000000 00000000 0x7c90eb94
STACK_COMMAND: .thread 0xffffffff890dd020 ; kb
FOLLOWUP_IP:
bfa2a421 8b5c240c mov ebx,dword ptr [esp+0Ch]
SYMBOL_NAME: ialmdev5!GHALGetFctTable+5c51
eax=00000000 ebx=5ffef561 ecx=10fef540 edx=4f000000 esi=89778110 edi=00000002
eip=bfa2a421 esp=b0df83b8 ebp=89778000 iopl=0 nv up ei pl zr na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000246
ialmdev5!GHALGetFctTable+0x5c51:
bfa2a421 8b5c240c mov ebx,dword ptr [esp+0Ch] ss:0010:b0df83c4=5ffef561
WARNING: Stack unwind information not available. Following fra mes may be wrong.
b0df8488 bf8056e7 e181e858 00000000 00000000 win32k!WatchdogDrvSynchronizeSurface+0x57 (FPO: [Non-Fpo])
b0df849c bf839c40 e181e858 00000000 00000000 win32k!PDEVOBJ::vSync+0x36 (FPO: [Non-Fpo])
b0df86b8 bf9e4ee1 e5e86828 e197b2d8 00000000 win32k!EngCopyBits+0x103 (FPO: [Non-Fpo])
b0df8c44 bf849265 e5e86828 e181e858 00000000 win32k!WatchdogDrvCopyBits+0x53 (FPO: [Non-Fpo])
b0df8d50 804dd99f e5802008 00000000 0000012c win32k!NtGdiGetPixel+0x1b2 (FPO: [Non-Fpo])
b0df8d50 7c90eb94 e5802008 00000000 0000012c nt!KiFastCallEntry+0xfc (FPO: [0,0] TrapFrame @ b0df8d64)
b0771000 b079b180 kmixer kmixer.sys Wed Jun 14 04:47:45 2006 (448FCD31)
b0e2c000 b0e40400 wdmaud wdmaud.sys Wed Jun 14 05:00:44 2006 (448FD03C)
b0f99000 b0f9cae0 aswRdr aswRdr.SYS Mon Jan 15 12:26:05 2007 (45ABB92D)
b0fd9000 b0fe7d80 sysaudio sysaudio.sys Wed Aug 04 02:15:54 2004 (41107F1A)
b1209000 b120bd00 vstor2 vstor2.sys Mon Nov 13 15:43:11 2006 (4558D8DF)
b12f1000 b1342480 srv srv.sys Mon Aug 14 06:34:39 2006 (44E051BF)
b135f000 b1362d00 vmnetuserif vmnetuserif.sys Mon Nov 13 15:40:06 2006 (4558D826)
b136b000 b13ab280 HTTP HTTP.sys Thu Mar 16 20:33:09 2006 (441A03C5)
b13fc000 b1411580 aswMon2 aswMon2.SYS Wed Nov 01 10:54:26 2006 (4548B522)
b143a000 b1451580 vmx86 vmx86.sys Mon Nov 13 15:29:48 2006 (4558D5BC)
b151a000 b1546400 mrxdav mrxdav.sys Wed Aug 04 02:00:49 2004 (41107B91)
b16d7000 b16da280 ndisuio ndisuio.sys Wed Aug 04 02:03:10 2004 (41107C1E)
b17c9000 b17d3000 hcmon hcmon.sys Mon Nov 13 15:39:38 2006 (4558D80A)
b1881000 b1886b00 vmnetbridge vmnetbridge.sys Mon Nov 13 15:40:07 2006 (4558D827)
b18cb000 b18cbd00 dxgthk dxgthk.sys Fri Aug 17 16:53:12 2001 (3B7D8438)
b1ad0000 b1b3ea00 mrxsmb mrxsmb.sys Fri May 05 05:41:42 2006 (445B1DD6)
b1b3f000 b1b6 9a00 rdbss rdbss.sys Fri May 05 05:47:55 2006 (445B1F4B)
b1b6a000 b1b8bd00 afd afd.sys Wed Aug 04 02:14:13 2004 (41107EB5)
b1b8c000 b1bb3c00 netbt netbt.sys Wed Aug 04 02:14:36 2004 (41107ECC)
b1bb4000 b1bd4f00 ipnat ipnat.sys Wed Sep 29 18:28:36 2004 (415B3714)
b1bd5000 b1c2cd80 tcpip tcpip.sys Thu Apr 20 07:51:47 2006 (444775D3)
b1c2d000 b1c3f400 ipsec ipsec.sys Wed Aug 04 02:14:27 2004 (41107EC3)
b1c80000 b1c82900 Dxapi Dxapi.sys Fri Aug 17 16:53:19 2001 (3B7D843F)
b1e76000 b1e7a500 watchdog watchdog.sys Wed Aug 04 02:07:32 2004 (41107D24)
