Software Archive
Read-only legacy content
17060 Discussions
source ifortvars.csh error
shuhe_z_
Hi,Support
  I am evaluating Intel Parallel Studio XE 2015 Update 5, after I installed it. I edit my user (the user shell is csh) profile file " .cshrc" and add the following into it:
    source /opt/intel/bin/iccvars.csh
     source /opt/intel/bin/ifortvars.csh
   Then I update the change as "source .cshrc", it reports the following error:
     ERROR: Unknown switch ''. Accepted values: ia32, intel64
    And it results that we can't find the path of the executable file "icc or ifort " in the user enviroment.
  My OS is redhat6.8 X86_64.
  Do you any comment for this error ?
   I also attached the file iccvars.csh and ifortvars.csh for your reference.
Zheng
Devorah_H_Intel
source <install-dir>/bin/compilervars.sh <arg>
where <install-dir> is the directory structure containing the compiler /bin directory, and <arg> is one of the following architecture arguments:
intel64: Compilers and libraries for Intel® 64 architectures only
ia32: Compilers and libraries for IA-32 architectures only
Note: The default path for <install-dir> is /opt/intel/composer_xe_201X
Make sure to specify the <arg> value when sourcing. It doesn't look like it was set in the script. Hence the error message.
shuhe_z_
Hi, Devorah
    As your instruction, I changed the path definition as the following in the file .cshrc
      source /opt/intel/composer_xe_2015.5.223/bin/iccvars.csh intel64
      source /opt/intel/composer_xe_2015.5.223/bin/ifortvars.csh intel64
    Now the problem has been fixed.
Thanks for your kindly help.
Zheng
