Software Archive
Read-only legacy content
17060 Discussions
uncaughtException occured: Error: ENOTEMPTY
Philip_J_
When I attempted to use XDK IoT edition to upload the node.js blink application to my edison I got the following error. I previously had running the Ardiouno blink application which is still running. (Pressing stop button on the XDK IoT does not stop the light blinking). What should I do?
Phil
UPLOADING: Uploading project bundle to IoT device.
uncaughtException occured: Error: ENOTEMPTY, directory not empty '/node_app_slot/zetta-starter-project-master/zetta-starter-project-master'
    at Object.fs.rmdirSync (fs.js:612:18)
    at clearFolder (/opt/xdk-daemon/current/daemonUtils.js:52:8)
    at clearFolder (/opt/xdk-daemon/current/daemonUtils.js:47:11)
    at Object.clearFolder (/opt/xdk-daemon/current/daemonUtils.js:47:11)
    at /opt/xdk-daemon/current/appDaemon.js:239:19
    at Object.oncomplete (fs.js:107:15)
NagaVenkat_K_Intel
Login to the terminal on the Edison board
restart the app-daemon service using the terminal
systemctl enable xdk-daemon
systemctl restart xdk-daemon
or empty the contents of node_app_slot folder
root@edison:~# cd /node_app_slot/
root@edison:~/.node_app_slot# rm -Rf *