b9f7f000 b9fb2200 update update.sys Wed Aug 04 01:58:32 2004 (41107B08)
b9fb3000 b9fe3100 rdpdr rdpdr.sys Wed Aug 04 02:01:10 2004 (41107BA6)
b9fe4000 b9ff4e00 psched psched.sys Wed Aug 04 02:04:16 2004 (41107C60)
b9ff5000 ba00b680 ndiswan ndiswan.sys Wed Aug 04 02:14:30 2004 (41107EC6)
ba00c000 ba02f980 portcls portcls.sys Wed Aug 04 02:15:47 2004 (41107F13)
ba030000 ba407440 ALCXWDM ALCXWDM.SYS Thu Jan 25 03:37:13 2007 (45B86C39)
ba408000 ba42a680 ks ks.sys Wed Aug 04 02:15:20 2004 (41107EF8)
ba42b000 ba43e900 parport parport.sys Wed Aug 04 01:59:04 2004 (41107B28)
ba43f000 ba483800 MRV8335XP MRV8335XP.sys Mon Aug 22 03:04:13 2005 (430978ED)
ba484000 ba4a6f00 USBPORT USBPORT.SYS Tue Oct 25 19:39:41 2005 (435EC23D)
ba4a7000 ba4ba780 VIDEOPRT VIDEOPRT.SYS Wed Aug 04 02:07:04 2004 (41107D08)
ba4bb000 ba5f8ec0 ialmnt5 ialmnt5.sys Tue Sep 20 14:00:52 2005 (43304E54)
ba609000 ba618900 Cdfs Cdfs.SYS Wed Aug 04 02:14:09 2004 (41107EB1)
ba619000 ba627080 redbook redbook.sys Wed Aug 04 01:59:34 2004 (41107B46)
ba629000 ba635180 cdrom cdrom.sys Wed Aug 04 01:59:52 2004 (41107B58)
ba639000 ba643380 imapi imapi.sys Wed Aug 04 02:00:12 2004 (41107B6C)
ba649000 ba655e00 i8042prt i8042prt.sys Wed Aug 04 02:14:36 2004 (41107ECC)
ba659000 ba668d80 serial serial.sys Wed Aug 04 02:15:51 2004 (41107F17)
ba669000 ba671d00 intelppm intelppm.sys Wed Aug 04 01:59:19 2004 (41107B37)
baa5f000 baa61580 vmnetadapter vmnetadapter.sys Thu Dec 16 03:13:25 2004 (41C143A5)
baa63000 baa66c80 mssmbios mssmbios.sys Wed Aug 04 02:07:47 2004 (41107D33)
baa7f000 baa81580 ndistapi ndistapi.sys Fri Aug 17 16:55:29 2001 (3B7D84C1)
bace5000 baced880 Fips Fips.SYS Fri Aug 17 21:31:49 2001 (3B7DC585)
bacf5000 bacfd700 netbios netbios.sys Wed Aug 04 02:03:19 2004 (4110 7C27)
bad05000 bad0d700 wanarp wanarp.sys Wed Aug 04 02:04:57 2004 (41107C89)
bad31000 bad33280 rasacd rasacd.sys Fri Aug 17 16:55:39 2001 (3B7D84CB)
baf00000 baf08360 aswTdi aswTdi.SYS Mon Jan 15 12:25:22 2007 (45ABB902)
baf70000 baf7e100 usbhub usbhub.sys Wed Aug 04 02:08:40 2004 (41107D68)
baf90000 baf99480 NDProxy NDProxy.SYS Fri Aug 17 16:55:30 2001 (3B7D84C2)
f7617000 f7623c80 VolSnap VolSnap.sys Wed Aug 04 02:00:14 2004 (41107B6E)
f76a7000 f76b5b80 drmk drmk.sys Wed Aug 04 02:07:54 2004 (41107D3A)
f76b7000 f76c3880 rasl2tp rasl2tp.sys Wed Aug 04 02:14:21 2004 (41107EBD)
f76c7000 f76d1200 raspppoe raspppoe.sys Wed Aug 04 02:05:06 2004 (41107C92)
f76d7000 f76e2d00 raspptp raspptp.sys Wed Aug 04 02:14:26 2004 (41107EC2)
f76e7000 f76ef900 msgpc msgpc.sys Wed Aug 04 02:04:11 2004 (41107C5B)
f76f7000 f7700f00 termdd termdd.sys Wed Aug 04 01:58:52 2004 (41107B1C)
f77b7000 f77be000 VMparport VMparport.sys Mon Nov 13 15:38:45 2006 (4558D7D5)
f77e7000 f77ec000 usbuhci usbuhci.sys Wed Aug 04 02:08:34 2004 (41107D62)
