Software Archive
Read-only legacy content
17060 Discussions
intel xdk 3900 cant create projects
Ridwaan_L_
When trying to create a project with intel xdk
I am using the latest version 3900
I get the below error (I have also attached an image)
Unexpected call to process.exit()
  • unknown
You can cancel plugin resolution and exit this project.
PaulF_IntelCorp
Can you provide more details, I am unable to reproduce the issue. For example, screenshots showing what you are doing, which template are starting from, which options are you selecting, etc.
Ridwaan_L_
@Paul F Thank you for the reply
Please find attached screen shots of process I am following
The problem only started after updateing to version 3900 of xdk
As for templates I tried it with html templates as well as a blank HTML + cordova project
PaulF_IntelCorp
Thank you for those details. I was not able to completely reproduce the issue, but I did find that it took an unusually long period of time to do the install on Windows (on Mac it was relatively fast). I suspect that what is happening is you have a slow network connection and the process that is trying to pullin the plugins for the template is timing out. With a faster connection you probably would see what I saw, an unusually long time to initialize the project, but not so long that it resulted in a timeout.
Are you able to try this from another network that might provide a faster connection, as a way of testing this theory?
Ridwaan_L_
Thank u Paul
I have fixed it by re-intsalling the xdk thank u for the assist
