Software Archive
Read-only legacy content
17060 Discussions
miccheck failed
ramy_a_
I performed the miccheck command on a node which has two Xeon phi
Here is the output:
MicCheck 3.6.1-r1
Copyright (c) 2015, Intel Corporation.
Executing default tests for host
  Test 0: Check number of devices the OS sees in the system ... pass
  Test 1: Check mic driver is loaded ... pass
  Test 2: Check number of devices driver sees in the system ... pass
  Test 3: Check mpssd daemon is running ... pass
Executing default tests for device: 0
  Test 4 (mic0): Check device is in online state and its postcode is FF ... pass
  Test 5 (mic0): Check ras daemon is available in device ... pass
  Test 6 (mic0): Check running flash version is correct ... fail
    device flash version does not match, should be '391', it is '386'.
Executing default tests for device: 1
  Test 7 (mic1): Check device is in online state and its postcode is FF ... pass
  Test 8 (mic1): Check ras daemon is available in device ... pass
  Test 9 (mic1): Check running flash version is correct ... fail
Status: FAIL
Failure: A device test failed
I need to know how to fix this issue.
If I need to update the flash version, pleae,can anyone provide me with procedures to do so?
Thanks for your help.
Ramy
JJK
New Contributor III
most likely you've just upgraded your MPSS version and did not upgrade the flash on the Phi's. Try running
micflash -update -device all
to see if that solves it.