f77ef000 f77f5a80 usbehci usbehci.sys Tue Oct 25 19:39:41 2005 (435EC23D)
f77f7000 f77f8000 fdc fdc.sys unavailable (00000000)
f77ff000 f7804a00 mouclass mouclass.sys Wed Aug 04 01:58:32 2004 (41107B08)
f7807000 f780d000 kbdclass kbdclass.sys Wed Aug 04 01:58:32 2004 (41107B08)
f791b000 f791d800 VMNET VMNET.SYS Thu Dec 16 03:13:19 2004 (41C1439F)
f79b3000 f79b4a80 ParVdm ParVdm.SYS Fri Aug 17 16:49:49 2001 (3B7D836D)
f79cd000 f79ce100 swenum swenum.sys Wed Aug 04 01:58:41 2004 (41107B11)
f79cf000 f79d0280 USBD USBD.SYS Fri Aug 17 17:02:58 2001 (3B7D8682)
f79d9000 f79daf00 Fs_Rec Fs_Rec.SYS Fri Aug 17 16:49:37 2001 (3B7D8361)
f79db000 f79dc080 Beep Beep.SYS Fri Aug 17 16:47:33 2001 (3B7D82E5)
f79dd000 f79de080 mnmdd mnmdd.SYS Fri Aug 17 16:57:28 2001 (3B7D8538)
f79df000 f79e0080 RDPCDD RDPCDD.sys Fri Aug 17 16:46:56 2001 (3B7D82C0)
f7a57000 f7a57c00 audstub audstub.sys Fri Aug 17 16:59:40 2001 (3B7D85BC)
f7a5b000 f7a5bb80 Null Null.SYS Fri Aug 17 16:47:39 2001 (3B7D82EB)
0 Compliments
davistje
Débutant
7 273 Visites
I went back to my ATI card and instead of using ATI's driver's I downloaded and instead the OMEGA driver's.... with write combining turned off my computer has been running crash free (knock on wood!) for several hours (atleast 13hrs). I also changed hardware sound acceleration (in DirectX run dxdiag from start/run) to standard acceleration since I read that correct a similar problem for someone.
Anyone still having this problem try turning write combing off and change sound acceleration to standard and post your results.
I may take out the ATI card and see if these changes work with the onboard video (Intel 865G controller) than again I probably won't bother if my ATI card remains stable.
I will check back in a day or so and report on whether everything is working properly still since I am sure some of you are only using you onboard video because of similar problems with either an ATI card or nVidia card.
0 Compliments
davistje
Débutant
7 273 Visites
Well so far so good! My computer has been running crash free now for over 24hrs! I ripped 2 movies to DVD, played 3 tables of online poker at the same time and I ran 2 movies at the same time (1 on each each of my displays).
Dare I take out my ATI card and try these settings using the Intel 865G onboard video? Well maybe if things are running this good for a few days I will give it a shot just for the hell of it.
Also 1 last note for those of you with who have updatethe motherboard drivers with inf_inst.... don't just run the installer and assume everything is updated like I did! Go online and find a company that will scan your drivers and make sure they all updated! If the scan reveals stuff out of date (eg. S-ATA controller drivers etc...) run the installer following these instructions. For those of you with other chipsets something similar may apply.
