Software Archive
Read-only legacy content
17060 Discussions
offload error: cannot offload to MIC - device is not available
ye_f_1
I am a newer in MIC.
I install and config Phi follow this link "arrayfire.com/getting-started-with-the-intel-xeon-phi-on-ubuntu-14-04linux-kernel-3-13-0/".It seems that everything is OK.But when I run program,I get this information "offload error: cannot offload to MIC - device is not available".I source compilervars.sh intel64 before running program.My compiler version is "Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.1.150 Build 20151021".
I input "micctrl -s",then I get follow output:
mic0: online (mode: linux image: /usr/share/mpss/boot/bzImage-knightscorner).
then I ssh mic0,when I input password.I get follow information:
Tunnel device open failed.
Could not request tunnel forwarding.
after that,I check if coi_daemo has started on coprocessor and input "ps -aux | grep coi_daemon",It seems that coi_daemo is already running:
micuser    4827  0.0  0.0  97912  1580 ?        Sl   10:13   0:00 /usr/bin/coi_daemon --coiuser=micuser
This is my source program:
#include <stdio.h>
#include <math.h>
#include "offload.h"
int
main()
        float pi=0.0;
        int count=10000;
        int i;
        #pragma offload target(mic)
        for(i=0;i<count;i++)
                float t=(float)((i+0.5)/count);
                pi+=4.0/(1.0+t*t);
        pi/=count;
        if(fabs(pi-3.14)<=0.01)
                printf("pass pi=%f\n",pi);
        else
                printf("fail\n");
        return 0;
what should I do ?
ye_f_1
I input "sudo miccheck" and get follow information:
miccheck
MicCheck 3.4.6-r1
Copyright 2013 Intel Corporation All Rights Reserved
Executing default tests for host
  Test 0: Check number of devices the OS sees in the system ... pass
  Test 1: Check mic driver is loaded ... pass
  Test 2: Check number of devices driver sees in the system ... pass
  Test 3: Check mpssd daemon is running ... pass
Executing default tests for device: 0
  Test 4 (mic0): Check device is in online state and its postcode is FF ... pass
terminate called after throwing an instance of 'mic_exception'
  what():  std::exception
Aborted (core dumped)
ye_f_1
I find a problem,when I use "sudo micinfo":
MicInfo Utility Log
Created Fri Jan 29 15:47:26 2016
    System Info
        HOST OS            : Linux
        OS Version        : 3.19.0-25-generic
        Driver Version        : 3.4.2-1
        MPSS Version        : NotAvailable
        Host Physical Memory    : 65866 MB
Device No: 0, Device Name: mic0
    Version
        Flash Version          : 2.1.02.0390
        SMC Firmware Version     : 1.17.6900
        SMC Boot Loader Version     : 1.8.4326
        uOS Version          : 2.6.38.8+mpss3.4.6
        Device Serial Number      : ADKC51600279
    Board
        Vendor ID          : 0x8086
        Device ID          : 0x225d
        Subsystem ID          : 0x3608
        Coprocessor Stepping ID     : 2
        PCIe Width          : x16
        PCIe Speed          : 5 GT/s
        PCIe Max payload size     : 256 bytes
        PCIe Max read req size     : 512 bytes
        Coprocessor Model     : 0x01
        Coprocessor Model Ext     : 0x00
        Coprocessor Type     : 0x00
        Coprocessor Family     : 0x0b
        Coprocessor Family Ext     : 0x00
        Coprocessor Stepping      : C0
        Board SKU          : C0PRQ-3120/3140 P/A
        ECC Mode          : Enabled
        SMC HW Revision      : Product 300W Active CS
    Cores
        Total No of Active Cores : 57
        Voltage          : 0 uV
        Frequency         : 1100000 kHz
    Thermal
        Fan Speed Control      : On
        Fan RPM          : 900
        Fan PWM          : 20
        Die Temp         : 45 C
    GDDR
        GDDR Vendor         : Elpida
        GDDR Version         : 0x1
        GDDR Density         : 2048 Mb
        GDDR Size         : 5952 MB
        GDDR Technology         : GDDR5
        GDDR Speed         : 5.000000 GT/s
        GDDR Frequency         : 2500000 kHz
        GDDR Voltage         : 1501000 uV
JJK
New Contributor III
On the host side you need to run the mpss daemon in order to "talk" to the Mic card. I don't know if that is explained in the arrayfire.com HOWTO, but this deamon (mpssd) is essential for all Mic operations. Your mic_exception error is also most likely caused by this.
