Software Archive
Read-only legacy content
toastr
Dan_K_
I'm using a plugin that provides a 'toast-like' popup; see https://github.com/CodeSeven/toastr
Works in the emulator but not in the App Preview. Any ideas?
Amrita_C_Intel
I'm guessing that your app is hung up trying to retrieve over the device network interface. Please read this doc regarding the limitations of the Emulate tab > https://software.intel.com/en-us/xdk/docs/intel-xdk-debug-and-test-overv... and see the rest of that page for a variety of suggestions regarding how to debug your app on a real device. Also, check this documentation regarding the domain white list feature in the Build Settings on the Projects tab >http://cordova.apache.org/docs/en/4.0.0/guide_appdev_whitelist_index.md....
Suggestion:
Try killing the current running version of the app preview.
What happens if you build the app?
Dan_K_
When I do a build and download to Google Drive, then access via the phone, I get "Parse Error - an error occurred while parsing the package".
Amrita_C_Intel
Can you provide the build log or error you are getting?
Dan_K_
A rebuild did the trick. Not sure what the issue was.
