Software Archive
Read-only legacy content
17060 Discussions
"Collapsible" inside a "collapsible" in Bootstrap bug
re_s_
when i make a collapsible menu and i put other collapsible menus in it, the names of the menus, merge (please see the pictures)
any ideas?
Thanks a lot in advance
re_s_
Pamela_H_Intel
Did you strictly use App Designer to create the collapsible menus? Or did you modify css? or use JavaScript?
re_s_
Hi Pamela, i am using App designer.
Chris_P_Intel
Look at the source and see if the names have been merged there. If so, correct them. Should be trivial to do so. That should fix the problem, though, if the collapsible is edited in App Designer again it might happen again.
If the names are not merged in the source then it sounds like some sort of bug in Bootstrap itself. But this seems unlikely.
Let me know what you find.
re_s_
i have corrected the names through the source code but they keep o merging, however thanks for your efford to help me.
Pamela_H_Intel
If you are comfortable working with the code, an option would be to work in the code view (not the design view) - especially after you have the general set up of your UI.
Edi_L_
Hi all
I have the same issue? Is there any workaround, so I can still work with App Designer?
thanks for your help
Regads
Ed
PaulF_IntelCorp
App Designer has been deprecated and will be removed, it is no longer being supported. Please see the release notes for details > https://software.intel.com/en-us/xdk/docs/release-notes-information-intel-xdk <