Extact the contents of the infinst_autol.exe using WinRar to a temp directory like c: emp. Run a command prompt (Start/Run/Cmd) and cd to the directory where you extracted the .exe to eg c: emp type in cd c: emp and hit enter. Now run the setup.exe file with the -overwrite switch type setup -overwrite and hit enter similarily you can do StartRunC: empsetup.exe -overwrite.... you may need to add infinst_autol to the command if you extracted the files to c: empinfinst_autol.
If your chipset is not Intel you can extract the files the same way however check the readme file to see if there are any command line switches that will do the same as overwrite.
Now go back to the website that you scanned your drivers at and see if everything is now updated properly. I use http://www.driveragent.comto do this check.
You can do a similar thing with the video drivers aswell however I think the command switch is -DOALL.
0 Compliments
davistje
Débutant
7 273 Visites
Well it has been almost 36hrs without a crash! Yippee!
0 Compliments
spikkelmal
Débutant
7 273 Visites
its no WOW/Blizzard problem, i dont play WOW. i had to buy a intel notebook and it displayed that error on the second day. all programme i used was winamp. first i thought it was a virus (not everyones a computer genius) and couldnt do my work (student, not gamer) because i could see absolutely NADA. im personally a AMD fan and after this will certainly remain one and will never recommend an intel to anyone. they cant even sell their product with a working driver.
0 Compliments
mageic
Débutant
7 273 Visites
I too have been dealing with this WoWproblem for MONTHS! an now im just straight up sick of this!! i've updated my drivers COUNTLESS times! problem still occurs! i got my computer wiped! still the same problem! What do i do to fix this!!! PLEASE E-MAIL ME Trevons55@yahoo.comIt seems to be TBC thats effecting this
0 Compliments
khaliqueahm
Débutant
7 273 Visites
Thanks!
0 Compliments
c_boreham
Débutant
7 273 Visites
So do i take it that there is still no update for that driver? i tried the two on the intel website but they said the system did not match or something like that when it did to all intents and purposes. how do you delete the ialmrnt5.dll? i am going to try reducing the settings in the display tab (right click desktop, properties, advanced, troubleshoot, move the arrow two marks to the left and see what happens for a while.
the error message has only recently started happening to my computer, about 6months old.
0 Compliments
bulltd
Débutant
7 273 Visites
I am having the exact same problem. Is there a fix for this?
0 Compliments
juno125
Débutant
7 273 Visites
Im having the exact same problem. I recently bought this laptop. IT uses the Mobile Intel 945GM Express Chipset Family. My driver version is PV14.20. I was running Black and White 2 when i recieved the exact same message. Ive updated the game and im still recieveing the exact same problem. The game compability list says that the game runs under perfect conditions but i seem to seriuosly doubt that list. Im lost. Is there some kind of fix to this problem?
0 Compliments
casinomagic3897
Débutant
7 273 Visites
Hey,
I tried downloading the driver off this link: http://downloadfinder.intel.com/scripts-df-external/Product_Filter.aspx?ProductID=1764 and right befor einstalltion started my computer came up with the error message: "Your system does not meet minimum requirements" ... Grr! Lol - I just wanna play my game!!
0 Compliments
lawrence24
Débutant
7 273 Visites
NEED HELP WITH THIS PROBLEM TOO EMAIL ME PLEASE
lawrencefidelino24@yahoo.com.ph
0 Compliments
lawrence24
Débutant
7 305 Visites
ummmm ok i thing i got the solution to this
all i did is make my games Windowed Mode (not full screen)
thats it, ive never played WoW and Guild Wars
so i dont know if you can make it Windowed Mode
might as well try
all my other games are fixed though...
oh and make sure you get the latest version of your driver
to make sure no lag happens
cyaz
0 Compliments
bauhaus
Débutant
7 305 Visites
for wow players type this in-game:
/console uifaster 0
restart the game.
0 Compliments
mentos
Débutant
7 305 Visites
Hi there WoW fans. Got the same problem after updating and tried everything but thanks to a very good person (hi Idaila :D ) I got the solution for you (it's based on what bauhaus wrote) Ready ? Ok here it goes ;)
OPEN WoW FOLDER. GO TO THE "WTF" FOLDER. OPEN WITH WORD PAD "CONFIG.WTF" AND ADD THIS TEXT LINE: SET UIFaster "0" Then select "Save" (not "Save as" ) and it's done. Enjoy playing WoW again :)
0 Compliments
Répondre
