Software Archive
Read-only legacy content
17061 Discussions
license for CCompL is not available now (-15,570,115)
Guy_Tel-Zur
I think I successfully installed and registered Intel Cluster Studio XE 2013 SP1.
whien I try to use icc I get:
Error: A license for CCompL is not available now (-15,570,115).
A connection to the license server could not be made.  You should
make sure that your license daemon process is running: both an
lmgrd process and an INTEL process should be running
if your license limits you to a specified number of licenses in use
at a time.  Also, check to see if the wrong port@host or the wrong
license file is being used, or if the port or hostname in the license
file has changed.
License file(s) used were (in this order):
    1.  Trusted Storage
**  2.  /home/telzurintel/licenses/XXXXXX.lic
**  3.  /opt/intel/composer_xe_2013_sp1.0.080/Licenses
**  4.  /opt/intel/licenses/l_XXXXXX.lic
**  5.  /Users/Shared/Library/Application Support/Intel/Licenses
**  6.  /opt/intel/composer_xe_2013_sp1.0.080/bin/intel64/*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
INTEL_LICENSE_FILE points to /opt/intel/licenses/l_XXXXXX.lic
(the real license name was renamed here to XXXXX)
Please advise!
Guy
icc: error #10052: could not checkout FLEXlm license
James_T_Intel
Hi Guy,
Are you using a floating license?  Please send me (via private message is fine) the logs from your license server.
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
Jeremy_F_
Hey !
I have the same problem with my licence, as you can see:
# module load intel/2013.1.046.mpt
# icc
file has changed.
    1.  Trusted Storage
**  2.  /workfs/dev/libs/intel/2013.1.046/composer_xe_2013_sp1.2.144/Licenses
**  3.  /root/intel/licenses
**  4.  /opt/intel/licenses/COM_L___XXXX-XXXXXXXX.lic
        //serial number stripped out.
**  6.  /workfs/dev/libs/intel/2013.1.046/composer_xe_2013_sp1.2.144/bin/intel64/*.lic
Can you help me to fix this problem ? I try to change the licence path without success.
Thank you.
J. Foulon
Guy_Tel-zur1
Do you have by chance two Intel developer accounts? if so you perhaps you are trying to use the software from the other identity.
--Guy
Hubert_H_Intel
Jeremy,
On your login prompt, please create a log file and send it to me via "Send Author A Message" link to protect confidential data. I've purged also confidential data of your last post.
# export INTEL_LMD_DEBUG=/tmp/LMD_log.txt
# icc
Hubert.
kiran_s_
hi  ...
i have same problem
[root@nits-hpc ~]# icc
file has changed.
    1.  Trusted Storage
**  2.  /opt/intel/composer_xe_2013_sp1.2.144/licenses
**  3.  /opt/intel/licenses/lic1.lic
**  4.  /root/intel/licenses
**  5.  /opt/intel/composer_xe_2013_sp1.2.144/Licenses
**  6.  /Users/Shared/Library/Application Support/Intel/Licenses
**  7.  /opt/intel/composer_xe_2013_sp1.2.144/bin/intel64/*.lic
please help
kiran_s_
i got the solution of this problem
restart the flexlm service which is  your  license server
which is inside
/opt/intel/flexlm/
and execute lmgrd service
./lmgrd
Thank you
kiran sonavane
