Software Archive
Read-only legacy content
17061 Discussions
intel xdk update serious issue
Mour_D_
i update my intel xdk one of my plugins got removed during updated , but i want that plugin for my project proper flow , is there any way to fix it
1: this is plugin which got removed as result of updated
<intelxdk:plugin intelxdk:name="orientationLock" intelxdk:value="https://github.com/cogitor/PhoneGap-OrientationLock.git"/>
i tried to readd this plugin but unable to do so getting error plugin not found
to add plugin i went to add plugin > import 3rd party plugin > Git repo
enter repo url: https://github.com/cogitor/PhoneGap-OrientationLock.git and click add plugin
see below screenshot
2: import local plugin seems buggy and not working
3: i tried some othe plugins also
https://github.com/apache/cordova-plugin-device-orientation
and
none seems working
for eg for repo
https://git-wip-us.apache.org/repos/asf/cordova-plugin-device-orientation.git
see below screenshot , what i am missing  do i need to fill other fields also can you tell what values to be used there
4: is there any way i can downgrade and get olx version of intel xdk i am in trouble as it does not works
Amrita_C_Intel
I was able to add https://github.com/cogitor/PhoneGap-OrientationLock plugin successfully. As you upgraded please refer this https://software.intel.com/en-us/forums/intel-xdk/topic/594199#comment-1...
Try to restart your XDK by killing the running one.
Dale_S_Intel
We're currently having a problem when the XDK install location is on a different drive than the project location, e.g. XDK is installed on C: and your project lives on the D: drive.  For now the fix is to copy your project to the D: drive and open it in XDK.  You may need to "delete" the old project first, but that shouldn't delete any actual files, but always backup first.
Let us know if that's the problem you're seeing or if this doesn't correct it.
Dale
Anusha_M_Intel1
If you must, the installer and instructions are provided here: https://software.intel.com/en-us/forums/intel-xdk/topic/594398
Mour_D_
bro i am tired i could not make my work somehow in latest app my video does not plays at all ,i am using crosswalk + android ,
on older version of inter my video play , i do now knwo what went wrong after update
Dale_S_Intel
I believe this is a known issue that we're working on.  I'll update here when I have more info.
Pamela_H_Intel
We hope to have a fix out soon, but meanwhile, for audio/video problems, try making build settings Cordova 5.1.1 and Crosswalk 15. (Just know that Cordova 5.1.1 won't work on Android 2.3 (only 4.0+)).
PaulF_IntelCorp
This issue with audio/video on Crosswalk builds has been resolved. Also, the issue regarding different project and install drives has also been resolved, you need to use version 2548.
