~i have made a test about the BusSpeedReadback.
when the data is not small,it's performance is 6.xxGB/s.
Bus when the data reach to 1GB,the performance is not steady.
Sometimes it's 6.xxGB/s,sometimes 0.3xxGB/s.
Why the busspeedreadback,and busspeeddownload are not steady.
~when the data is small!!! an error
I don't know, off hand, what may be causing that. I have sent email to one of the people who worked on that code to see if they can provide an answer.
I assume you are running the SHOC benchmark from https://github.com/vetter/shoc-mic. If so can you send me the output of the benchmark run, it should show you the statistical variation,
Reza
BTW, I just ran the SHOC BusSpeedReadback with 1 GB of data transfer and seeing consistent result for 1 GB transfers 6.87 GB/s.
test | atts | units | median | mean | stddev | min | max | trial0 | trial1 | trial2 | trial3 | trial4 | trial5 | trial6 | trial7 | trial8 | trial9 |
ReadbackSpeed | 1048576kB | GB/sec | 6.87285 | 6.87076 | 0.007744 | 6.85817 | 6.88146 | 6.87815 | 6.87696 | 6.87287 | 6.87142 | 6.87283 | 6.88146 | 6.87463 | 6.85817 | 6.86027 | 6.8608 |
dl. h.: go into BIOS and under "Advanced" set the parameter "Extended ATR" to 0x01. The symptoms you are seeing can occur when this parameter is set to its default value 0x03. See also http://software.intel.com/en-us/forums/topic/401509 for explanation.
