Software Archive
Read-only legacy content
17061 토론
ios indexeddb problem
Jörg_G_
초급자
951 조회수
i develop a Little app with an indexedDb Database. I am Import the plugin: "cordova-plugin-indexedDB" (0.1.2) and the IDE automatic Import the plugin "cordova-plugin-websql" (0.0.10).
On emulate Devices the app works fine. On Chrome too. The build end wiht no Errors and i can install the app on my iPhone 6 IOS 9.3.2. The App starts but no data stored in the database.
Build Log
  • Building a Cordova 5.4.1 application.
  • Using platform cordova-ios 4.0.1.
  • The application name is "dumbo"
  • The package name is "de.schumannsolutions.u18"
  • Plugin "cordova-plugin-statusbar" (2.1.0) installed.
  • Plugin "cordova-plugin-device" (1.1.1) installed.
  • Plugin "cordova-plugin-splashscreen" (3.2.0) installed.
  • Plugin "cordova-plugin-indexedDB" (0.1.2) installed.
  • Plugin "cordova-plugin-websql" (0.0.10) installed.
  • Targeting iOS version 8.0.
any idea ? Thanks
0 포인트
3 응답
PaulF_IntelCorp
951 조회수
Many people prefer to use the SQLite plugin (see the featured plugins list -- cordova-sqlite-storage).
0 포인트
Valerio_P_1
초급자
951 조회수
This is the code to work with Android and IOS. The "Cordova VKWebView Engine" is incompatible with IndexedDB then you do not use it.
document.addEventListener(
    "app.Ready",
    function(){
         if(window.device.platform !== 'Android'){
            window.shimIndexedDB.__useShim();
        createLocalDB();
    false
var db=null;
function createLocalDB(){
    db=null;
    var indexedDB = window.indexedDB || window.mozIndexedDB || window.webkitIndexedDB || window.msIndexedDB || window.shimIndexedDB;
    var request = indexedDB.open(LOCAL_DB_NAME, LOCAL_DB_VERSION);
    request.onupgradeneeded = function(){
        db = request.result;
        // from heare, create your objectStore
    request.onsuccess = function(){
        console.log("Success");
    request.onerror = function(){
        console.log("Error in indexedDB");
0 포인트
Daniele_A_
초급자
951 조회수
up ^ i have the same problem in iphone with ios 9 ... when i try to create database he can't i use various plug in no way....There is news about ios and indexdb?? Wich plug in it's best to use? Regards
0 포인트
응답
