Software Archive
Read-only legacy content
17060 Discussions
iframe no intel xdk
lucas_s_3
Bom dia queridos colegas.
Quando clico em determinado item do menu, preciso que abra um link no iframe do aplicativo. É possível? Como faço?
Diego_Calp
Valued Contributor I
Hello:
In your menu item event put this code:
$('#myIframeID').attr('src', 'http://www.google.com');
Diego
Diego_Calp
Hello:
Diego
lucas_s_3
Obrigado Diego.
Trabalho com javascript a mais de 5 anos, mas sempre utilizei a linguagem nativa, ou seja, o mesmo codigo que me forneceu eu faria desta forma:
window.open('http://www.google.com.br', "corpo");
Posso utilizar assim, ou devo migrar para a forma que me passou?
Onde encontro conteúdo para estudar este framework? Qual o nome dele?
Obrigado pela atenção.
PaulF_IntelCorp
Using the inAppBrowser plugin and use the API provided by it. You are not in a browser when you write a Cordova app, thus some of those things that work in a browser do not work in a webview. Your code is not associated with a server or a domain, which also causes some issues and confusion.
Diego_Calp
Hi Lucas,
The codeI suggested is using jquery. To work with XDK you could use documentation about javascript, html5 and cordova for any aplication, and depending on your project settings, read about the framework you are using (don't know which one you selected, I suggest Bootstrap) and jquery if you are including it in your projects (XDK adds it automatically, but is optional).
Good luck,
Diego
PaulF_IntelCorp
lucas s. wrote:
I understand, but where to find content to study?
Lucas -- Google is your best friend:
lucas_s_3
Realizando os testes em SIMULATE, funcionou perfeitamente, porém quando gerei o APK e instalei em meu celular não abre o conteúdo no iframe, o que posso fazer?
PaulF_IntelCorp
lucas s. wrote:
Performing tests in SIMULATE, it worked perfectly, but when generate the APK and installed on my mobile phone does not open the content in the iframe, what can I do?
Use the Debug tab to get the best debug environment.
lucas_s_3
Bom dia, não consegui identificar o problema ainda, estou utilizando o script abaixo para abrir a página no iframe, funciona perfeitamente mas quando envio para o celular (APK) não funciona. window.open('http://www.google.com.br', "corpo");
lucas_s_3
Realizei o teste usando a opção TEST do Intel XDK e transferi para o App Preview, funcionou 100%, mas quando realizo a instalação não funciona.
O nome do App na Play Store é: At the CLUB
Ficaria grato se alguém testasse e informasse o problema.
