Software Archive
Read-only legacy content
17060 Discussions
lambda for TBB parallel_for
Goran_N
Is it possible to pass a lambda function into 'parallel_for' instead of Body object?
This is an example of what I would like to do:
auto procEachRowL = [this, &imageOut, &imWB](const tbb::blocked_range &r){
for (size_t i=r.begin(); i this->ProcessEachRow(i, imageOut, imWB); };
parallel_for(blocked_range(0, yMax, 1), procEachRowL); // Syntax error here
JenniferJ
Quoting - Goran N
for (size_t i=r.begin(); ithis->ProcessEachRow(i, imageOut, imWB); };
I used NQ example and it works fine for me.
[cpp]void solve() {
	auto forPar_For =
 [](const blocked_range &r){
      for (size_t i = r.begin(); i != r.end(); ++i) {
      setQueen(new int[size], 0, (int)i);
	parallel_for(blocked_range(0, size, 1), forPar_For);
[/cpp]
I'm using the Parallel Composer update2-revised.
Jennifer
Goran_N
My syntax error was coming from:
parallel_for(blocked_range<int>...
instead of:
parallel_for(blocked_range<size_t>...
Now it works correctly. Thanks!
Quoting - Jennifer Jiang (Intel)
[cpp]void solve() {
auto forPar_For =
[/cpp]
Jennifer
